[petsc-users] MUMPS error
Mon May 25 04:06:30 CDT 2015
On Mon, May 25, 2015 at 2:54 AM, venkatesh g <venkateshgk.j at gmail.com>
wrote:
> Ok this will load the matrices in parallel correct ?
Yes
   Matt
> On Sun, May 24, 2015 at 7:36 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Sun, May 24, 2015 at 8:57 AM, venkatesh g <venkateshgk.j at gmail.com>
>> wrote:
>>> I am using Matload option as in the ex7.c code given by the Slepc.
>>> ierr = MatLoad(A,viewer);CHKERRQ(ierr);
>>> There is no problem here right ? or any additional option is required
>>> for very large matrices while running the eigensolver in parallel ?
>> This will load the matrix from the viewer (presumably disk). There are no
>> options for large matrices.
>>   Thanks,
>>       Matt
>>> cheers,
>>> Venkatesh
>>> On Sat, May 23, 2015 at 5:43 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Sat, May 23, 2015 at 7:09 AM, venkatesh g <venkateshgk.j at gmail.com>
>>>> wrote:
>>>>> Hi,
>>>>> Thanks.
>>>>> Per node it has 24 cores and each core has 4 GB RAM. And the job was
>>>>> submitted in 10 nodes.
>>>>> So, does it mean it requires 10G for one core ? or for 1 node ?
>>>> The error message from MUMPS said that it tried to allocate 10G. We
>>>> must assume each process
>>>> tried to do the same thing. That means if you scheduled 24 processes on
>>>> a node, it would try to
>>>> allocate at least 240G, which is in excess of what you specify above.
>>>> Note that this has nothing to do with PETSc. It is all in the
>>>> documentation for that machine and its
>>>> scheduling policy.
>>>>   Thanks,
>>>>      Matt
>>>>> cheers,
>>>>> Venkatesh
>>>>> On Sat, May 23, 2015 at 5:17 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Sat, May 23, 2015 at 6:44 AM, venkatesh g <venkateshgk.j at gmail.com
>>>>>> > wrote:
>>>>>>> Hi,
>>>>>>> The same eigenproblem runs with 120 GB RAM in a serial machine in
>>>>>>> Matlab.
>>>>>>> In Cray I fired with 240*4 GB RAM in parallel. So it has to go in
>>>>>>> right ?
>>>>>> I do not know how MUMPS allocates memory, but the message is
>>>>>> unambiguous. Also,
>>>>>> this is concerned with the memory available per node. Do you know how
>>>>>> many processes
>>>>>> per node were scheduled? The message below indicates that it was
>>>>>> trying to allocate 10G
>>>>>> for one process.
>>>>>>> And for small matrices it is having negative scaling i.e 24 core is
>>>>>>> running faster.
>>>>>> Yes, for strong scaling you always get slowdown eventually since
>>>>>> overheads dominate
>>>>>> work, see Amdahl's Law.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> I have attached the submission script.
>>>>>>> Pls see.. Kindly let me know
>>>>>>> cheers,
>>>>>>> Venkatesh
>>>>>>> On Sat, May 23, 2015 at 4:58 PM, Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Sat, May 23, 2015 at 2:39 AM, venkatesh g <
>>>>>>>> venkateshgk.j at gmail.com> wrote:
>>>>>>>>> Hi again,
>>>>>>>>> I have installed the Petsc and Slepc in Cray with intel compilers
>>>>>>>>> with Mumps.
>>>>>>>>> I am getting this error when I solve eigenvalue problem with large
>>>>>>>>> matrices: [201]PETSC ERROR: Error reported by MUMPS in numerical
>>>>>>>>> factorization phase: Cannot allocate required memory 9632 megabytes
>>>>>>>> It ran out of memory on the node.
>>>>>>>>> Also it is again not scaling well for small matrices.
>>>>>>>> MUMPS strong scaling for small matrices is not very good. Weak
>>>>>>>> scaling is looking at big matrices.
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> Kindly let me know what to do.
>>>>>>>>> cheers,
>>>>>>>>> Venkatesh
>>>>>>>>> On Tue, May 19, 2015 at 3:02 PM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Tue, May 19, 2015 at 1:04 AM, venkatesh g <
>>>>>>>>>>> Hi,
>>>>>>>>>>> I have attached the log of the command which I gave in the
>>>>>>>>>>> master node: make streams NPMAX=32
>>>>>>>>>>> I dont know why it says 'It appears you have only 1 node'. But
>>>>>>>>>>> other codes run in parallel with good scaling on 8 nodes.
>>>>>>>>>> If you look at the STREAMS numbers, you can see that your system
>>>>>>>>>> is only able to support about 2 cores with the
>>>>>>>>>> available memory bandwidth. Thus for bandwidth constrained
>>>>>>>>>> operations (almost everything in sparse linear algebra
>>>>>>>>>> and solvers), your speedup will not be bigger than 2.
>>>>>>>>>> Other codes may do well on this machine, but they would be
>>>>>>>>>> compute constrained, using things like DGEMM.
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>> Kindly let me know.
>>>>>>>>>>> Venkatesh
>>>>>>>>>>> On Mon, May 18, 2015 at 11:21 PM, Barry Smith <
>>>>>>>>>>> bsmith at mcs.anl.gov> wrote:
>>>>>>>>>>>>    Run the streams benchmark on this system and send the
>>>>>>>>>>>> results.
>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#computers
>>>>>>>>>>>> > On May 18, 2015, at 11:14 AM, venkatesh g <
>>>>>>>>>>>> > Hi,
>>>>>>>>>>>> > I have emailed the mumps-user list.
>>>>>>>>>>>> > Actually the cluster has 8 nodes with 16 cores, and other
>>>>>>>>>>>> codes scale well.
>>>>>>>>>>>> > I wanted to ask if this job takes much time, then if I submit
>>>>>>>>>>>> on more cores, I have to increase the icntl(14).. which would again take
>>>>>>>>>>>> long time.
>>>>>>>>>>>> > So is there another way ?
>>>>>>>>>>>> > cheers,
>>>>>>>>>>>> > Venkatesh
>>>>>>>>>>>> > On Mon, May 18, 2015 at 7:16 PM, Matthew Knepley <
>>>>>>>>>>>> > On Mon, May 18, 2015 at 8:29 AM, venkatesh g <
>>>>>>>>>>>> > Hi I have attached the performance logs for 2 jobs on
>>>>>>>>>>>> different processors. I had to increase the workspace icntl(14) when I
>>>>>>>>>>>> submit on more cores since it is failing with small value of icntl(14).
>>>>>>>>>>>> > 1. performance_log1.txt is run on 8 cores (option given
>>>>>>>>>>>> -mat_mumps_icntl_14 200)
>>>>>>>>>>>> > 2. performance_log2.txt is run on 2 cores (option given
>>>>>>>>>>>> -mat_mumps_icntl_14 85  )
>>>>>>>>>>>> > 1) Your number of iterates increased from 7600 to 9600, but
>>>>>>>>>>>> that is a relatively small effect
>>>>>>>>>>>> > 2) MUMPS is just taking a lot longer to do forward/backward
>>>>>>>>>>>> solve. You might try emailing
>>>>>>>>>>>> > the list for them. However, I would bet that your system has
>>>>>>>>>>>> enough bandwidth for 2 procs
>>>>>>>>>>>> > and not much more.
>>>>>>>>>>>> >   Thanks,
>>>>>>>>>>>> >      Matt
>>>>>>>>>>>> > Venkatesh
>>>>>>>>>>>> > On Sun, May 17, 2015 at 6:13 PM, Matthew Knepley <
>>>>>>>>>>>> > On Sun, May 17, 2015 at 1:38 AM, venkatesh g <
>>>>>>>>>>>> > Hi, Thanks for the information. I now increased the workspace
>>>>>>>>>>>> by adding '-mat_mumps_icntl_14 100'
>>>>>>>>>>>> > It works. However, the problem is, if I submit in 1 core I
>>>>>>>>>>>> get the answer in 200 secs, but with 4 cores and '-mat_mumps_icntl_14 100'
>>>>>>>>>>>> it takes 3500secs.
>>>>>>>>>>>> > Send the output of -log_summary for all performance queries.
>>>>>>>>>>>> Otherwise we are just guessing.
>>>>>>>>>>>> >     Matt
>>>>>>>>>>>> > My command line is: 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2
>>>>>>>>>>>> -eps_nev 1 -st_type sinvert -eps_max_it 5000 -st_ksp_type preonly
>>>>>>>>>>>> -st_pc_type lu -st_pc_factor_mat_solver_package mumps -mat_mumps_icntl_14
>>>>>>>>>>>> 100'
>>>>>>>>>>>> > Kindly let me know.
>>>>>>>>>>>> > Venkatesh
>>>>>>>>>>>> > On Sat, May 16, 2015 at 7:10 PM, David Knezevic <
>>>>>>>>>>>> david.knezevic at akselos.com> wrote:
>>>>>>>>>>>> > On Sat, May 16, 2015 at 8:08 AM, venkatesh g <
>>>>>>>>>>>> > Hi,
>>>>>>>>>>>> > I am trying to solving AX=lambda BX eigenvalue problem.
>>>>>>>>>>>> > A and B are of sizes 3600x3600
>>>>>>>>>>>> > I run with this command :
>>>>>>>>>>>> > 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1 -st_type
>>>>>>>>>>>> sinvert -eps_max_it 5000 -st_ksp_type preonly -st_pc_type lu
>>>>>>>>>>>> -st_pc_factor_mat_solver_package mumps'
>>>>>>>>>>>> > I get this error: (I get result only when I give 1 or 2
>>>>>>>>>>>> processors)
>>>>>>>>>>>> > Reading COMPLEX matrices from binary files...
>>>>>>>>>>>> > [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>> > [0]PETSC ERROR: Error in external library!
>>>>>>>>>>>> > [0]PETSC ERROR: Error reported by MUMPS in numerical
>>>>>>>>>>>> factorization phase: INFO(1)=-9, INFO(2)=2024
>>>>>>>>>>>> > The MUMPS error types are described in Chapter 7 of the MUMPS
>>>>>>>>>>>> manual. In this case you have INFO(1)=-9, which is explained in the manual
>>>>>>>>>>>> as:
>>>>>>>>>>>> > "–9 Main internal real/complex workarray S too small. If
>>>>>>>>>>>> INFO(2) is positive, then the number of entries that are missing in S at
>>>>>>>>>>>> the moment when the error is raised is available in INFO(2). If INFO(2) is
>>>>>>>>>>>> negative, then its absolute value should be multiplied by 1 million. If an
>>>>>>>>>>>> error –9 occurs, the user should increase the value of ICNTL(14) before
>>>>>>>>>>>> calling the factorization (JOB=2) again, except if ICNTL(23) is provided,
>>>>>>>>>>>> in which case ICNTL(23) should be increased."
>>>>>>>>>>>> > This says that you should use ICTNL(14) to increase the
>>>>>>>>>>>> working space size:
>>>>>>>>>>>> > "ICNTL(14) is accessed by the host both during the analysis
>>>>>>>>>>>> and the factorization phases. It corresponds to the percentage increase in
>>>>>>>>>>>> the estimated working space. When significant extra fill-in is caused by
>>>>>>>>>>>> numerical pivoting, increasing ICNTL(14) may help. Except in special cases,
>>>>>>>>>>>> the default value is 20 (which corresponds to a 20 % increase)."
>>>>>>>>>>>> > So, for example, you can avoid this error via the following
>>>>>>>>>>>> command line argument to PETSc: "-mat_mumps_icntl_14 30", where 30
>>>>>>>>>>>> indicates that we allow a 30% increase in the workspace instead of the
>>>>>>>>>>>> default 20%.
>>>>>>>>>>>> > David
>>>>>>>>>>>> > What most experimenters take for granted before they begin
>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>> > -- Norbert Wiener
>>>>>>>>>>>> > -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150525/5a640c0b/attachment.html>
