[petsc-users] MUMPS error
    venkatesh g
    venkateshgk.j at gmail.com
    Mon May 25 04:10:02 CDT 2015
Ok now I have restructured the matrix. Now I will not use mumps and use
only Petsc and Slepc. I am getting some error.
I will open another thread.
Venkatesh
On Mon, May 25, 2015 at 2:36 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, May 25, 2015 at 2:54 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
>> Ok this will load the matrices in parallel correct ?
> Yes
>    Matt
>> On Sun, May 24, 2015 at 7:36 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sun, May 24, 2015 at 8:57 AM, venkatesh g <venkateshgk.j at gmail.com>
>>> wrote:
>>>> I am using Matload option as in the ex7.c code given by the Slepc.
>>>> ierr = MatLoad(A,viewer);CHKERRQ(ierr);
>>>> There is no problem here right ? or any additional option is required
>>>> for very large matrices while running the eigensolver in parallel ?
>>> This will load the matrix from the viewer (presumably disk). There are
>>> no options for large matrices.
>>>   Thanks,
>>>       Matt
>>>> cheers,
>>>> Venkatesh
>>>> On Sat, May 23, 2015 at 5:43 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Sat, May 23, 2015 at 7:09 AM, venkatesh g <venkateshgk.j at gmail.com>
>>>>> wrote:
>>>>>> Hi,
>>>>>> Thanks.
>>>>>> Per node it has 24 cores and each core has 4 GB RAM. And the job was
>>>>>> submitted in 10 nodes.
>>>>>> So, does it mean it requires 10G for one core ? or for 1 node ?
>>>>> The error message from MUMPS said that it tried to allocate 10G. We
>>>>> must assume each process
>>>>> tried to do the same thing. That means if you scheduled 24 processes
>>>>> on a node, it would try to
>>>>> allocate at least 240G, which is in excess of what you specify above.
>>>>> Note that this has nothing to do with PETSc. It is all in the
>>>>> documentation for that machine and its
>>>>> scheduling policy.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> cheers,
>>>>>> Venkatesh
>>>>>> On Sat, May 23, 2015 at 5:17 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Sat, May 23, 2015 at 6:44 AM, venkatesh g <
>>>>>>> venkateshgk.j at gmail.com> wrote:
>>>>>>>> Hi,
>>>>>>>> The same eigenproblem runs with 120 GB RAM in a serial machine in
>>>>>>>> Matlab.
>>>>>>>> In Cray I fired with 240*4 GB RAM in parallel. So it has to go in
>>>>>>>> right ?
>>>>>>> I do not know how MUMPS allocates memory, but the message is
>>>>>>> unambiguous. Also,
>>>>>>> this is concerned with the memory available per node. Do you know
>>>>>>> how many processes
>>>>>>> per node were scheduled? The message below indicates that it was
>>>>>>> trying to allocate 10G
>>>>>>> for one process.
>>>>>>>> And for small matrices it is having negative scaling i.e 24 core is
>>>>>>>> running faster.
>>>>>>> Yes, for strong scaling you always get slowdown eventually since
>>>>>>> overheads dominate
>>>>>>> work, see Amdahl's Law.
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> I have attached the submission script.
>>>>>>>> Pls see.. Kindly let me know
>>>>>>>> cheers,
>>>>>>>> Venkatesh
>>>>>>>> On Sat, May 23, 2015 at 4:58 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Sat, May 23, 2015 at 2:39 AM, venkatesh g <
>>>>>>>>>> Hi again,
>>>>>>>>>> I have installed the Petsc and Slepc in Cray with intel compilers
>>>>>>>>>> with Mumps.
>>>>>>>>>> I am getting this error when I solve eigenvalue problem with
>>>>>>>>>> large matrices: [201]PETSC ERROR: Error reported by MUMPS in numerical
>>>>>>>>>> factorization phase: Cannot allocate required memory 9632 megabytes
>>>>>>>>> It ran out of memory on the node.
>>>>>>>>>> Also it is again not scaling well for small matrices.
>>>>>>>>> MUMPS strong scaling for small matrices is not very good. Weak
>>>>>>>>> scaling is looking at big matrices.
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> Kindly let me know what to do.
>>>>>>>>>> cheers,
>>>>>>>>>> Venkatesh
>>>>>>>>>> On Tue, May 19, 2015 at 3:02 PM, Matthew Knepley <
>>>>>>>>>>> On Tue, May 19, 2015 at 1:04 AM, venkatesh g <
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> I have attached the log of the command which I gave in the
>>>>>>>>>>>> master node: make streams NPMAX=32
>>>>>>>>>>>> I dont know why it says 'It appears you have only 1 node'. But
>>>>>>>>>>>> other codes run in parallel with good scaling on 8 nodes.
>>>>>>>>>>> If you look at the STREAMS numbers, you can see that your system
>>>>>>>>>>> is only able to support about 2 cores with the
>>>>>>>>>>> available memory bandwidth. Thus for bandwidth constrained
>>>>>>>>>>> operations (almost everything in sparse linear algebra
>>>>>>>>>>> and solvers), your speedup will not be bigger than 2.
>>>>>>>>>>> Other codes may do well on this machine, but they would be
>>>>>>>>>>> compute constrained, using things like DGEMM.
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>      Matt
>>>>>>>>>>>> Kindly let me know.
>>>>>>>>>>>> Venkatesh
>>>>>>>>>>>> On Mon, May 18, 2015 at 11:21 PM, Barry Smith <
>>>>>>>>>>>> bsmith at mcs.anl.gov> wrote:
>>>>>>>>>>>>>    Run the streams benchmark on this system and send the
>>>>>>>>>>>>> results.
>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#computers
>>>>>>>>>>>>> > On May 18, 2015, at 11:14 AM, venkatesh g <
>>>>>>>>>>>>> > Hi,
>>>>>>>>>>>>> > I have emailed the mumps-user list.
>>>>>>>>>>>>> > Actually the cluster has 8 nodes with 16 cores, and other
>>>>>>>>>>>>> codes scale well.
>>>>>>>>>>>>> > I wanted to ask if this job takes much time, then if I
>>>>>>>>>>>>> submit on more cores, I have to increase the icntl(14).. which would again
>>>>>>>>>>>>> take long time.
>>>>>>>>>>>>> > So is there another way ?
>>>>>>>>>>>>> > cheers,
>>>>>>>>>>>>> > Venkatesh
>>>>>>>>>>>>> > On Mon, May 18, 2015 at 7:16 PM, Matthew Knepley <
>>>>>>>>>>>>> > On Mon, May 18, 2015 at 8:29 AM, venkatesh g <
>>>>>>>>>>>>> > Hi I have attached the performance logs for 2 jobs on
>>>>>>>>>>>>> different processors. I had to increase the workspace icntl(14) when I
>>>>>>>>>>>>> submit on more cores since it is failing with small value of icntl(14).
>>>>>>>>>>>>> > 1. performance_log1.txt is run on 8 cores (option given
>>>>>>>>>>>>> -mat_mumps_icntl_14 200)
>>>>>>>>>>>>> > 2. performance_log2.txt is run on 2 cores (option given
>>>>>>>>>>>>> -mat_mumps_icntl_14 85  )
>>>>>>>>>>>>> > 1) Your number of iterates increased from 7600 to 9600, but
>>>>>>>>>>>>> that is a relatively small effect
>>>>>>>>>>>>> > 2) MUMPS is just taking a lot longer to do forward/backward
>>>>>>>>>>>>> solve. You might try emailing
>>>>>>>>>>>>> > the list for them. However, I would bet that your system has
>>>>>>>>>>>>> enough bandwidth for 2 procs
>>>>>>>>>>>>> > and not much more.
>>>>>>>>>>>>> >   Thanks,
>>>>>>>>>>>>> >      Matt
>>>>>>>>>>>>> > Venkatesh
>>>>>>>>>>>>> > On Sun, May 17, 2015 at 6:13 PM, Matthew Knepley <
>>>>>>>>>>>>> > On Sun, May 17, 2015 at 1:38 AM, venkatesh g <
>>>>>>>>>>>>> > Hi, Thanks for the information. I now increased the
>>>>>>>>>>>>> workspace by adding '-mat_mumps_icntl_14 100'
>>>>>>>>>>>>> > It works. However, the problem is, if I submit in 1 core I
>>>>>>>>>>>>> get the answer in 200 secs, but with 4 cores and '-mat_mumps_icntl_14 100'
>>>>>>>>>>>>> it takes 3500secs.
>>>>>>>>>>>>> > Send the output of -log_summary for all performance queries.
>>>>>>>>>>>>> Otherwise we are just guessing.
>>>>>>>>>>>>> >     Matt
>>>>>>>>>>>>> > My command line is: 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2
>>>>>>>>>>>>> -eps_nev 1 -st_type sinvert -eps_max_it 5000 -st_ksp_type preonly
>>>>>>>>>>>>> -st_pc_type lu -st_pc_factor_mat_solver_package mumps -mat_mumps_icntl_14
>>>>>>>>>>>>> 100'
>>>>>>>>>>>>> > Kindly let me know.
>>>>>>>>>>>>> > Venkatesh
>>>>>>>>>>>>> > On Sat, May 16, 2015 at 7:10 PM, David Knezevic <
>>>>>>>>>>>>> david.knezevic at akselos.com> wrote:
>>>>>>>>>>>>> > On Sat, May 16, 2015 at 8:08 AM, venkatesh g <
>>>>>>>>>>>>> > Hi,
>>>>>>>>>>>>> > I am trying to solving AX=lambda BX eigenvalue problem.
>>>>>>>>>>>>> > A and B are of sizes 3600x3600
>>>>>>>>>>>>> > I run with this command :
>>>>>>>>>>>>> > 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1 -st_type
>>>>>>>>>>>>> sinvert -eps_max_it 5000 -st_ksp_type preonly -st_pc_type lu
>>>>>>>>>>>>> -st_pc_factor_mat_solver_package mumps'
>>>>>>>>>>>>> > I get this error: (I get result only when I give 1 or 2
>>>>>>>>>>>>> processors)
>>>>>>>>>>>>> > Reading COMPLEX matrices from binary files...
>>>>>>>>>>>>> > [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>> > [0]PETSC ERROR: Error in external library!
>>>>>>>>>>>>> > [0]PETSC ERROR: Error reported by MUMPS in numerical
>>>>>>>>>>>>> factorization phase: INFO(1)=-9, INFO(2)=2024
>>>>>>>>>>>>> > The MUMPS error types are described in Chapter 7 of the
>>>>>>>>>>>>> MUMPS manual. In this case you have INFO(1)=-9, which is explained in the
>>>>>>>>>>>>> manual as:
>>>>>>>>>>>>> > "–9 Main internal real/complex workarray S too small. If
>>>>>>>>>>>>> INFO(2) is positive, then the number of entries that are missing in S at
>>>>>>>>>>>>> the moment when the error is raised is available in INFO(2). If INFO(2) is
>>>>>>>>>>>>> negative, then its absolute value should be multiplied by 1 million. If an
>>>>>>>>>>>>> error –9 occurs, the user should increase the value of ICNTL(14) before
>>>>>>>>>>>>> calling the factorization (JOB=2) again, except if ICNTL(23) is provided,
>>>>>>>>>>>>> in which case ICNTL(23) should be increased."
>>>>>>>>>>>>> > This says that you should use ICTNL(14) to increase the
>>>>>>>>>>>>> working space size:
>>>>>>>>>>>>> > "ICNTL(14) is accessed by the host both during the analysis
>>>>>>>>>>>>> and the factorization phases. It corresponds to the percentage increase in
>>>>>>>>>>>>> the estimated working space. When significant extra fill-in is caused by
>>>>>>>>>>>>> numerical pivoting, increasing ICNTL(14) may help. Except in special cases,
>>>>>>>>>>>>> the default value is 20 (which corresponds to a 20 % increase)."
>>>>>>>>>>>>> > So, for example, you can avoid this error via the following
>>>>>>>>>>>>> command line argument to PETSc: "-mat_mumps_icntl_14 30", where 30
>>>>>>>>>>>>> indicates that we allow a 30% increase in the workspace instead of the
>>>>>>>>>>>>> default 20%.
>>>>>>>>>>>>> > David
>>>>>>>>>>>>> > What most experimenters take for granted before they begin
>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>> > -- Norbert Wiener
>>>>>>>>>>>>> > -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150525/853842d3/attachment-0001.html>
