[petsc-users] MUMPS error
venkatesh g
venkateshgk.j at gmail.com
Mon May 25 02:54:01 CDT 2015
Ok this will load the matrices in parallel correct ?
On Sun, May 24, 2015 at 7:36 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, May 24, 2015 at 8:57 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
>> I am using Matload option as in the ex7.c code given by the Slepc.
>> ierr = MatLoad(A,viewer);CHKERRQ(ierr);
>> There is no problem here right ? or any additional option is required for
>> very large matrices while running the eigensolver in parallel ?
> This will load the matrix from the viewer (presumably disk). There are no
> options for large matrices.
> Thanks,
> Matt
>> cheers,
>> Venkatesh
>> On Sat, May 23, 2015 at 5:43 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sat, May 23, 2015 at 7:09 AM, venkatesh g <venkateshgk.j at gmail.com>
>>> wrote:
>>>> Hi,
>>>> Thanks.
>>>> Per node it has 24 cores and each core has 4 GB RAM. And the job was
>>>> submitted in 10 nodes.
>>>> So, does it mean it requires 10G for one core ? or for 1 node ?
>>> The error message from MUMPS said that it tried to allocate 10G. We must
>>> assume each process
>>> tried to do the same thing. That means if you scheduled 24 processes on
>>> a node, it would try to
>>> allocate at least 240G, which is in excess of what you specify above.
>>> Note that this has nothing to do with PETSc. It is all in the
>>> documentation for that machine and its
>>> scheduling policy.
>>> Thanks,
>>> Matt
>>>> cheers,
>>>> Venkatesh
>>>> On Sat, May 23, 2015 at 5:17 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Sat, May 23, 2015 at 6:44 AM, venkatesh g <venkateshgk.j at gmail.com>
>>>>> wrote:
>>>>>> Hi,
>>>>>> The same eigenproblem runs with 120 GB RAM in a serial machine in
>>>>>> Matlab.
>>>>>> In Cray I fired with 240*4 GB RAM in parallel. So it has to go in
>>>>>> right ?
>>>>> I do not know how MUMPS allocates memory, but the message is
>>>>> unambiguous. Also,
>>>>> this is concerned with the memory available per node. Do you know how
>>>>> many processes
>>>>> per node were scheduled? The message below indicates that it was
>>>>> trying to allocate 10G
>>>>> for one process.
>>>>>> And for small matrices it is having negative scaling i.e 24 core is
>>>>>> running faster.
>>>>> Yes, for strong scaling you always get slowdown eventually since
>>>>> overheads dominate
>>>>> work, see Amdahl's Law.
>>>>> Thanks,
>>>>> Matt
>>>>>> I have attached the submission script.
>>>>>> Pls see.. Kindly let me know
>>>>>> cheers,
>>>>>> Venkatesh
>>>>>> On Sat, May 23, 2015 at 4:58 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Sat, May 23, 2015 at 2:39 AM, venkatesh g <
>>>>>>> venkateshgk.j at gmail.com> wrote:
>>>>>>>> Hi again,
>>>>>>>> I have installed the Petsc and Slepc in Cray with intel compilers
>>>>>>>> with Mumps.
>>>>>>>> I am getting this error when I solve eigenvalue problem with large
>>>>>>>> matrices: [201]PETSC ERROR: Error reported by MUMPS in numerical
>>>>>>>> factorization phase: Cannot allocate required memory 9632 megabytes
>>>>>>> It ran out of memory on the node.
>>>>>>>> Also it is again not scaling well for small matrices.
>>>>>>> MUMPS strong scaling for small matrices is not very good. Weak
>>>>>>> scaling is looking at big matrices.
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> Kindly let me know what to do.
>>>>>>>> cheers,
>>>>>>>> Venkatesh
>>>>>>>> On Tue, May 19, 2015 at 3:02 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Tue, May 19, 2015 at 1:04 AM, venkatesh g <
>>>>>>>>>> Hi,
>>>>>>>>>> I have attached the log of the command which I gave in the master
>>>>>>>>>> node: make streams NPMAX=32
>>>>>>>>>> I dont know why it says 'It appears you have only 1 node'. But
>>>>>>>>>> other codes run in parallel with good scaling on 8 nodes.
>>>>>>>>> If you look at the STREAMS numbers, you can see that your system
>>>>>>>>> is only able to support about 2 cores with the
>>>>>>>>> available memory bandwidth. Thus for bandwidth constrained
>>>>>>>>> operations (almost everything in sparse linear algebra
>>>>>>>>> and solvers), your speedup will not be bigger than 2.
>>>>>>>>> Other codes may do well on this machine, but they would be compute
>>>>>>>>> constrained, using things like DGEMM.
>>>>>>>>> Thanks,
>>>>>>>>> Matt
>>>>>>>>>> Kindly let me know.
>>>>>>>>>> Venkatesh
>>>>>>>>>> On Mon, May 18, 2015 at 11:21 PM, Barry Smith <bsmith at mcs.anl.gov
>>>>>>>>>> > wrote:
>>>>>>>>>>> Run the streams benchmark on this system and send the
>>>>>>>>>>> results.
>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#computers
>>>>>>>>>>> > On May 18, 2015, at 11:14 AM, venkatesh g <
>>>>>>>>>>> > Hi,
>>>>>>>>>>> > I have emailed the mumps-user list.
>>>>>>>>>>> > Actually the cluster has 8 nodes with 16 cores, and other
>>>>>>>>>>> codes scale well.
>>>>>>>>>>> > I wanted to ask if this job takes much time, then if I submit
>>>>>>>>>>> on more cores, I have to increase the icntl(14).. which would again take
>>>>>>>>>>> long time.
>>>>>>>>>>> > So is there another way ?
>>>>>>>>>>> > cheers,
>>>>>>>>>>> > Venkatesh
>>>>>>>>>>> > On Mon, May 18, 2015 at 7:16 PM, Matthew Knepley <
>>>>>>>>>>> > On Mon, May 18, 2015 at 8:29 AM, venkatesh g <
>>>>>>>>>>> > Hi I have attached the performance logs for 2 jobs on
>>>>>>>>>>> different processors. I had to increase the workspace icntl(14) when I
>>>>>>>>>>> submit on more cores since it is failing with small value of icntl(14).
>>>>>>>>>>> > 1. performance_log1.txt is run on 8 cores (option given
>>>>>>>>>>> -mat_mumps_icntl_14 200)
>>>>>>>>>>> > 2. performance_log2.txt is run on 2 cores (option given
>>>>>>>>>>> -mat_mumps_icntl_14 85 )
>>>>>>>>>>> > 1) Your number of iterates increased from 7600 to 9600, but
>>>>>>>>>>> that is a relatively small effect
>>>>>>>>>>> > 2) MUMPS is just taking a lot longer to do forward/backward
>>>>>>>>>>> solve. You might try emailing
>>>>>>>>>>> > the list for them. However, I would bet that your system has
>>>>>>>>>>> enough bandwidth for 2 procs
>>>>>>>>>>> > and not much more.
>>>>>>>>>>> > Thanks,
>>>>>>>>>>> > Matt
>>>>>>>>>>> > Venkatesh
>>>>>>>>>>> > On Sun, May 17, 2015 at 6:13 PM, Matthew Knepley <
>>>>>>>>>>> > On Sun, May 17, 2015 at 1:38 AM, venkatesh g <
>>>>>>>>>>> > Hi, Thanks for the information. I now increased the workspace
>>>>>>>>>>> by adding '-mat_mumps_icntl_14 100'
>>>>>>>>>>> > It works. However, the problem is, if I submit in 1 core I get
>>>>>>>>>>> the answer in 200 secs, but with 4 cores and '-mat_mumps_icntl_14 100' it
>>>>>>>>>>> takes 3500secs.
>>>>>>>>>>> > Send the output of -log_summary for all performance queries.
>>>>>>>>>>> Otherwise we are just guessing.
>>>>>>>>>>> > Matt
>>>>>>>>>>> > My command line is: 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2
>>>>>>>>>>> -eps_nev 1 -st_type sinvert -eps_max_it 5000 -st_ksp_type preonly
>>>>>>>>>>> -st_pc_type lu -st_pc_factor_mat_solver_package mumps -mat_mumps_icntl_14
>>>>>>>>>>> 100'
>>>>>>>>>>> > Kindly let me know.
>>>>>>>>>>> > Venkatesh
>>>>>>>>>>> > On Sat, May 16, 2015 at 7:10 PM, David Knezevic <
>>>>>>>>>>> david.knezevic at akselos.com> wrote:
>>>>>>>>>>> > On Sat, May 16, 2015 at 8:08 AM, venkatesh g <
>>>>>>>>>>> > Hi,
>>>>>>>>>>> > I am trying to solving AX=lambda BX eigenvalue problem.
>>>>>>>>>>> > A and B are of sizes 3600x3600
>>>>>>>>>>> > I run with this command :
>>>>>>>>>>> > 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1 -st_type sinvert
>>>>>>>>>>> -eps_max_it 5000 -st_ksp_type preonly -st_pc_type lu
>>>>>>>>>>> -st_pc_factor_mat_solver_package mumps'
>>>>>>>>>>> > I get this error: (I get result only when I give 1 or 2
>>>>>>>>>>> processors)
>>>>>>>>>>> > Reading COMPLEX matrices from binary files...
>>>>>>>>>>> > [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>> > [0]PETSC ERROR: Error in external library!
>>>>>>>>>>> > [0]PETSC ERROR: Error reported by MUMPS in numerical
>>>>>>>>>>> factorization phase: INFO(1)=-9, INFO(2)=2024
>>>>>>>>>>> > The MUMPS error types are described in Chapter 7 of the MUMPS
>>>>>>>>>>> manual. In this case you have INFO(1)=-9, which is explained in the manual
>>>>>>>>>>> as:
>>>>>>>>>>> > "–9 Main internal real/complex workarray S too small. If
>>>>>>>>>>> INFO(2) is positive, then the number of entries that are missing in S at
>>>>>>>>>>> the moment when the error is raised is available in INFO(2). If INFO(2) is
>>>>>>>>>>> negative, then its absolute value should be multiplied by 1 million. If an
>>>>>>>>>>> error –9 occurs, the user should increase the value of ICNTL(14) before
>>>>>>>>>>> calling the factorization (JOB=2) again, except if ICNTL(23) is provided,
>>>>>>>>>>> in which case ICNTL(23) should be increased."
>>>>>>>>>>> > This says that you should use ICTNL(14) to increase the
>>>>>>>>>>> working space size:
>>>>>>>>>>> > "ICNTL(14) is accessed by the host both during the analysis
>>>>>>>>>>> and the factorization phases. It corresponds to the percentage increase in
>>>>>>>>>>> the estimated working space. When significant extra fill-in is caused by
>>>>>>>>>>> numerical pivoting, increasing ICNTL(14) may help. Except in special cases,
>>>>>>>>>>> the default value is 20 (which corresponds to a 20 % increase)."
>>>>>>>>>>> > So, for example, you can avoid this error via the following
>>>>>>>>>>> command line argument to PETSc: "-mat_mumps_icntl_14 30", where 30
>>>>>>>>>>> indicates that we allow a 30% increase in the workspace instead of the
>>>>>>>>>>> default 20%.
>>>>>>>>>>> > David
>>>>>>>>>>> > What most experimenters take for granted before they begin
>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>> their experiments lead.
>>>>>>>>>>> > -- Norbert Wiener
>>>>>>>>>>> > -- Norbert Wiener
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150525/4f2765bc/attachment-0001.html>
