[petsc-users] why we have a zero residual?
Matthew Knepley
knepley at gmail.com
Fri May 15 13:49:44 CDT 2015
On Fri, May 15, 2015 at 1:45 PM, Fande Kong <fande.kong at colorado.edu> wrote:
> Hi all,
> I was wondering why we will get a zero residual when solving the linear
> step of a nonlinear problem? I am solving a fluid-structure interaction
> problems using inexact Newton method, within which fGMRES is used together
> with a multilevel Schwarz preconditioner. The algorithm works well when the
> mesh is small, but it catched a zero residual issue when we turn to use a
> little bit large mesh. The output is listed as follows:
> 0 SNES Function norm 1.291775443677e-02
> Jacobian: rows 5575441 Column 5575441
> call DMGetInterpolation_SpmcsDMMesh
> Jacobian: rows 1298448 Column 1298448
> 0 KSP Residual norm 1.291775443677e-02
> 1 KSP Residual norm 0.000000000000e+00
> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 0
This looks like a mistake in the Jacobian or preconditioner, since you have
a 0 residual, but
a bad descent direction.
Matt
> Any suggestions? Thanks.
> Fande,
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150515/2eeb78c2/attachment.html>
