[petsc-users] why we have a zero residual?
Dmitry Karpeyev karpeev at mcs.anl.gov
Fri May 15 14:04:26 CDT 2015
What does -ksp_monitor_true_residual show?
On Fri, May 15, 2015 at 1:45 PM Fande Kong <fande.kong at colorado.edu> wrote:
> Hi all,
> I was wondering why we will get a zero residual when solving the linear
> step of a nonlinear problem? I am solving a fluid-structure interaction
> problems using inexact Newton method, within which fGMRES is used together
> with a multilevel Schwarz preconditioner. The algorithm works well when the
> mesh is small, but it catched a zero residual issue when we turn to use a
> little bit large mesh.  The output is listed as follows:
> 0 SNES Function norm 1.291775443677e-02
>   Jacobian: rows 5575441  Column 5575441
> call DMGetInterpolation_SpmcsDMMesh
>   Jacobian: rows 1298448  Column 1298448
>     0 KSP Residual norm 1.291775443677e-02
>     1 KSP Residual norm 0.000000000000e+00
> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 0
> Any suggestions? Thanks.
> Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150515/d007a871/attachment.html>
