[petsc-users] why we have a zero residual?
    Fande Kong
    fande.kong at colorado.edu
    Fri May 15 13:45:47 CDT 2015
Hi all,
I was wondering why we will get a zero residual when solving the linear
step of a nonlinear problem? I am solving a fluid-structure interaction
problems using inexact Newton method, within which fGMRES is used together
with a multilevel Schwarz preconditioner. The algorithm works well when the
mesh is small, but it catched a zero residual issue when we turn to use a
little bit large mesh.  The output is listed as follows:
0 SNES Function norm 1.291775443677e-02
  Jacobian: rows 5575441  Column 5575441
call DMGetInterpolation_SpmcsDMMesh
  Jacobian: rows 1298448  Column 1298448
    0 KSP Residual norm 1.291775443677e-02
    1 KSP Residual norm 0.000000000000e+00
Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 0
Any suggestions? Thanks.
Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150515/fa0af1c2/attachment.html>
