[petsc-users] Is matrix analysis available in PETSc or external package?
Danyang Su
danyang.su at gmail.com
Tue May 12 13:35:07 CDT 2015
On 15-05-11 07:19 PM, Hong wrote:
> Danyang:
> I recently have some time-dependent cases that have difficulty in
> convergence. It needs a lot of linear iterations during a specific
> time, e.g., more than 100 linear iterations for every newton
> iteration. In PETSc parallel version, this number will be doubled
> or even more. Our case usually needs less than 10 iterations for
> every newton iteration. This is NOT caused by PETSc relative
> routines as the original sequential solver (ILU) also has the same
> problem.
> The results seems reasonable, but the large number of iterations
> leads me to suspect that something is not well implemented in a
> particular module. This module is developed a long time ago by
> another guy and it sounds impossible for me to check every line
> (thousands of lines) and do theoretical analysis.Does PETSc or
> external package provide matrix analysis to help to locate the
> 'suspected' entry?
> We need know what solvers being used. My guess is the default
> gmres/bjacobi/ilu(0). Please run your code with option '-ts_view' or
> '-snes_view' to find out.
Hi Hong,
Sorry for the late reply. I guess there is nothing wrong in the solver
or data structure, but maybe some large entries in the linear system
that cause the problem hard to solve. I will export the matrix to check
these values.
Danyang
> Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150512/958f5071/attachment.html>
