[petsc-users] Is matrix analysis available in PETSc or external package?
Hong hzhang at mcs.anl.gov
Mon May 11 21:19:58 CDT 2015
Danyang:
> I recently have some time-dependent cases that have difficulty in
> convergence. It needs a lot of linear iterations during a specific time,
> e.g., more than 100 linear iterations for every newton iteration. In PETSc
> parallel version, this number will be doubled or even more. Our case
> usually needs less than 10 iterations for every newton iteration. This is
> NOT caused by PETSc relative routines as the original sequential solver
> (ILU) also has the same problem.
> The results seems reasonable, but the large number of iterations leads me
> to suspect that something is not well implemented in a particular module.
> This module is developed a long time ago by another guy and it sounds
> impossible for me to check every line (thousands of lines) and do
> theoretical analysis.Does PETSc or external package provide matrix analysis
> to help to locate the 'suspected' entry?
We need know what solvers being used. My guess is the default
gmres/bjacobi/ilu(0). Please run your code with option '-ts_view' or
'-snes_view' to find out.
Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150511/7fab54c9/attachment.html>
