[petsc-users] configure error on Titan with Intel
Mark Adams
mfadams at lbl.gov
Tue May 12 11:12:55 CDT 2015
> Notes: ./configure ran fine and detected -lhwloc in some standard system
> install location under normal circumstances it couldn't just disappear for
> a different example.
I configured in an interactive shell, so on a compute node. I tried to
'make ex56' on a login node, as usual. So I am guessing that it would have
worked if I had made it a compute node. They have an inconstancy, I'm
guessing. I can try it all on a compute node ....
> > On Fri, May 8, 2015 at 5:51 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Satish Balay <balay at mcs.anl.gov> writes:
> > > Also - Perhaps with intel compilers - the recommended blas is
> > > something other than ACML? [like MKL?]. Something to check..
> > MKL (and anything built using the Intel compiler) has the "run slower on
> > AMD" feature. For any given operation, ACML won't necessarily be
> > faster, but at least it's not intentionally crippled. For most of what
> > PETSc does, any such MKL/ACML difference is irrelevant.
> > <configure.log><make.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150512/98bf3020/attachment.html>
