[petsc-users] Is matrix analysis available in PETSc or external package?
Danyang Su danyang.su at gmail.com
Mon May 11 19:10:53 CDT 2015
Hi All,
I recently have some time-dependent cases that have difficulty in
convergence. It needs a lot of linear iterations during a specific time,
e.g., more than 100 linear iterations for every newton iteration. In
PETSc parallel version, this number will be doubled or even more. Our
case usually needs less than 10 iterations for every newton iteration.
This is NOT caused by PETSc relative routines as the original sequential
solver (ILU) also has the same problem.
The results seems reasonable, but the large number of iterations leads
me to suspect that something is not well implemented in a particular
module. This module is developed a long time ago by another guy and it
sounds impossible for me to check every line (thousands of lines) and do
theoretical analysis.Does PETSc or external package provide matrix
analysis to help to locate the 'suspected' entry?
Thanks and regards,
Danyang
