[petsc-users] configure error on Titan with Intel
Matthew Knepley
knepley at gmail.com
Mon May 11 19:39:12 CDT 2015
On Mon, May 11, 2015 at 7:35 PM, Mark Adams <mfadams at lbl.gov> wrote:
> I did a fresh build again. No luck. Is this how I turn it off?
> '--download-hwloc=0',
--with-hwloc=0
Matt
> On Mon, May 11, 2015 at 5:14 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, May 11, 2015 at 7:06 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> I think I did a super clean build... I will try again.
>> I did not look at the configure.log. If this is master, it should not
>> download hwloc automatically. If its not, turn it off.
>> Matt
>>> On Mon, May 11, 2015 at 5:04 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, May 11, 2015 at 6:55 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> More Titan fun. I have built for PGI on Titan but tests are failing
>>>>> to build: -lhwloc?
>>>>> cc -mp -fast -o ex56 ex56.o
>>>>> -L/autofs/na3_home1/adams/petsc_master_opt64idx_pgi/lib -lpetsc
>>>>> -Wl,-rpath,/opt/pgi/14.2.0/linux86/5.1/lib
>>>>> -L/opt/pgi/14.2.0/linux86/5.1/lib -llapack -lblas
>>>>> -Wl,-rpath,/autofs/na3_home1/adams/petsc_master_opt64idx_pgi/lib
>>>>> -L/autofs/na3_home1/adams/petsc_master_opt64idx_pgi/lib -lparmetis -lmetis
>>>>> -lhwloc -lssl -lcrypto -ldl -lstdc++
>>>>> /usr/bin/ld: cannot find -lhwloc
>>>>> make: [ex56] Error 2 (ignored)
>>>> Barry had hwloc autoinstalling, but then we talked him out of it. You
>>>> need to clean things out and build again, since it
>>>> thinks that it is still there.
>>>> Matt
>>>>> On Fri, May 8, 2015 at 5:51 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>>>> Satish Balay <balay at mcs.anl.gov> writes:
>>>>>> > Also - Perhaps with intel compilers - the recommended blas is
>>>>>> > something other than ACML? [like MKL?]. Something to check..
>>>>>> MKL (and anything built using the Intel compiler) has the "run slower
>>>>>> on
>>>>>> AMD" feature. For any given operation, ACML won't necessarily be
>>>>>> faster, but at least it's not intentionally crippled. For most of
>>>>>> what
>>>>>> PETSc does, any such MKL/ACML difference is irrelevant.
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150511/b608b24c/attachment.html>
