[petsc-users] configure error on Titan with Intel
Mark Adams mfadams at lbl.gov
Mon May 11 19:35:48 CDT 2015
I did a fresh build again. No luck.  Is this how I turn it off?
  '--download-hwloc=0',
On Mon, May 11, 2015 at 5:14 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, May 11, 2015 at 7:06 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> I think I did a super clean build...  I will try again.
> I did not look at the configure.log. If this is master, it should not
> download hwloc automatically. If its not, turn it off.
>    Matt
>> On Mon, May 11, 2015 at 5:04 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, May 11, 2015 at 6:55 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> More Titan fun.  I have built for PGI on Titan but tests are failing to
>>>> build: -lhwloc?
>>>> cc -mp -fast  -o ex56 ex56.o
>>>> -L/autofs/na3_home1/adams/petsc_master_opt64idx_pgi/lib  -lpetsc
>>>> -Wl,-rpath,/opt/pgi/14.2.0/linux86/5.1/lib
>>>> -L/opt/pgi/14.2.0/linux86/5.1/lib -llapack -lblas
>>>> -Wl,-rpath,/autofs/na3_home1/adams/petsc_master_opt64idx_pgi/lib
>>>> -L/autofs/na3_home1/adams/petsc_master_opt64idx_pgi/lib -lparmetis -lmetis
>>>> -lhwloc -lssl -lcrypto -ldl -lstdc++
>>>> /usr/bin/ld: cannot find -lhwloc
>>>> make: [ex56] Error 2 (ignored)
>>> Barry had hwloc autoinstalling, but then we talked him out of it. You
>>> need to clean things out and build again, since it
>>> thinks that it is still there.
>>>   Matt
>>>> On Fri, May 8, 2015 at 5:51 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>>> Satish Balay <balay at mcs.anl.gov> writes:
>>>>> > Also - Perhaps with intel compilers - the recommended blas is
>>>>> > something other than ACML? [like MKL?]. Something to check..
>>>>> MKL (and anything built using the Intel compiler) has the "run slower
>>>>> on
>>>>> AMD" feature.  For any given operation, ACML won't necessarily be
>>>>> faster, but at least it's not intentionally crippled.  For most of what
>>>>> PETSc does, any such MKL/ACML difference is irrelevant.
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150511/03c08187/attachment-0001.html>
