[petsc-users] configure error on Titan with Intel
Matthew Knepley
knepley at gmail.com
Mon May 11 19:14:58 CDT 2015
On Mon, May 11, 2015 at 7:06 PM, Mark Adams <mfadams at lbl.gov> wrote:
> I think I did a super clean build... I will try again.
I did not look at the configure.log. If this is master, it should not
download hwloc automatically. If its not, turn it off.
Matt
> On Mon, May 11, 2015 at 5:04 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, May 11, 2015 at 6:55 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> More Titan fun. I have built for PGI on Titan but tests are failing to
>>> build: -lhwloc?
>>> cc -mp -fast -o ex56 ex56.o
>>> -L/autofs/na3_home1/adams/petsc_master_opt64idx_pgi/lib -lpetsc
>>> -Wl,-rpath,/opt/pgi/14.2.0/linux86/5.1/lib
>>> -L/opt/pgi/14.2.0/linux86/5.1/lib -llapack -lblas
>>> -Wl,-rpath,/autofs/na3_home1/adams/petsc_master_opt64idx_pgi/lib
>>> -L/autofs/na3_home1/adams/petsc_master_opt64idx_pgi/lib -lparmetis -lmetis
>>> -lhwloc -lssl -lcrypto -ldl -lstdc++
>>> /usr/bin/ld: cannot find -lhwloc
>>> make: [ex56] Error 2 (ignored)
>> Barry had hwloc autoinstalling, but then we talked him out of it. You
>> need to clean things out and build again, since it
>> thinks that it is still there.
>> Matt
>>> On Fri, May 8, 2015 at 5:51 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>> Satish Balay <balay at mcs.anl.gov> writes:
>>>> > Also - Perhaps with intel compilers - the recommended blas is
>>>> > something other than ACML? [like MKL?]. Something to check..
>>>> MKL (and anything built using the Intel compiler) has the "run slower on
>>>> AMD" feature. For any given operation, ACML won't necessarily be
>>>> faster, but at least it's not intentionally crippled. For most of what
>>>> PETSc does, any such MKL/ACML difference is irrelevant.
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150511/f56fda30/attachment.html>
