[petsc-users] configure error on Titan with Intel
Mark Adams mfadams at lbl.gov
Mon May 11 19:06:27 CDT 2015
I think I did a super clean build...  I will try again.
On Mon, May 11, 2015 at 5:04 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, May 11, 2015 at 6:55 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> More Titan fun.  I have built for PGI on Titan but tests are failing to
>> build: -lhwloc?
>> cc -mp -fast  -o ex56 ex56.o
>> -L/autofs/na3_home1/adams/petsc_master_opt64idx_pgi/lib  -lpetsc
>> -Wl,-rpath,/opt/pgi/14.2.0/linux86/5.1/lib
>> -L/opt/pgi/14.2.0/linux86/5.1/lib -llapack -lblas
>> -Wl,-rpath,/autofs/na3_home1/adams/petsc_master_opt64idx_pgi/lib
>> -L/autofs/na3_home1/adams/petsc_master_opt64idx_pgi/lib -lparmetis -lmetis
>> -lhwloc -lssl -lcrypto -ldl -lstdc++
>> /usr/bin/ld: cannot find -lhwloc
>> make: [ex56] Error 2 (ignored)
> Barry had hwloc autoinstalling, but then we talked him out of it. You need
> to clean things out and build again, since it
> thinks that it is still there.
>   Matt
>> On Fri, May 8, 2015 at 5:51 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Satish Balay <balay at mcs.anl.gov> writes:
>>> > Also - Perhaps with intel compilers - the recommended blas is
>>> > something other than ACML? [like MKL?]. Something to check..
>>> MKL (and anything built using the Intel compiler) has the "run slower on
>>> AMD" feature.  For any given operation, ACML won't necessarily be
>>> faster, but at least it's not intentionally crippled.  For most of what
>>> PETSc does, any such MKL/ACML difference is irrelevant.
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150511/121f98cd/attachment.html>
