[petsc-users] TS without an RHSJacobian
Gideon Simpson gideon.simpson at gmail.com
Sun May 10 11:26:55 CDT 2015
What happens if I use TS for a nonlinear problem without specifying the RHSJacobian?  There’s some mention in the manual that if you’re working with a problem built on a da, it will use finite differences to approximate it, but I found the language a bit ambiguous.  Could someone elaborate?
-gideon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150510/7085e793/attachment.html>
