[petsc-users] TS without an RHSJacobian
Sun May 10 11:29:35 CDT 2015
On Sun, May 10, 2015 at 11:26 AM, Gideon Simpson <gideon.simpson at gmail.com>
wrote:
> What happens if I use TS for a nonlinear problem without specifying the
> RHSJacobian?  There’s some mention in the manual that if you’re working
> with a problem built on a da, it will use finite differences to approximate
> it, but I found the language a bit ambiguous.  Could someone elaborate?
It should use finite differences and coloring to make the Jacobian.
However, I have not checked whether its actually implemented.
If not, we will do it. I know I put it into IJacobian().
   Matt
> -gideon
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150510/f514876a/attachment.html>
