[petsc-users] MatSetValue - Faster if guaranteed local processor?
Satish Balay
balay at mcs.anl.gov
Fri May 8 16:33:41 CDT 2015
On Fri, 8 May 2015, Jed Brown wrote:
> Ganesh Vijayakumar <ganesh.iitm at gmail.com> writes:
> > Hello,
> > Is there any way I can get MatSetValue to run faster if I can guarantee
> > that the entries are local to that processor?
> Use MatSetValuesBlocked if relevant. Determining on/off process is not
> a bottleneck. Profile carefully before assuming where the time is
> spent.
The assembly will be most efficient if:
1. preallocation is done correctly
2. most/all entries are local
3. If you can insert values in blocks [and if the block has multiple
colum values - then the col indices are in sorted accending order]
Satish
