[petsc-users] (no subject)
Reza Yaghmaie reza.yaghmaie2 at gmail.com
Mon May 4 17:57:33 CDT 2015
Dear Matt,
The initial guess was zero for all cases of SNES solvers. The initial
jacobian was identity for all cases. The system is small and is ran
sequentially.
I have to add that I use FDColoring routine for the jacobian as well.
Ray
On Monday, May 4, 2015, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, May 4, 2015 at 5:41 PM, Reza Yaghmaie <reza.yaghmaie2 at gmail.com
> <javascript:_e(%7B%7D,'cvml','reza.yaghmaie2 at gmail.com');>> wrote:
>> Dear Matt,
>> Actually the initial jacobian was identity. Regular SNES converges in 48
>> iterations, GMRES in 19, NCG in 67,...
>> Do you think SNESQN with the basiclineseach was the problem for
>> divergence?
>> If I use SNESQN by default should not it converge with initial identity
>> jacobian?
> Do you mean that you used an initial guess of the identity, or that the
> Actual Jacobian was the identity at your
> initial guess?
>   Matt
>> Best regards,
>> Reza
>> <javascript:_e(%7B%7D,'cvml','knepley at gmail.com');>> wrote:
>>> On Mon, May 4, 2015 at 2:11 PM, Reza Yaghmaie <reza.yaghmaie2 at gmail.com>
>>> wrote:
>>>> Dear PETSC representatives,
>>>> I am solving a nonlinear problem with SNESNGMRES and it converges
>>>> faster with less iterations compared to otehr SNES methods. Any idea why
>>>> that is the case?
>>> It is impossible to tell with this information.
>>>> Also SNESQN diverges quickly. I tried to use SNESLINESEARCHBASIC for
>>>> the linesearch option and nothing changes.
>>> This can happen, especially if your matrix is far from the identity.
>>>> I presume it is using the default SNESQN method. Btw, there are three
>>>> options for QN, as "SNES_QN_LBFGS, SNES_QN_BROYDEN, SNES_QN_BADBROYEN"
>>>> in teh manual. I tried to associate them with SNES however it seems these
>>>> hyphened names don't work there. What am I missing?
>>> -snes_qn_scale_type <lbfgs,broyden,badbroyden>
>>> from
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESQNSetType.html
>>>    Thanks,
>>>     Matt
>>> Best regards,
>>>> Ray
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150504/4d233845/attachment.html>
