[petsc-users] (no subject)
Mon May 4 17:53:19 CDT 2015
On Mon, May 4, 2015 at 5:41 PM, Reza Yaghmaie <reza.yaghmaie2 at gmail.com>
wrote:
> Dear Matt,
> Actually the initial jacobian was identity. Regular SNES converges in 48
> iterations, GMRES in 19, NCG in 67,...
> Do you think SNESQN with the basiclineseach was the problem for divergence?
> If I use SNESQN by default should not it converge with initial identity
> jacobian?
Do you mean that you used an initial guess of the identity, or that the
Actual Jacobian was the identity at your
initial guess?
  Matt
> Best regards,
> Reza
> On Monday, May 4, 2015, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, May 4, 2015 at 2:11 PM, Reza Yaghmaie <reza.yaghmaie2 at gmail.com>
>> wrote:
>>> Dear PETSC representatives,
>>> I am solving a nonlinear problem with SNESNGMRES and it converges faster
>>> with less iterations compared to otehr SNES methods. Any idea why that is
>>> the case?
>> It is impossible to tell with this information.
>>> Also SNESQN diverges quickly. I tried to use SNESLINESEARCHBASIC for
>>> the linesearch option and nothing changes.
>> This can happen, especially if your matrix is far from the identity.
>>> I presume it is using the default SNESQN method. Btw, there are three
>>> options for QN, as "SNES_QN_LBFGS, SNES_QN_BROYDEN, SNES_QN_BADBROYEN"
>>> in teh manual. I tried to associate them with SNES however it seems these
>>> hyphened names don't work there. What am I missing?
>> -snes_qn_scale_type <lbfgs,broyden,badbroyden>
>> from
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESQNSetType.html
>>    Thanks,
>>     Matt
>> Best regards,
>>> Ray
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150504/b2fbb12a/attachment.html>
