[petsc-users] Problem with MPI, MatAXPY and SAME_NONZERO_PATTERN
Klaus Kaiser kaiser at igpm.rwth-aachen.de
Mon Mar 30 05:18:39 CDT 2015
Hallo Metthew,
at the weekend I updated petsc to the newest release version 3.5.2 and I
still got this strange behavior.
Best
Klaus
On 03/27/2015 05:07 PM, Klaus Kaiser wrote:
> Hallo Matthew,
> here is a short example I used for 8 cores:
>     int d_nnz[3];
>     int o_nnz[3];
>     d_nnz[0] = 3; d_nnz[1] = 3; d_nnz[2] = 3;
>     o_nnz[0] = 6; o_nnz[1] = 6; o_nnz[2] = 6;
>     ierr = MatCreateBAIJ(PETSC_COMM_WORLD, 3, 9, 9, 72, 72, 0, d_nnz,
> 0, o_nnz,&A);
>     ierr = MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>     ierr = MatSetOption(A,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>     ierr = MatSetOption(A,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
> 0, o_nnz,&Ah);
> 0, o_nnz,&At);
>     std::vector<double> insert(3*3*3*3, 1.0);
>     for(int i=0;i<8;++i)
>         int rows[3] = {i,i+1,i+3};
>         int cols[3] = {i,i+1,i+3};
>         MatSetValuesBlocked(A, 3, rows, 3, cols, &insert[0], ADD_VALUES);
>     MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
>     MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
>     MatDuplicate(A,MAT_COPY_VALUES,&Ah);
>     MatDuplicate(A,MAT_COPY_VALUES,&At);
>     MatAssemblyBegin(Ah,MAT_FINAL_ASSEMBLY);
>     MatAssemblyEnd(Ah,MAT_FINAL_ASSEMBLY);
>     MatAssemblyBegin(At,MAT_FINAL_ASSEMBLY);
>     MatAssemblyEnd(At,MAT_FINAL_ASSEMBLY);
>     MatAXPY(Ah,1.,At,SAME_NONZERO_PATTERN);
>     MatAXPY(A,1.,Ah,SAME_NONZERO_PATTERN);
> The result is, that only some values are computed correctly.
> Best and Thank you a lot
> Klaus
> On 03/27/2015 04:26 PM, Matthew Knepley wrote:
>> On Fri, Mar 27, 2015 at 10:16 AM, Klaus Kaiser
>> <kaiser at igpm.rwth-aachen.de <mailto:kaiser at igpm.rwth-aachen.de>> wrote:
>>     Hallo Matthew,
>>     thanks for your fast response. With "no beside the nonzero
>>     structure" I meant, that I do not create a different non-zero
>>     structure while I'm adding values to my matrices.
>>     I also tried MAT_COPY_VALUES and the result was the same.
>> Please send the small example and we will figure out what is going wrong.
>>   Thanks,
>>      Matt
>>     I do not get a error message but the resulting matrix is wrong.
>>     Here I have a short example. The first 9 rows and first 3 colomn
>>     of the matrices Ah, At and Ah+At on the first processor (of 8):
>>     Ah:
>>     0:                   60.3553 -0.249975              2.77556e-17
>>     1:                         0 60.3553                        0
>>     2:                         0 0                  60.3553
>>     3:                   17.6777 0.374962                 0.124987
>>     4:                         0 17.6777                        0
>>     5:                         0 0                  17.6777
>>     6:                  -7.32233 -0.124987                 0.374962
>>     7:                         0 -7.32233                        0
>>     8:                         0 0                 -7.32233
>>     At:
>>     0:                         0 0                        0
>>     1:                      2500 0                        0
>>     2:              -4.54747e-13 0                        0
>>     3:                         0 0                        0
>>     4:                      1250 0                        0
>>     5:                      1250 0                        0
>>     6:                         0 0                        0
>>     7:                      1250 0                        0
>>     8:                      3750 0                        0
>>     Ah+At
>>     1:                      2500 60.3553                        0
>>     2:              -4.54747e-13 0                  60.3553
>>     4:                         0 17.6777                        0
>>     5:                         0 0                  17.6777
>>     7:                         0 -7.32233                        0
>>     8:                         0 0                 -7.32233
>>     you can see the first 3 rows of the resulting matrix looks
>>     exactly like what I would expect, but the last 6 rows only
>>     consists of the values of Ah. When you would also look on the
>>     matrix A and A+Ah+At you would also see, that values where both
>>     matrices have an nonzero entry are not sum correctly.
>>     Best
>>     Klaus
>>     On 03/27/2015 03:59 PM, Matthew Knepley wrote:
>>>     On Fri, Mar 27, 2015 at 9:48 AM, Klaus Kaiser
>>>     wrote:
>>>         Hallo,
>>>         I have a strange behavior in my code concerning the function
>>>         MatAXPY. I create 3 different Matrices
>>>             ierr = MatCreateBAIJ(PETSC_COMM_WORLD, block_size,
>>>         local_size, local_size, system_size, system_size, 0, d_nnz,
>>>         0, o_nnz,&A);
>>>             ierr =
>>>             ierr =
>>>         0, o_nnz,&At);
>>>             ierr =
>>>         MatSetOption(At,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>>>             ierr = MatSetOption(At,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>>>             ierr =
>>>         MatSetOption(At,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>>>         0, o_nnz,&Ah);
>>>             ierr =
>>>         MatSetOption(Ah,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>>>             ierr = MatSetOption(Ah,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>>>             ierr =
>>>         MatSetOption(Ah,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>>>     These creations are superfluous since you use MatDuplicate() below.
>>>         and want to sum these three matrixes with different factors.
>>>         First I fill the Matrix A with some values, and duplicate
>>>         the structure of A to the other two matrices:
>>>         MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&Ah);
>>>         MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&At);
>>>         After this I fill the matrices At and Ah with some other
>>>         values, which are not beside the non zero structure (I also
>>>         tried with just copying the Matrix A). Now after another
>>>         MatAssembly
>>>     I do not understand "no beside the nonzero structure". Do you
>>>     mean that the nonzero structure is the same?
>>>     Can you first test with MAT_COPY_VALUES?
>>>         I want to add these Matrices in the form A+c*(Ah+d*At):
>>>             MatAXPY(Ah,c,At,SAME_NONZERO_PATTERN);
>>>             MatAXPY(A,d,Ah,SAME_NONZERO_PATTERN);
>>>         When I run the method with mpi and one core everything works
>>>         fine. Starting the same method with more cores, the sum of
>>>         the matrices fails. It seems like some values are added
>>>     Please send the full output of a failure when you use
>>>     MAT_COPY_VALUES on 2 procs.
>>>       Thanks,
>>>          Matt
>>>         correctly and many values are missed. Using
>>>         DIFFERENT_NONZERO_STRUCTURE leads to the right behavior in
>>>         the multi-core case, but is very slow. I checked with a
>>>         viewer if all matrices have the same nonzero structure and
>>>         this is the case.
>>>         Does anyone know why this fails, or do I have made any wrong
>>>         thoughts?
>>>         I'm corrently working with a petsc version (Petsc Release
>>>         Version 3.3.0, Patch 5, Sat Dec  1 15:10:41 CST 2012), I
>>>         looked into the changelogs up to the current version and did
>>>         not find any note about MatAXPY or MatAYPX.
>>>         Best and Thanks a lot for your help
>>>         Klaus
>>>     What most experimenters take for granted before they begin their
>>>     experiments is infinitely more interesting than any results to
>>>     which their experiments lead.
>>>     -- Norbert Wiener
>> experiments is infinitely more interesting than any results to which
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150330/2b1bdd78/attachment.html>
