[petsc-users] Problem with MPI, MatAXPY and SAME_NONZERO_PATTERN
Klaus Kaiser
kaiser at igpm.rwth-aachen.de
Fri Mar 27 11:07:55 CDT 2015
Hallo Matthew,
here is a short example I used for 8 cores:
int d_nnz[3];
int o_nnz[3];
d_nnz[0] = 3; d_nnz[1] = 3; d_nnz[2] = 3;
o_nnz[0] = 6; o_nnz[1] = 6; o_nnz[2] = 6;
ierr = MatCreateBAIJ(PETSC_COMM_WORLD, 3, 9, 9, 72, 72, 0, d_nnz,
0, o_nnz,&A);
ierr = MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
ierr = MatSetOption(A,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
ierr = MatSetOption(A,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
0, o_nnz,&Ah);
0, o_nnz,&At);
std::vector<double> insert(3*3*3*3, 1.0);
for(int i=0;i<8;++i)
int rows[3] = {i,i+1,i+3};
int cols[3] = {i,i+1,i+3};
MatSetValuesBlocked(A, 3, rows, 3, cols, &insert[0], ADD_VALUES);
MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
MatDuplicate(A,MAT_COPY_VALUES,&Ah);
MatDuplicate(A,MAT_COPY_VALUES,&At);
MatAssemblyBegin(Ah,MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(Ah,MAT_FINAL_ASSEMBLY);
MatAssemblyBegin(At,MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(At,MAT_FINAL_ASSEMBLY);
MatAXPY(Ah,1.,At,SAME_NONZERO_PATTERN);
MatAXPY(A,1.,Ah,SAME_NONZERO_PATTERN);
The result is, that only some values are computed correctly.
Best and Thank you a lot
Klaus
On 03/27/2015 04:26 PM, Matthew Knepley wrote:
> On Fri, Mar 27, 2015 at 10:16 AM, Klaus Kaiser
> <kaiser at igpm.rwth-aachen.de <mailto:kaiser at igpm.rwth-aachen.de>> wrote:
> Hallo Matthew,
> thanks for your fast response. With "no beside the nonzero
> structure" I meant, that I do not create a different non-zero
> structure while I'm adding values to my matrices.
> I also tried MAT_COPY_VALUES and the result was the same.
> Please send the small example and we will figure out what is going wrong.
> Thanks,
> Matt
> I do not get a error message but the resulting matrix is wrong.
> Here I have a short example. The first 9 rows and first 3 colomn
> of the matrices Ah, At and Ah+At on the first processor (of 8):
> Ah:
> 0: 60.3553 -0.249975 2.77556e-17
> 1: 0 60.3553 0
> 2: 0 0 60.3553
> 3: 17.6777 0.374962 0.124987
> 4: 0 17.6777 0
> 5: 0 0 17.6777
> 6: -7.32233 -0.124987 0.374962
> 7: 0 -7.32233 0
> 8: 0 0 -7.32233
> At:
> 0: 0 0 0
> 1: 2500 0 0
> 2: -4.54747e-13 0 0
> 3: 0 0 0
> 4: 1250 0 0
> 5: 1250 0 0
> 6: 0 0 0
> 7: 1250 0 0
> 8: 3750 0 0
> Ah+At
> 1: 2500 60.3553 0
> 2: -4.54747e-13 0 60.3553
> 4: 0 17.6777 0
> 5: 0 0 17.6777
> 7: 0 -7.32233 0
> 8: 0 0 -7.32233
> you can see the first 3 rows of the resulting matrix looks exactly
> like what I would expect, but the last 6 rows only consists of the
> values of Ah. When you would also look on the matrix A and A+Ah+At
> you would also see, that values where both matrices have an
> nonzero entry are not sum correctly.
> Best
> Klaus
> On 03/27/2015 03:59 PM, Matthew Knepley wrote:
>> On Fri, Mar 27, 2015 at 9:48 AM, Klaus Kaiser
>> wrote:
>> Hallo,
>> I have a strange behavior in my code concerning the function
>> MatAXPY. I create 3 different Matrices
>> ierr = MatCreateBAIJ(PETSC_COMM_WORLD, block_size,
>> local_size, local_size, system_size, system_size, 0, d_nnz,
>> 0, o_nnz,&A);
>> ierr =
>> ierr =
>> 0, o_nnz,&At);
>> ierr =
>> MatSetOption(At,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>> ierr = MatSetOption(At,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>> ierr =
>> MatSetOption(At,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>> 0, o_nnz,&Ah);
>> ierr =
>> MatSetOption(Ah,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>> ierr = MatSetOption(Ah,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>> ierr =
>> MatSetOption(Ah,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>> These creations are superfluous since you use MatDuplicate() below.
>> and want to sum these three matrixes with different factors.
>> First I fill the Matrix A with some values, and duplicate the
>> structure of A to the other two matrices:
>> MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&Ah);
>> MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&At);
>> After this I fill the matrices At and Ah with some other
>> values, which are not beside the non zero structure (I also
>> tried with just copying the Matrix A). Now after another
>> MatAssembly
>> I do not understand "no beside the nonzero structure". Do you
>> mean that the nonzero structure is the same?
>> Can you first test with MAT_COPY_VALUES?
>> I want to add these Matrices in the form A+c*(Ah+d*At):
>> MatAXPY(Ah,c,At,SAME_NONZERO_PATTERN);
>> MatAXPY(A,d,Ah,SAME_NONZERO_PATTERN);
>> When I run the method with mpi and one core everything works
>> fine. Starting the same method with more cores, the sum of
>> the matrices fails. It seems like some values are added
>> Please send the full output of a failure when you use
>> MAT_COPY_VALUES on 2 procs.
>> Thanks,
>> Matt
>> correctly and many values are missed. Using
>> DIFFERENT_NONZERO_STRUCTURE leads to the right behavior in
>> the multi-core case, but is very slow. I checked with a
>> viewer if all matrices have the same nonzero structure and
>> this is the case.
>> Does anyone know why this fails, or do I have made any wrong
>> thoughts?
>> I'm corrently working with a petsc version (Petsc Release
>> Version 3.3.0, Patch 5, Sat Dec 1 15:10:41 CST 2012), I
>> looked into the changelogs up to the current version and did
>> not find any note about MatAXPY or MatAYPX.
>> Best and Thanks a lot for your help
>> Klaus
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150327/fb4027e6/attachment-0001.html>
