[petsc-users] Problem with MPI, MatAXPY and SAME_NONZERO_PATTERN
    Matthew Knepley
    knepley at gmail.com
    Mon Mar 30 06:43:30 CDT 2015
On Mon, Mar 30, 2015 at 5:18 AM, Klaus Kaiser <kaiser at igpm.rwth-aachen.de>
wrote:
>  Hallo Metthew,
> at the weekend I updated petsc to the newest release version 3.5.2 and I
> still got this strange behavior.
Okay, I will check it out. The first thing I am going to do is try with AIJ
matrices instead of BAIJ, which
you can probably do before me. If you get the right result, then its a bug
in the BAIJ implementation,
which I am confident has not been tested as thoroughly.
     Matt
> Best
> Klaus
> On 03/27/2015 05:07 PM, Klaus Kaiser wrote:
> Hallo Matthew,
> here is a short example I used for 8 cores:
>     int d_nnz[3];
>     int o_nnz[3];
>     d_nnz[0] = 3; d_nnz[1] = 3; d_nnz[2] = 3;
>     o_nnz[0] = 6; o_nnz[1] = 6; o_nnz[2] = 6;
>     ierr = MatCreateBAIJ(PETSC_COMM_WORLD, 3, 9, 9, 72, 72, 0, d_nnz, 0,
> o_nnz,&A);
>     ierr = MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>     ierr = MatSetOption(A,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>     ierr = MatSetOption(A,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
> o_nnz,&Ah);
> o_nnz,&At);
>     std::vector<double> insert(3*3*3*3, 1.0);
>     for(int i=0;i<8;++i)
>         int rows[3] = {i,i+1,i+3};
>         int cols[3] = {i,i+1,i+3};
>         MatSetValuesBlocked(A, 3, rows, 3, cols, &insert[0], ADD_VALUES);
>     MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
>     MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
>     MatDuplicate(A,MAT_COPY_VALUES,&Ah);
>     MatDuplicate(A,MAT_COPY_VALUES,&At);
>     MatAssemblyBegin(Ah,MAT_FINAL_ASSEMBLY);
>     MatAssemblyEnd(Ah,MAT_FINAL_ASSEMBLY);
>     MatAssemblyBegin(At,MAT_FINAL_ASSEMBLY);
>     MatAssemblyEnd(At,MAT_FINAL_ASSEMBLY);
>     MatAXPY(Ah,1.,At,SAME_NONZERO_PATTERN);
>     MatAXPY(A,1.,Ah,SAME_NONZERO_PATTERN);
> The result is, that only some values are computed correctly.
> Best and Thank you a lot
> Klaus
> On 03/27/2015 04:26 PM, Matthew Knepley wrote:
>  On Fri, Mar 27, 2015 at 10:16 AM, Klaus Kaiser <
> kaiser at igpm.rwth-aachen.de> wrote:
>>  Hallo Matthew,
>> thanks for your fast response. With "no beside the nonzero structure" I
>> meant, that I do not create a different non-zero structure while I'm adding
>> values to my matrices.
>> I also tried MAT_COPY_VALUES and the result was the same.
>  Please send the small example and we will figure out what is going wrong.
>    Thanks,
>       Matt
>>  I do not get a error message but the resulting matrix is wrong. Here I
>> have a short example. The first 9 rows and first 3 colomn of the matrices
>> Ah, At and Ah+At on the first processor (of 8):
>> Ah:
>> 0:                   60.3553                -0.249975
>> 2.77556e-17
>> 1:                         0
>> 60.3553                        0
>> 2:                         0                        0
>> 60.3553
>> 3:                   17.6777                 0.374962
>> 0.124987
>> 4:                         0
>> 17.6777                        0
>> 5:                         0                        0
>> 17.6777
>> 6:                  -7.32233                -0.124987
>> 0.374962
>> 7:                         0
>> -7.32233                        0
>> 8:                         0                        0
>> -7.32233
>> At:
>> 0:                         0
>> 0                        0
>> 1:                      2500
>> 0                        0
>> 2:              -4.54747e-13
>> 0                        0
>> 3:                         0
>> 0                        0
>> 4:                      1250
>> 0                        0
>> 5:                      1250
>> 0                        0
>> 6:                         0
>> 0                        0
>> 7:                      1250
>> 0                        0
>> 8:                      3750
>> 0                        0
>> Ah+At
>> 2.77556e-17
>> 1:                      2500
>> 60.3553                        0
>> 2:              -4.54747e-13                        0
>> 60.3553
>> 3:                   17.6777                 0.374962
>> 0.124987
>> 4:                         0
>> 17.6777                        0
>> 5:                         0                        0
>> 17.6777
>> 0.374962
>> 7:                         0
>> -7.32233                        0
>> 8:                         0                        0
>> -7.32233
>> you can see the first 3 rows of the resulting matrix looks exactly like
>> what I would expect, but the last 6 rows only consists of the values of Ah.
>> When you would also look on the matrix A and A+Ah+At you would also see,
>> that values where both matrices have an nonzero entry are not sum correctly.
>> Best
>> Klaus
>> On 03/27/2015 03:59 PM, Matthew Knepley wrote:
>>  On Fri, Mar 27, 2015 at 9:48 AM, Klaus Kaiser <
>>> Hallo,
>>> I have a strange behavior in my code concerning the function MatAXPY. I
>>> create 3 different Matrices
>>>     ierr = MatCreateBAIJ(PETSC_COMM_WORLD, block_size, local_size,
>>> local_size, system_size, system_size, 0, d_nnz, 0, o_nnz,&A);
>>> local_size, system_size, system_size, 0, d_nnz, 0, o_nnz,&At);
>>>     ierr = MatSetOption(At,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>>>     ierr = MatSetOption(At,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>>>     ierr = MatSetOption(At,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>>> local_size, system_size, system_size, 0, d_nnz, 0, o_nnz,&Ah);
>>>     ierr = MatSetOption(Ah,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>>>     ierr = MatSetOption(Ah,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>>>     ierr = MatSetOption(Ah,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>>  These creations are superfluous since you use MatDuplicate() below.
>>> and want to sum these three matrixes with different factors. First I
>>> fill the Matrix A with some values, and duplicate the structure of A to the
>>> other two matrices:
>>>     MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&Ah);
>>>     MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&At);
>>> After this I fill the matrices At and Ah with some other values, which
>>> are not beside the non zero structure (I also tried with just copying the
>>> Matrix A). Now after another MatAssembly
>>  I do not understand "no beside the nonzero structure". Do you mean that
>> the nonzero structure is the same?
>>  Can you first test with MAT_COPY_VALUES?
>>> I want to add these Matrices in the form A+c*(Ah+d*At):
>>>     MatAXPY(Ah,c,At,SAME_NONZERO_PATTERN);
>>>     MatAXPY(A,d,Ah,SAME_NONZERO_PATTERN);
>>> When I run the method with mpi and one core everything works fine.
>>> Starting the same method with more cores, the sum of the matrices fails. It
>>> seems like some values are added
>>  Please send the full output of a failure when you use MAT_COPY_VALUES
>> on 2 procs.
>>    Thanks,
>>       Matt
>>> correctly and many values are missed. Using DIFFERENT_NONZERO_STRUCTURE
>>> leads to the right behavior in the multi-core case, but is very slow. I
>>> checked with a viewer if all matrices have the same nonzero structure and
>>> this is the case.
>>> Does anyone know why this fails, or do I have made any wrong thoughts?
>>> I'm corrently working with a petsc version (Petsc Release Version 3.3.0,
>>> Patch 5, Sat Dec  1 15:10:41 CST 2012), I looked into the changelogs up to
>>> the current version and did not find any note about MatAXPY or MatAYPX.
>>> Best and Thanks a lot for your help
>>> Klaus
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150330/873f72da/attachment-0001.html>
