[petsc-users] Problem with MPI, MatAXPY and SAME_NONZERO_PATTERN
    Matthew Knepley
    knepley at gmail.com
    Fri Mar 27 10:26:36 CDT 2015
On Fri, Mar 27, 2015 at 10:16 AM, Klaus Kaiser <kaiser at igpm.rwth-aachen.de>
wrote:
>  Hallo Matthew,
> thanks for your fast response. With "no beside the nonzero structure" I
> meant, that I do not create a different non-zero structure while I'm adding
> values to my matrices.
> I also tried MAT_COPY_VALUES and the result was the same.
Please send the small example and we will figure out what is going wrong.
     Matt
> I do not get a error message but the resulting matrix is wrong. Here I
> have a short example. The first 9 rows and first 3 colomn of the matrices
> Ah, At and Ah+At on the first processor (of 8):
> Ah:
> 0:                   60.3553                -0.249975
> 2.77556e-17
> 1:                         0
> 60.3553                        0
> 2:                         0                        0
> 60.3553
> 3:                   17.6777                 0.374962
> 0.124987
> 4:                         0
> 17.6777                        0
> 5:                         0                        0
> 17.6777
> 6:                  -7.32233                -0.124987
> 0.374962
> 7:                         0
> -7.32233                        0
> 8:                         0                        0
> -7.32233
> At:
> 0:                         0
> 0                        0
> 1:                      2500
> 0                        0
> 2:              -4.54747e-13
> 0                        0
> 3:                         0
> 0                        0
> 4:                      1250
> 0                        0
> 5:                      1250
> 0                        0
> 6:                         0
> 0                        0
> 7:                      1250
> 0                        0
> 8:                      3750
> 0                        0
> Ah+At
> 2.77556e-17
> 1:                      2500
> 60.3553                        0
> 2:              -4.54747e-13                        0
> 60.3553
> 3:                   17.6777                 0.374962
> 0.124987
> 4:                         0
> 17.6777                        0
> 5:                         0                        0
> 17.6777
> 0.374962
> 7:                         0
> -7.32233                        0
> 8:                         0                        0
> -7.32233
> you can see the first 3 rows of the resulting matrix looks exactly like
> what I would expect, but the last 6 rows only consists of the values of Ah.
> When you would also look on the matrix A and A+Ah+At you would also see,
> that values where both matrices have an nonzero entry are not sum correctly.
> Best
> Klaus
> On 03/27/2015 03:59 PM, Matthew Knepley wrote:
>  On Fri, Mar 27, 2015 at 9:48 AM, Klaus Kaiser <kaiser at igpm.rwth-aachen.de
> > wrote:
>> Hallo,
>> I have a strange behavior in my code concerning the function MatAXPY. I
>> create 3 different Matrices
>>     ierr = MatCreateBAIJ(PETSC_COMM_WORLD, block_size, local_size,
>> local_size, system_size, system_size, 0, d_nnz, 0, o_nnz,&A);
>>     ierr = MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>>     ierr = MatSetOption(A,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>>     ierr = MatSetOption(A,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>> local_size, system_size, system_size, 0, d_nnz, 0, o_nnz,&At);
>>     ierr = MatSetOption(At,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>>     ierr = MatSetOption(At,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>>     ierr = MatSetOption(At,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>> local_size, system_size, system_size, 0, d_nnz, 0, o_nnz,&Ah);
>>     ierr = MatSetOption(Ah,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>>     ierr = MatSetOption(Ah,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>>     ierr = MatSetOption(Ah,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>  These creations are superfluous since you use MatDuplicate() below.
>> and want to sum these three matrixes with different factors. First I fill
>> the Matrix A with some values, and duplicate the structure of A to the
>> other two matrices:
>>     MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
>>     MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
>>     MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&Ah);
>>     MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&At);
>>     MatAssemblyBegin(Ah,MAT_FINAL_ASSEMBLY);
>>     MatAssemblyEnd(Ah,MAT_FINAL_ASSEMBLY);
>>     MatAssemblyBegin(At,MAT_FINAL_ASSEMBLY);
>>     MatAssemblyEnd(At,MAT_FINAL_ASSEMBLY);
>> After this I fill the matrices At and Ah with some other values, which
>> are not beside the non zero structure (I also tried with just copying the
>> Matrix A). Now after another MatAssembly
>  I do not understand "no beside the nonzero structure". Do you mean that
> the nonzero structure is the same?
>  Can you first test with MAT_COPY_VALUES?
>> I want to add these Matrices in the form A+c*(Ah+d*At):
>>     MatAXPY(Ah,c,At,SAME_NONZERO_PATTERN);
>>     MatAXPY(A,d,Ah,SAME_NONZERO_PATTERN);
>> When I run the method with mpi and one core everything works fine.
>> Starting the same method with more cores, the sum of the matrices fails. It
>> seems like some values are added
>  Please send the full output of a failure when you use MAT_COPY_VALUES on
> 2 procs.
>    Thanks,
>       Matt
>> correctly and many values are missed. Using DIFFERENT_NONZERO_STRUCTURE
>> leads to the right behavior in the multi-core case, but is very slow. I
>> checked with a viewer if all matrices have the same nonzero structure and
>> this is the case.
>> Does anyone know why this fails, or do I have made any wrong thoughts?
>> I'm corrently working with a petsc version (Petsc Release Version 3.3.0,
>> Patch 5, Sat Dec  1 15:10:41 CST 2012), I looked into the changelogs up to
>> the current version and did not find any note about MatAXPY or MatAYPX.
>> Best and Thanks a lot for your help
>> Klaus
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150327/63a15bf7/attachment-0001.html>
