[petsc-users] SLEPc - Generalized symmetric eigenproblem using ARPACK
Harshad Sahasrabudhe
harshad.sahasrabudhe at gmail.com
Wed Mar 25 16:21:41 CDT 2015
> Absolutely. Also, with Krylov-Schur you can adjust the restart parameter
> (which is hidden in ARPACK); it may help improve convergence in some cases.
Awesome. I'll just use Krylov-Schur then. Thanks.
On Wed, Mar 25, 2015 at 5:18 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 25/03/2015, a las 22:06, Harshad Sahasrabudhe escribió:
> > I thought ARPACK was faster when the system size is large and number of
> eigenvalues required is small. I will be working with sparse matrices of
> size ~60,000. Does SLEPC's Krylov-Schur have about the same performance as
> ARPACK for calculating ~50 eigenvalues for such matrices?
> http://slepc.upv.es/documentation/current/docs/manualpages/EPS/EPSKrylovSchurSetRestart.html
> Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150325/d38c97fc/attachment.html>
