[petsc-users] SLEPc - Generalized symmetric eigenproblem using	ARPACK
    Jose E. Roman
    jroman at dsic.upv.es
    Wed Mar 25 16:18:13 CDT 2015
El 25/03/2015, a las 22:06, Harshad Sahasrabudhe escribió:
> I thought ARPACK was faster when the system size is large and number of eigenvalues required is small. I will be working with sparse matrices of size ~60,000. Does SLEPC's Krylov-Schur have about the same performance as ARPACK for calculating ~50 eigenvalues for such matrices?
Absolutely. Also, with Krylov-Schur you can adjust the restart parameter (which is hidden in ARPACK); it may help improve convergence in some cases.
http://slepc.upv.es/documentation/current/docs/manualpages/EPS/EPSKrylovSchurSetRestart.html
Jose
