[petsc-users] DMView and DMLoad
Ataollah Mesgarnejad amesga1 at tigers.lsu.edu
Tue Mar 10 17:02:53 CDT 2015
Thanks Matt,
I changed your file to reproduce the error. If you run it on more than one
processor you will get something similar to:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Number of coordinates loaded 9 does not match number of
vertices 13
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2186-g052b31f  GIT
Date: 2015-03-04 11:15:59 -0600
[0]PETSC ERROR: /work/01624/amesga/Code/dmcomplex/ex5 on a
sandybridge-cxx-dbg named c560-303.stampede.tacc.utexas.edu by amesga Tue
Mar 10 16:57:01 2015
[0]PETSC ERROR: Configure options --COPTFLAGS= --CXXOPTFLAGS= --FOPTFLAGS=
--download-chaco=1 --download-exodusii=1 --download-hdf5=1
--download-metis=1 --download-netcdf=1 --download-parmetis=1 --with-blacs=1
--with-blas-lapack-dir=/opt/apps/intel/13/composer_xe_2013_sp1.1.106/mkl/lib/intel64
--with-clanguage=C++ --with-debugging=yes --with-hdf5=1 --with-metis=1
--with-valgrind=1 --download-triangle=1
--with-valgrind-dir=/opt/apps/valgrind/3.8.1/ --with-mpi-compilers=1
--with-mpi-dir=/opt/apps/intel13/impi/4.1.3.049/intel64
--with-scalar-type=real --with-shared-libraries=1
--with-vendor-compilers=intel --with-x11=1 -with-pic
PETSC_ARCH=sandybridge-cxx-dbg
[0]PETSC ERROR: #1 DMPlexLoad_HDF5() line 741 in
/work/01624/amesga/Software/petsc/src/dm/impls/plex/plexhdf5.c
[0]PETSC ERROR: #2 DMLoad_Plex() line 605 in
/work/01624/amesga/Software/petsc/src/dm/impls/plex/plex.c
[0]PETSC ERROR: #3 DMLoad() line 2939 in
/work/01624/amesga/Software/petsc/src/dm/interface/dm.c
[0]PETSC ERROR: #4 main() line 31 in /work/01624/amesga/Code/dmcomplex/ex5.c
[0]PETSC ERROR: No PETSc Option Table entries
[0]PETSC ERROR: ----------------End of Error Message -------
It seems like HDF5 version of DMView and DMLoad work fine for a serial
DMPlex but DMLoad breaks in parallel.
Many thanks,
Ata
On Tue, Mar 10, 2015 at 3:15 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 9, 2015 at 11:28 AM, Ataollah Mesgarnejad <
> amesga1 at tigers.lsu.edu> wrote:
>> Dear all,
>> I'm trying to save and load distributed DMPlex in HDF5 format with DMView
>> and DMLoad. The problem is even though there are no errors while loading
>> the DM when I look at the DM loaded from file is not equal to the DM that
>> was saved. Also, when loading the DM if DMSetType is called before the
>> DMLoad, DMLoad produces errors (like line 316
>> <https://bitbucket.org/petsc/petsc/src/236f5a4d227fe9d0affddb8701edb9509ad39525/src/snes/examples/tutorials/ex12.c?at=master#cl-316>
>> in src/snes/examples/tutorials/ex12.c ).
>> I'm including a small code to replicate the problem here plus an input
>> mesh file.
> Here is a simpler test, which I am going to make DMPlex ex5. The file you
> sent does not make sense
> to me since it has cells with only two vertices. Run it with
>   -dm_view ::ascii_info_detail
>   Thanks,
>     Matt
>> Best,
>> Ata
>>  * @file
>>  * Created by Ataollah Mesgarnejad on 3/6/15.
>>  * This is a test to read and write a distributed DM.
>> static char help[] = "An example of the usage of PetscSF to scatter data
>> back and forth between a \
>> a serial DM and its parallel counterpart.\n";
>> #include <petscdmplex.h>
>> #include <petscsnes.h>
>> #include <petscsf.h>
>> #include <exodusII.h>
>> #include <petsc-private/dmimpl.h>     /*I      "petscdm.h"     I*/
>> #include <petscviewerhdf5.h>
>> #undef __FUNCT__
>> #define __FUNCT__ "main"
>> int main(int argc,char **argv)
>>     PetscErrorCode      ierr;
>>     DM                  dm, distDM,distDMold;
>>     char                ifilename[PETSC_MAX_PATH_LEN];
>>     PetscBool           flg;
>>     int                 CPU_word_size = 0,IO_word_size = 0,exoid;
>>     float               version;
>>     PetscInt            numproc,rank;
>>     PetscViewer         stdoutViewer,DMPlexHDF5View;
>>     PetscReal           *VArray;
>>     PetscInt            dim;
>>     PetscInt            numFields = 2;
>>     PetscInt            numComp[2] = {1,1};
>>     PetscInt            numDof[6] = {1, 0, 0,
>>         0, 0, 1}; /*{Vertex, Edge, Cell} */
>>     PetscInt            bcFields[1] = {0}, numBC=0;
>>     //PetscInt          *remoteOffsets;
>>     char**              namelist;
>>     PetscInt            off;
>>     IS                  bcPoints[1] = {NULL};
>>     IS                  *ISlist;
>>     PetscSection        seqSection, distSection;
>>     Vec                 distV, V;
>>     PetscSF             pointSF;//,pointSFold;
>>     PetscInt            pStart, pEnd, dof;
>>     PetscBool           load_files = PETSC_FALSE, save_files =
>> PETSC_FALSE;
>>     MPI_Comm            comm;
>>     ierr = PetscInitialize(&argc, &argv, (char*)0, help);CHKERRQ(ierr);
>>     ierr = PetscViewerASCIIGetStdout(PETSC_COMM_SELF,&stdoutViewer);
>> CHKERRQ(ierr);
>>     comm = PETSC_COMM_WORLD;
>>     // PetscErrorCode DMCreateSubDM(DM dm, PetscInt numFields, PetscInt
>> fields[], IS *is, DM *subdm)
>>     ierr = PetscOptionsBegin(PETSC_COMM_WORLD,"","PetscSF Test Options",
>> "none");CHKERRQ(ierr);
>>     ierr = PetscOptionsBool("-save_files","save the distributed vector
>> in HDF5 format","",PETSC_FALSE,&save_files,NULL);CHKERRQ(ierr);
>>     ierr = PetscOptionsBool("-load_files","Load the distributed vector
>> in HDF5 format","",PETSC_FALSE,&load_files,NULL);CHKERRQ(ierr);
>>     ierr = PetscOptionsEnd();
>>     ierr = PetscOptionsGetString(PETSC_NULL,"-i",ifilename,sizeof
>> ifilename,&flg);CHKERRQ(ierr);
>>     ierr = MPI_Comm_size(PETSC_COMM_WORLD,&numproc);
>>     ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
>>     if (!rank)
>>         exoid = ex_open(ifilename,EX_READ
>> ,&CPU_word_size,&IO_word_size,&version);
>>         if (exoid <= 0) SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"ex_open(\"%s\",...)
>> did not return a valid file ID",ifilename);
>>     else
>>         exoid = -1;                 /* Not used */
>>     ierr = DMPlexCreateExodus(PETSC_COMM_WORLD,exoid,PETSC_FALSE,&dm);
>>                                                 CHKERRQ(ierr);
>>     ierr = PetscObjectSetName((PetscObject) dm,"sequential-DM");
>>     ierr = DMGetDimension(dm, &dim);
>>                                                 CHKERRQ(ierr);
>>     if (numproc < 2 ) distDM = dm;
>>     else ierr = DMPlexDistribute(dm, 0, &pointSF, &distDM);
>>                                                 CHKERRQ(ierr);
>>     ierr = PetscObjectSetName((PetscObject) distDM,"Distributed-DM");
>>     ierr = DMPlexCreateSection(dm,      dim, numFields, numComp, numDof,
>>                                numBC, bcFields, bcPoints,PETSC_NULL,
>> &seqSection);                                      CHKERRQ(ierr);
>>     ierr = DMPlexCreateSection(distDM,  dim, numFields, numComp, numDof,
>> &distSection);                                     CHKERRQ(ierr);
>>     ierr = DMSetDefaultSection(dm, seqSection);
>>                                                 CHKERRQ(ierr);
>>     ierr = DMSetDefaultSection(distDM, distSection);
>>                                                 CHKERRQ(ierr);
>>     ierr = DMCreateGlobalVector(dm, &V);
>>                                                 CHKERRQ(ierr);
>>     ierr = VecCreate(comm, &distV);
>>                                                 CHKERRQ(ierr);
>>     ierr = PetscObjectSetName((PetscObject) distV,"Distributed-V");
>>     ierr = VecGetArray(V, &VArray);
>>                                                 CHKERRQ(ierr);
>>     // fill vertex data
>>     ierr = DMPlexGetDepthStratum(dm, 0, &pStart, &pEnd);
>>                                                 CHKERRQ(ierr);
>>     for (int p = pStart; p < pEnd; p++)
>>         ierr = PetscSectionGetDof(seqSection, p, &dof);
>>                                                 CHKERRQ(ierr);
>>         ierr = PetscSectionGetOffset(seqSection, p, &off);
>>                                                 CHKERRQ(ierr);
>>         for (int d = 0; d < dof; d++)
>>             VArray[off + d] = p;
>>     // fill cell data
>>     ierr = DMPlexGetDepthStratum(dm, 1, &pStart, &pEnd);
>>                                                 CHKERRQ(ierr);
>>                                                 CHKERRQ(ierr);
>>                                                 CHKERRQ(ierr);
>>             VArray[off + d] = -p-1;
>>     ierr = VecRestoreArray(V, &VArray); CHKERRQ(ierr);
>>     ierr = DMCreateFieldIS(dm, &numFields, &namelist, &ISlist);
>>                                                 CHKERRQ(ierr);
>>     ierr = DMPlexDistributeField(dm, pointSF, seqSection, V,
>> distSection, distV);                                       CHKERRQ(ierr);
>> #if defined(PETSC_HAVE_HDF5)
>>     if (save_files)
>>         // distribute fields
>>         ierr = PetscPrintf(PETSC_COMM_WORLD, "==== Distrubuted DM\n");
>>                                                 CHKERRQ(ierr);
>>         ierr = DMView(distDM, PETSC_VIEWER_STDOUT_WORLD);
>>                                                 CHKERRQ(ierr);
>>         PetscSynchronizedFlush(PETSC_COMM_WORLD, PETSC_STDOUT);
>>         // Save distributed data
>>         ierr = PetscViewerHDF5Open(PetscObjectComm((PetscObject) distDM),
>> "distDM.h5", FILE_MODE_WRITE, &DMPlexHDF5View);CHKERRQ(ierr);
>>         ierr = PetscPrintf(PETSC_COMM_WORLD,"Writing dist DM ...\n");
>>         ierr = DMView(distDM, DMPlexHDF5View);
>>                                                 CHKERRQ(ierr);
>>         PetscViewerDestroy(&DMPlexHDF5View);
>>     else if (load_files)
>>         ierr = PetscPrintf(PETSC_COMM_WORLD,"Loading dist vectors ...\n");
>>                                             CHKERRQ(ierr);
>>         ierr = PetscViewerHDF5Open(PETSC_COMM_SELF,"distDM.h5",
>> FILE_MODE_READ, &DMPlexHDF5View);                       CHKERRQ(ierr);
>>         ierr = DMCreate(comm,&distDMold);
>>                                                 CHKERRQ(ierr);
>>         ierr = DMLoad(distDMold,DMPlexHDF5View);
>>                                                 CHKERRQ(ierr);
>>         ierr = DMSetType(distDMold, DMPLEX);
>>                                                 CHKERRQ(ierr);
>>         /*ierr = DMPlexCreateSection(distDMold,  dim, numFields,
>> numComp, numDof,
>> &distSectionold);                              CHKERRQ(ierr);
>>         ierr = DMSetDefaultSection(distDMold,
>> distSectionold);CHKERRQ(ierr);
>>         ierr = DMGetPointSF(distDMold,&pointSFold);
>>                                               CHKERRQ(ierr);*/
>>         ierr = PetscPrintf(PETSC_COMM_WORLD, "==== Read DM\n");
>>                                                 CHKERRQ(ierr);
>>         ierr = DMView(distDMold, PETSC_VIEWER_STDOUT_WORLD);
>>                                                 CHKERRQ(ierr);
>>                                                 CHKERRQ(ierr);
>>         DMPlexEqual(distDM, distDMold, &flg);
>>         if (flg)
>>             PetscPrintf(PETSC_COMM_WORLD,"\n DMs equal\n");
>>         else
>>             PetscPrintf(PETSC_COMM_WORLD,"\n DMs are not equal\n\n");
>> #endif
>>     ierr = VecDestroy(&V); CHKERRQ(ierr);
>>     ierr = VecDestroy(&distV); CHKERRQ(ierr);
>>     //ierr = VecDestroy(&seqV); CHKERRQ(ierr);
>>     ierr = DMDestroy(&dm);CHKERRQ(ierr);
>>     ierr = DMDestroy(&distDM);CHKERRQ(ierr);
>>     ierr = PetscFinalize();
>>     return 0;
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150310/716cf4db/attachment-0001.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150310/716cf4db/attachment-0001.c>
