[petsc-users] DMView and DMLoad
    Matthew Knepley
    knepley at gmail.com
    Tue Mar 10 17:05:37 CDT 2015
On Tue, Mar 10, 2015 at 5:02 PM, Ataollah Mesgarnejad <
amesga1 at tigers.lsu.edu> wrote:
> Thanks Matt,
> I changed your file to reproduce the error. If you run it on more than one
> processor you will get something similar to:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Number of coordinates loaded 9 does not match number of
> vertices 13
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2186-g052b31f  GIT
> Date: 2015-03-04 11:15:59 -0600
> [0]PETSC ERROR: /work/01624/amesga/Code/dmcomplex/ex5 on a
> sandybridge-cxx-dbg named c560-303.stampede.tacc.utexas.edu by amesga Tue
> Mar 10 16:57:01 2015
> [0]PETSC ERROR: Configure options --COPTFLAGS= --CXXOPTFLAGS= --FOPTFLAGS=
> --download-chaco=1 --download-exodusii=1 --download-hdf5=1
> --download-metis=1 --download-netcdf=1 --download-parmetis=1 --with-blacs=1
> --with-blas-lapack-dir=/opt/apps/intel/13/composer_xe_2013_sp1.1.106/mkl/lib/intel64
> --with-clanguage=C++ --with-debugging=yes --with-hdf5=1 --with-metis=1
> --with-valgrind=1 --download-triangle=1
> --with-valgrind-dir=/opt/apps/valgrind/3.8.1/ --with-mpi-compilers=1
> --with-mpi-dir=/opt/apps/intel13/impi/4.1.3.049/intel64
> --with-scalar-type=real --with-shared-libraries=1
> --with-vendor-compilers=intel --with-x11=1 -with-pic
> PETSC_ARCH=sandybridge-cxx-dbg
> [0]PETSC ERROR: #1 DMPlexLoad_HDF5() line 741 in
> /work/01624/amesga/Software/petsc/src/dm/impls/plex/plexhdf5.c
> [0]PETSC ERROR: #2 DMLoad_Plex() line 605 in
> /work/01624/amesga/Software/petsc/src/dm/impls/plex/plex.c
> [0]PETSC ERROR: #3 DMLoad() line 2939 in
> /work/01624/amesga/Software/petsc/src/dm/interface/dm.c
> [0]PETSC ERROR: #4 main() line 31 in
> /work/01624/amesga/Code/dmcomplex/ex5.c
> [0]PETSC ERROR: No PETSc Option Table entries
> [0]PETSC ERROR: ----------------End of Error Message -------
> It seems like HDF5 version of DMView and DMLoad work fine for a serial
> DMPlex but DMLoad breaks in parallel.
Cool, will get it fixed. I have only been loading Vecs since DMLoad()
cannot recreate hierarchies, and thus is not
compatible with the FAS tests I am mostly running.
    Matt
> Many thanks,
> Ata
> On Tue, Mar 10, 2015 at 3:15 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Mar 9, 2015 at 11:28 AM, Ataollah Mesgarnejad <
>>> Dear all,
>>> I'm trying to save and load distributed DMPlex in HDF5 format with
>>> DMView and DMLoad. The problem is even though there are no errors while
>>> loading the DM when I look at the DM loaded from file is not equal to the
>>> DM that was saved. Also, when loading the DM if DMSetType is called before
>>> the DMLoad, DMLoad produces errors (like line 316
>>> <https://bitbucket.org/petsc/petsc/src/236f5a4d227fe9d0affddb8701edb9509ad39525/src/snes/examples/tutorials/ex12.c?at=master#cl-316>
>>> in src/snes/examples/tutorials/ex12.c ).
>>> I'm including a small code to replicate the problem here plus an input
>>> mesh file.
>> Here is a simpler test, which I am going to make DMPlex ex5. The file you
>> sent does not make sense
>> to me since it has cells with only two vertices. Run it with
>>   -dm_view ::ascii_info_detail
>>   Thanks,
>>     Matt
>>> Best,
>>> Ata
>>>  * @file
>>>  * Created by Ataollah Mesgarnejad on 3/6/15.
>>>  * This is a test to read and write a distributed DM.
>>> static char help[] = "An example of the usage of PetscSF to scatter
>>> data back and forth between a \
>>> a serial DM and its parallel counterpart.\n";
>>> #include <petscdmplex.h>
>>> #include <petscsnes.h>
>>> #include <petscsf.h>
>>> #include <exodusII.h>
>>> #include <petsc-private/dmimpl.h>     /*I      "petscdm.h"     I*/
>>> #include <petscviewerhdf5.h>
>>> #undef __FUNCT__
>>> #define __FUNCT__ "main"
>>> int main(int argc,char **argv)
>>>     PetscErrorCode      ierr;
>>>     DM                  dm, distDM,distDMold;
>>>     char                ifilename[PETSC_MAX_PATH_LEN];
>>>     PetscBool           flg;
>>>     int                 CPU_word_size = 0,IO_word_size = 0,exoid;
>>>     float               version;
>>>     PetscInt            numproc,rank;
>>>     PetscViewer         stdoutViewer,DMPlexHDF5View;
>>>     PetscReal           *VArray;
>>>     PetscInt            dim;
>>>     PetscInt            numFields = 2;
>>>     PetscInt            numComp[2] = {1,1};
>>>     PetscInt            numDof[6] = {1, 0, 0,
>>>         0, 0, 1}; /*{Vertex, Edge, Cell} */
>>>     PetscInt            bcFields[1] = {0}, numBC=0;
>>>     //PetscInt          *remoteOffsets;
>>>     char**              namelist;
>>>     PetscInt            off;
>>>     IS                  bcPoints[1] = {NULL};
>>>     IS                  *ISlist;
>>>     PetscSection        seqSection, distSection;
>>>     Vec                 distV, V;
>>>     PetscSF             pointSF;//,pointSFold;
>>>     PetscInt            pStart, pEnd, dof;
>>>     PetscBool           load_files = PETSC_FALSE, save_files =
>>> PETSC_FALSE;
>>>     MPI_Comm            comm;
>>>     ierr = PetscInitialize(&argc, &argv, (char*)0, help);CHKERRQ(ierr);
>>>     ierr = PetscViewerASCIIGetStdout(PETSC_COMM_SELF,&stdoutViewer);
>>> CHKERRQ(ierr);
>>>     comm = PETSC_COMM_WORLD;
>>>     // PetscErrorCode DMCreateSubDM(DM dm, PetscInt numFields, PetscInt
>>> fields[], IS *is, DM *subdm)
>>>     ierr = PetscOptionsBegin(PETSC_COMM_WORLD,"","PetscSF Test Options",
>>> "none");CHKERRQ(ierr);
>>>     ierr = PetscOptionsBool("-save_files","save the distributed vector
>>> in HDF5 format","",PETSC_FALSE,&save_files,NULL);CHKERRQ(ierr);
>>>     ierr = PetscOptionsBool("-load_files","Load the distributed vector
>>> in HDF5 format","",PETSC_FALSE,&load_files,NULL);CHKERRQ(ierr);
>>>     ierr = PetscOptionsEnd();
>>>     ierr = PetscOptionsGetString(PETSC_NULL,"-i",ifilename,sizeof
>>> ifilename,&flg);CHKERRQ(ierr);
>>>     ierr = MPI_Comm_size(PETSC_COMM_WORLD,&numproc);
>>>     ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
>>>     if (!rank)
>>>         exoid = ex_open(ifilename,EX_READ
>>> ,&CPU_word_size,&IO_word_size,&version);
>>>         if (exoid <= 0) SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"ex_open(\"%s\",...)
>>> did not return a valid file ID",ifilename);
>>>     else
>>>         exoid = -1;                 /* Not used */
>>>     ierr = DMPlexCreateExodus(PETSC_COMM_WORLD,exoid,PETSC_FALSE,&dm);
>>>                                                 CHKERRQ(ierr);
>>>     ierr = PetscObjectSetName((PetscObject) dm,"sequential-DM");
>>>     ierr = DMGetDimension(dm, &dim);
>>>                                                 CHKERRQ(ierr);
>>>     if (numproc < 2 ) distDM = dm;
>>>     else ierr = DMPlexDistribute(dm, 0, &pointSF, &distDM);
>>>                                                 CHKERRQ(ierr);
>>>     ierr = PetscObjectSetName((PetscObject) distDM,"Distributed-DM");
>>>     ierr = DMPlexCreateSection(dm,      dim, numFields, numComp, numDof,
>>>                                numBC, bcFields, bcPoints,PETSC_NULL,
>>> &seqSection);                                      CHKERRQ(ierr);
>>>     ierr = DMPlexCreateSection(distDM,  dim, numFields, numComp, numDof,
>>> &distSection);                                     CHKERRQ(ierr);
>>>     ierr = DMSetDefaultSection(dm, seqSection);
>>>                                                 CHKERRQ(ierr);
>>>     ierr = DMSetDefaultSection(distDM, distSection);
>>>                                                 CHKERRQ(ierr);
>>>     ierr = DMCreateGlobalVector(dm, &V);
>>>                                                 CHKERRQ(ierr);
>>>     ierr = VecCreate(comm, &distV);
>>>                                                 CHKERRQ(ierr);
>>>     ierr = PetscObjectSetName((PetscObject) distV,"Distributed-V");
>>>     ierr = VecGetArray(V, &VArray);
>>>                                                 CHKERRQ(ierr);
>>>     // fill vertex data
>>>     ierr = DMPlexGetDepthStratum(dm, 0, &pStart, &pEnd);
>>>                                                 CHKERRQ(ierr);
>>>     for (int p = pStart; p < pEnd; p++)
>>>         ierr = PetscSectionGetDof(seqSection, p, &dof);
>>>                                                 CHKERRQ(ierr);
>>>         ierr = PetscSectionGetOffset(seqSection, p, &off);
>>>                                                 CHKERRQ(ierr);
>>>         for (int d = 0; d < dof; d++)
>>>             VArray[off + d] = p;
>>>     // fill cell data
>>>     ierr = DMPlexGetDepthStratum(dm, 1, &pStart, &pEnd);
>>>                                                 CHKERRQ(ierr);
>>>                                                 CHKERRQ(ierr);
>>>                                                 CHKERRQ(ierr);
>>>             VArray[off + d] = -p-1;
>>>     ierr = VecRestoreArray(V, &VArray); CHKERRQ(ierr);
>>>     ierr = DMCreateFieldIS(dm, &numFields, &namelist, &ISlist);
>>>                                                 CHKERRQ(ierr);
>>>     ierr = DMPlexDistributeField(dm, pointSF, seqSection, V,
>>> distSection, distV);                                       CHKERRQ
>>> (ierr);
>>> #if defined(PETSC_HAVE_HDF5)
>>>     if (save_files)
>>>         // distribute fields
>>>         ierr = PetscPrintf(PETSC_COMM_WORLD, "==== Distrubuted DM\n");
>>>                                                 CHKERRQ(ierr);
>>>         ierr = DMView(distDM, PETSC_VIEWER_STDOUT_WORLD);
>>>                                                 CHKERRQ(ierr);
>>>         PetscSynchronizedFlush(PETSC_COMM_WORLD, PETSC_STDOUT);
>>>         // Save distributed data
>>>         ierr = PetscViewerHDF5Open(PetscObjectComm((PetscObject)
>>> distDM),"distDM.h5", FILE_MODE_WRITE, &DMPlexHDF5View);CHKERRQ(ierr);
>>>         ierr = PetscPrintf(PETSC_COMM_WORLD,"Writing dist DM ...\n");
>>>         ierr = DMView(distDM, DMPlexHDF5View);
>>>                                                 CHKERRQ(ierr);
>>>         PetscViewerDestroy(&DMPlexHDF5View);
>>>     else if (load_files)
>>>         ierr = PetscPrintf(PETSC_COMM_WORLD,"Loading dist vectors ...\n");
>>>                                             CHKERRQ(ierr);
>>>         ierr = PetscViewerHDF5Open(PETSC_COMM_SELF,"distDM.h5",
>>> FILE_MODE_READ, &DMPlexHDF5View);                       CHKERRQ(ierr);
>>>         ierr = DMCreate(comm,&distDMold);
>>>                                                 CHKERRQ(ierr);
>>>         ierr = DMLoad(distDMold,DMPlexHDF5View);
>>>                                                 CHKERRQ(ierr);
>>>         ierr = DMSetType(distDMold, DMPLEX);
>>>                                                 CHKERRQ(ierr);
>>>         /*ierr = DMPlexCreateSection(distDMold,  dim, numFields,
>>> numComp, numDof,
>>> &distSectionold);                              CHKERRQ(ierr);
>>>         ierr = DMSetDefaultSection(distDMold,
>>> distSectionold);CHKERRQ(ierr);
>>>         ierr = DMGetPointSF(distDMold,&pointSFold);
>>>                                                 CHKERRQ(ierr);*/
>>>         ierr = PetscPrintf(PETSC_COMM_WORLD, "==== Read DM\n");
>>>                                                 CHKERRQ(ierr);
>>>         ierr = DMView(distDMold, PETSC_VIEWER_STDOUT_WORLD);
>>>                                                 CHKERRQ(ierr);
>>>                                                 CHKERRQ(ierr);
>>>         DMPlexEqual(distDM, distDMold, &flg);
>>>         if (flg)
>>>             PetscPrintf(PETSC_COMM_WORLD,"\n DMs equal\n");
>>>         else
>>>             PetscPrintf(PETSC_COMM_WORLD,"\n DMs are not equal\n\n");
>>> #endif
>>>     ierr = VecDestroy(&V); CHKERRQ(ierr);
>>>     ierr = VecDestroy(&distV); CHKERRQ(ierr);
>>>     //ierr = VecDestroy(&seqV); CHKERRQ(ierr);
>>>     ierr = DMDestroy(&dm);CHKERRQ(ierr);
>>>     ierr = DMDestroy(&distDM);CHKERRQ(ierr);
>>>     ierr = PetscFinalize();
>>>     return 0;
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150310/96c33c6f/attachment-0001.html>
