[petsc-users] DMView and DMLoad
Matthew Knepley
knepley at gmail.com
Tue Mar 10 15:15:46 CDT 2015
On Mon, Mar 9, 2015 at 11:28 AM, Ataollah Mesgarnejad <
amesga1 at tigers.lsu.edu> wrote:
> Dear all,
> I'm trying to save and load distributed DMPlex in HDF5 format with DMView
> and DMLoad. The problem is even though there are no errors while loading
> the DM when I look at the DM loaded from file is not equal to the DM that
> was saved. Also, when loading the DM if DMSetType is called before the
> DMLoad, DMLoad produces errors (like line 316
> <https://bitbucket.org/petsc/petsc/src/236f5a4d227fe9d0affddb8701edb9509ad39525/src/snes/examples/tutorials/ex12.c?at=master#cl-316>
> in src/snes/examples/tutorials/ex12.c ).
> I'm including a small code to replicate the problem here plus an input
> mesh file.
Here is a simpler test, which I am going to make DMPlex ex5. The file you
sent does not make sense
to me since it has cells with only two vertices. Run it with
-dm_view ::ascii_info_detail
Matt
> Best,
> Ata
> * @file
> * Created by Ataollah Mesgarnejad on 3/6/15.
> * This is a test to read and write a distributed DM.
> static char help[] = "An example of the usage of PetscSF to scatter data
> back and forth between a \
> a serial DM and its parallel counterpart.\n";
> #include <petscdmplex.h>
> #include <petscsnes.h>
> #include <petscsf.h>
> #include <exodusII.h>
> #include <petsc-private/dmimpl.h> /*I "petscdm.h" I*/
> #include <petscviewerhdf5.h>
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int argc,char **argv)
> PetscErrorCode ierr;
> DM dm, distDM,distDMold;
> char ifilename[PETSC_MAX_PATH_LEN];
> PetscBool flg;
> int CPU_word_size = 0,IO_word_size = 0,exoid;
> float version;
> PetscInt numproc,rank;
> PetscViewer stdoutViewer,DMPlexHDF5View;
> PetscReal *VArray;
> PetscInt dim;
> PetscInt numFields = 2;
> PetscInt numComp[2] = {1,1};
> PetscInt numDof[6] = {1, 0, 0,
> 0, 0, 1}; /*{Vertex, Edge, Cell} */
> PetscInt bcFields[1] = {0}, numBC=0;
> //PetscInt *remoteOffsets;
> char** namelist;
> PetscInt off;
> IS bcPoints[1] = {NULL};
> IS *ISlist;
> PetscSection seqSection, distSection;
> Vec distV, V;
> PetscSF pointSF;//,pointSFold;
> PetscInt pStart, pEnd, dof;
> PetscBool load_files = PETSC_FALSE, save_files = PETSC_FALSE
> MPI_Comm comm;
> ierr = PetscInitialize(&argc, &argv, (char*)0, help);CHKERRQ(ierr);
> ierr = PetscViewerASCIIGetStdout(PETSC_COMM_SELF,&stdoutViewer);
> CHKERRQ(ierr);
> comm = PETSC_COMM_WORLD;
> // PetscErrorCode DMCreateSubDM(DM dm, PetscInt numFields, PetscInt
> fields[], IS *is, DM *subdm)
> ierr = PetscOptionsBegin(PETSC_COMM_WORLD,"","PetscSF Test Options",
> "none");CHKERRQ(ierr);
> ierr = PetscOptionsBool("-save_files","save the distributed vector in
> HDF5 format","",PETSC_FALSE,&save_files,NULL);CHKERRQ(ierr);
> ierr = PetscOptionsBool("-load_files","Load the distributed vector in
> HDF5 format","",PETSC_FALSE,&load_files,NULL);CHKERRQ(ierr);
> ierr = PetscOptionsEnd();
> ierr = PetscOptionsGetString(PETSC_NULL,"-i",ifilename,sizeof
> ifilename,&flg);CHKERRQ(ierr);
> ierr = MPI_Comm_size(PETSC_COMM_WORLD,&numproc);
> ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
> if (!rank)
> exoid = ex_open(ifilename,EX_READ
> ,&CPU_word_size,&IO_word_size,&version);
> if (exoid <= 0) SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"ex_open(\"%s\",...)
> did not return a valid file ID",ifilename);
> else
> exoid = -1; /* Not used */
> ierr = DMPlexCreateExodus(PETSC_COMM_WORLD,exoid,PETSC_FALSE,&dm);
> CHKERRQ(ierr);
> ierr = PetscObjectSetName((PetscObject) dm,"sequential-DM");
> ierr = DMGetDimension(dm, &dim);
> CHKERRQ(ierr);
> if (numproc < 2 ) distDM = dm;
> else ierr = DMPlexDistribute(dm, 0, &pointSF, &distDM);
> CHKERRQ(ierr);
> ierr = PetscObjectSetName((PetscObject) distDM,"Distributed-DM");
> ierr = DMPlexCreateSection(dm, dim, numFields, numComp, numDof,
> numBC, bcFields, bcPoints,PETSC_NULL,
> &seqSection); CHKERRQ(ierr);
> ierr = DMPlexCreateSection(distDM, dim, numFields, numComp, numDof,
> &distSection); CHKERRQ(ierr);
> ierr = DMSetDefaultSection(dm, seqSection);
> CHKERRQ(ierr);
> ierr = DMSetDefaultSection(distDM, distSection);
> CHKERRQ(ierr);
> ierr = DMCreateGlobalVector(dm, &V);
> CHKERRQ(ierr);
> ierr = VecCreate(comm, &distV);
> CHKERRQ(ierr);
> ierr = PetscObjectSetName((PetscObject) distV,"Distributed-V");
> ierr = VecGetArray(V, &VArray);
> CHKERRQ(ierr);
> // fill vertex data
> ierr = DMPlexGetDepthStratum(dm, 0, &pStart, &pEnd);
> CHKERRQ(ierr);
> for (int p = pStart; p < pEnd; p++)
> ierr = PetscSectionGetDof(seqSection, p, &dof);
> CHKERRQ(ierr);
> ierr = PetscSectionGetOffset(seqSection, p, &off);
> CHKERRQ(ierr);
> for (int d = 0; d < dof; d++)
> VArray[off + d] = p;
> // fill cell data
> ierr = DMPlexGetDepthStratum(dm, 1, &pStart, &pEnd);
> CHKERRQ(ierr);
> CHKERRQ(ierr);
> CHKERRQ(ierr);
> VArray[off + d] = -p-1;
> ierr = VecRestoreArray(V, &VArray); CHKERRQ(ierr);
> ierr = DMCreateFieldIS(dm, &numFields, &namelist, &ISlist);
> CHKERRQ(ierr);
> ierr = DMPlexDistributeField(dm, pointSF, seqSection, V, distSection,
> distV); CHKERRQ(ierr);
> #if defined(PETSC_HAVE_HDF5)
> if (save_files)
> // distribute fields
> ierr = PetscPrintf(PETSC_COMM_WORLD, "==== Distrubuted DM\n");
> CHKERRQ(ierr);
> ierr = DMView(distDM, PETSC_VIEWER_STDOUT_WORLD);
> CHKERRQ(ierr);
> PetscSynchronizedFlush(PETSC_COMM_WORLD, PETSC_STDOUT);
> // Save distributed data
> ierr = PetscViewerHDF5Open(PetscObjectComm((PetscObject) distDM),
> "distDM.h5", FILE_MODE_WRITE, &DMPlexHDF5View);CHKERRQ(ierr);
> ierr = PetscPrintf(PETSC_COMM_WORLD,"Writing dist DM ...\n");
> ierr = DMView(distDM, DMPlexHDF5View);
> CHKERRQ(ierr);
> PetscViewerDestroy(&DMPlexHDF5View);
> else if (load_files)
> ierr = PetscPrintf(PETSC_COMM_WORLD,"Loading dist vectors ...\n");
> CHKERRQ(ierr);
> ierr = PetscViewerHDF5Open(PETSC_COMM_SELF,"distDM.h5",
> FILE_MODE_READ, &DMPlexHDF5View); CHKERRQ(ierr);
> ierr = DMCreate(comm,&distDMold);
> CHKERRQ(ierr);
> ierr = DMLoad(distDMold,DMPlexHDF5View);
> CHKERRQ(ierr);
> ierr = DMSetType(distDMold, DMPLEX);
> CHKERRQ(ierr);
> /*ierr = DMPlexCreateSection(distDMold, dim, numFields, numComp,
> numDof,
> &distSectionold); CHKERRQ(ierr);
> ierr = DMSetDefaultSection(distDMold,
> distSectionold);CHKERRQ(ierr);
> ierr = DMGetPointSF(distDMold,&pointSFold);
> CHKERRQ(ierr);*/
> ierr = PetscPrintf(PETSC_COMM_WORLD, "==== Read DM\n");
> CHKERRQ(ierr);
> ierr = DMView(distDMold, PETSC_VIEWER_STDOUT_WORLD);
> CHKERRQ(ierr);
> CHKERRQ(ierr);
> DMPlexEqual(distDM, distDMold, &flg);
> if (flg)
> PetscPrintf(PETSC_COMM_WORLD,"\n DMs equal\n");
> else
> PetscPrintf(PETSC_COMM_WORLD,"\n DMs are not equal\n\n");
> #endif
> ierr = VecDestroy(&V); CHKERRQ(ierr);
> ierr = VecDestroy(&distV); CHKERRQ(ierr);
> //ierr = VecDestroy(&seqV); CHKERRQ(ierr);
> ierr = DMDestroy(&dm);CHKERRQ(ierr);
> ierr = DMDestroy(&distDM);CHKERRQ(ierr);
> ierr = PetscFinalize();
> return 0;
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150310/09da59dc/attachment-0001.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150310/09da59dc/attachment-0001.c>
