[petsc-users] [Fwd: Re:  saving views as images]
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Mar 10 13:02:48 CDT 2015
  Looks like your afterimage is not installed to support .Gif files. When I install afterimage on my Mac from source http://www.afterstep.org/afterimage/getcode.php it just comes with support for .Gif files. Suggest trying that.
  Barry
> On Mar 10, 2015, at 12:14 PM, Theler German Guillermo <gtheler at cites-gss.com> wrote:
> On Tue, 2015-03-10 at 11:35 -0500, Barry Smith wrote:
>>   You must call
>>  call(PetscDrawSetSave(draw, "matrix", PETSC_FALSE));
>>  call(PetscDrawSetSaveFinalImage(draw, "matrix2"));
>> BEFORE you view the image.  PetscDrawSetSave() sets the flag to save future images; generally you could this immediately after you've done the PetscViewerDrawOpen
> Got it Barry, so now I have:
>  call(PetscViewerBinaryOpen(PETSC_COMM_WORLD,file,FILE_MODE_READ,&fd));
>  call(MatCreate(PETSC_COMM_WORLD,&A));
>  call(MatSetFromOptions(A));
>  call(MatLoad(A,fd));
>  call(PetscViewerDrawOpen(PETSC_COMM_WORLD, PETSC_NULL, file, 100, 100,
> size, size, &viewer));
>  call(PetscViewerDrawGetDraw(viewer, 0, &draw));
>  call(PetscDrawSetFromOptions(draw));
>  call(MatView(A, viewer));
>  call(PetscDrawDestroy(&draw));
>  call(PetscViewerDestroy(&fd));
>  call(MatDestroy(&A));
>  call(PetscFinalize());
> But now I get this dissapointing message from libafterimage:
> gtheler at blinky:~/codigos/mat2img$ ./mat2img -info
> [0] PetscInitialize(): PETSc successfully started: number of processors
> = 1
> [0] PetscGetHostName(): Rejecting domainname, likely is NIS
> blinky.(none)
> [0] PetscInitialize(): Running on machine: blinky
> [0] PetscCommDuplicate(): Duplicating a communicator 1140850688
> -2080374784 max tags = 536870911
> [0] PetscGetFileStat(): System call stat() succeeded on file matrix.bin
> [0] PetscTestOwnership(): System call access() succeeded on file
> matrix.bin
> [0] PetscFileRetrieve(): Found file matrix.bin
> [0] PetscGetFileStat(): System call stat() failed on file
> matrix.bin.info
> [0] PetscFileRetrieve(): Did not find file matrix.bin.info
> [0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
> -2080374784
> [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 20 X 20; storage space: 0
> unneeded,58 used
> [0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is
> 0
> [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 3
> [0] MatCheckCompressedRow(): Found the ratio (num_zerorows
> 0)/(num_localrows 20) < 0.6. Do not use CompressedRow routines.
> [0] Mat_CheckInode(): Found 20 nodes out of 20 rows. Not using Inode
> routines
> -2080374784
> [0] PetscDrawSetUpColormap_Shared(): Successfully allocated colors
> blinky.(none)
> [0] PetscPOpen(): Running command :rm -fr matrix matrix.m4v
> blinky.(none)
> [0] PetscPOpen(): Running command :mkdir matrix
> blinky.(none)
> [0] PetscPOpen(): Running command :rm -fr matrix2 matrix2.m4v
> blinky.(none)
> [0] PetscPOpen(): Running command :mkdir matrix2
> unknown ERROR: unable to write file "matrix2/matrix2_0.Gif" - GIF image
> format is not supported.
> [0] PetscFinalize(): PetscFinalize() called
> ________________________________
> Imprima este mensaje sólo si es absolutamente necesario.
> Para imprimir, en lo posible utilice el papel de ambos lados.
> El Grupo Sancor Seguros se compromete con el cuidado del medioambiente.
> ************AVISO DE CONFIDENCIALIDAD************
> El Grupo Sancor Seguros comunica que:
> Este mensaje y todos los archivos adjuntos a el son para uso exclusivo del destinatario y pueden contener información confidencial o propietaria, cuya divulgación es sancionada por ley. Si usted recibió este mensaje erróneamente, por favor notifíquenos respondiendo al remitente, borre el mensaje original y destruya las copias (impresas o grabadas en cualquier medio magnético) que pueda haber realizado del mismo. Todas las opiniones contenidas en este mail son propias del autor del mensaje. La publicación, uso, copia o impresión total o parcial de este mensaje o documentos adjuntos queda prohibida.
> Disposición DNDP 10-2008. El titular de los datos personales tiene la facultad de ejercer el derecho de acceso a los mismos en forma gratuita a intervalos no inferiores a seis meses, salvo que acredite un interés legítimo al efecto conforme lo establecido en el artículo 14, inciso 3 de la Ley 25.326. La DIRECCIÓN NACIONAL DE PROTECCIÓN DE DATOS PERSONALES, Organo de Control de la Ley 25.326, tiene la atribución de atender las denuncias y reclamos que se interpongan con relación al incumplimiento de las normas sobre la protección de datos personales.
