[petsc-users] [Fwd: Re:  saving views as images]
    Theler German Guillermo
    gtheler at cites-gss.com
    Tue Mar 10 13:58:01 CDT 2015
On Tue, 2015-03-10 at 13:02 -0500, Barry Smith wrote:
>   Looks like your afterimage is not installed to support .Gif files. When I install afterimage on my Mac from source http://www.afterstep.org/afterimage/getcode.php it just comes with support for .Gif files. Suggest trying that.
Yes, I realized that. Perhaps there is something about the GIF license
that the Debian team had to remove GIF support. I have tried to search
in the changelogs but could not find any reference. BTW, as I wrote in
my earlier emails, Debian provides version AfterImage 2.2.12 whilst in
the URL you quote (which is the only one that Google returns) the latest
version is 1.20, which I cannot have PETSc to use (see the configure.log
transcript below).
My workwaround was to change the format in which PETSc asks AfterImage
to dump the draw, i.e. line 395
of /home/gtheler/libs/petsc-3.5.3/src/sys/classes/draw/impls/x/xinit.c:
ASImage2file(asimage, 0, filename,ASIT_Gif,0);
So far I tried ASIT_Png but the library complains about not being able
to initialize zlib, but I think I should be able to fix. ASIT_Bmp works
fine.
Is there anything special about GIF within PETSc? IIRC, there are indeed
some issues with the license and this format was virtually replaced with
PNG almost all over the place. Maybe it would be a good idea to add a
database key so as to select the format in PetscDrawSetSave().
According to AfterImage API documentation, valid file types are
typedef enum
    ASIT_Xpm = 0,
    ASIT_ZCompressedXpm,
    ASIT_GZCompressedXpm,
    ASIT_Png,
    ASIT_Jpeg,
    ASIT_Xcf,
    ASIT_Ppm,
    ASIT_Pnm,
    ASIT_Bmp,
    ASIT_Ico,
    ASIT_Cur,
    ASIT_Gif,
    ASIT_Tiff,
    ASIT_XMLScript,
    ASIT_SVG,
    /* reserved for future implementation : */
    ASIT_Xbm,
    ASIT_Targa,
    ASIT_Supported = ASIT_Targa,
    ASIT_Pcx,
    ASIT_HTML,
    ASIT_XML,
    ASIT_Unknown
}ASImageFileTypes;
Output of configure.log with libAfterImage 1.20 as downloaded from
http://www.afterstep.org/afterimage/getcode.php:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
char picture_ximage2asimage();
static void _check_picture_ximage2asimage()
{ picture_ximage2asimage(); }
int main() {
_check_picture_ximage2asimage();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: mpicc  -o /tmp/petsc-s8uvAW/config.libraries/conftest
-fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
-g3 -O0 /tmp/petsc-s8uvAW/config.libraries/conftest.o
-Wl,-rpath,/home/gtheler/libs/libAfterImage-1.20
-L/home/gtheler/libs/libAfterImage-1.20 -lAfterImage -lX11
-Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu
-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.9
-L/usr/lib/gcc/x86_64-linux-gnu/4.9 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
-L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -ldl -lmpich -lopa -lmpl -lrt -lcr -lpthread
-lgcc_s -ldl
Possible ERROR while running linker: exit code 256
stderr:
/home/gtheler/libs/libAfterImage-1.20/libAfterImage.a(ximage.o): In
function `asimage2drawable_gl':
ximage.c:(.text+0x1178): undefined reference to `show_warning'
function `asimage2drawable':
ximage.c:(.text+0x1292): undefined reference to `show_error'
function `asimage2alpha_drawable':
ximage.c:(.text+0x13ac): undefined reference to `show_error'
function `asimage2alpha':
ximage.c:(.text+0x157c): undefined reference to `show_error'
/home/gtheler/libs/libAfterImage-1.20/libAfterImage.a(asimage.o): In
function `asimage_start':
asimage.c:(.text+0x1bb): undefined reference to `safecalloc'
asimage.c:(.text+0x22e): undefined reference to `show_error'
function `create_asimage':
asimage.c:(.text+0x38d): undefined reference to `safecalloc'
function `destroy_asimage':
asimage.c:(.text+0x865): undefined reference to `show_error'
function `create_image_manager':
asimage.c:(.text+0x9bf): undefined reference to `mystrdup'
asimage.c:(.text+0x9f9): undefined reference to `string_compare'
asimage.c:(.text+0xa00): undefined reference to `string_hash_value'
asimage.c:(.text+0xa1e): undefined reference to `create_ashash'
asimage.c:(.text+0xa43): undefined reference to `safecalloc'
function `destroy_image_manager':
asimage.c:(.text+0xa74): undefined reference to `destroy_ashash'
function `store_asimage':
asimage.c:(.text+0xb19): undefined reference to `mystrdup'
asimage.c:(.text+0xb43): undefined reference to `add_hash_item'
function `query_asimage':
asimage.c:(.text+0xbad): undefined reference to `get_hash_item'
function `fetch_asimage':
asimage.c:(.text+0xc0d): undefined reference to `get_hash_item'
function `dup_asimage':
asimage.c:(.text+0xc71): undefined reference to `show_error'
asimage.c:(.text+0xca4): undefined reference to `show_debug'
function `release_asimage':
asimage.c:(.text+0xd0b): undefined reference to `remove_hash_item'
function `forget_asimage':
asimage.c:(.text+0xd77): undefined reference to `remove_hash_item'
function `relocate_asimage':
asimage.c:(.text+0xdb9): undefined reference to `remove_hash_item'
asimage.c:(.text+0xde3): undefined reference to `add_hash_item'
function `safe_asimage_destroy':
asimage.c:(.text+0xe9a): undefined reference to `remove_hash_item'
function `release_asimage_by_name':
asimage.c:(.text+0xedd): undefined reference to `get_hash_item'
asimage.c:(.text+0xf36): undefined reference to `remove_hash_item'
function `flip_gradient':
asimage.c:(.text+0x1006): undefined reference to `safecalloc'
asimage.c:(.text+0x1031): undefined reference to `safemalloc'
asimage.c:(.text+0x103d): undefined reference to `safemalloc'
function `create_image_layers':
asimage.c:(.text+0x1226): undefined reference to `safecalloc'
function `destroy_image_layers':
asimage.c:(.text+0x12e7): undefined reference to `remove_hash_item'
function `asimage_compare_line':
asimage.c:(.text+0x1a9e): undefined reference to `show_error'
function `set_asimage_vector':
asimage.c:(.text+0x1dac): undefined reference to `safemalloc'
function `vectorize_asimage':
asimage.c:(.text+0x1f6a): undefined reference to `safecalloc'
asimage.c:(.text+0x1f80): undefined reference to `safemalloc'
asimage.c:(.text+0x1f90): undefined reference to `safemalloc'
asimage.c:(.text+0x1fa0): undefined reference to `safemalloc'
asimage.c:(.text+0x1fb0): undefined reference to `safemalloc'
asimage.c:(.text+0x1fc0): undefined reference to `safemalloc'
/home/gtheler/libs/libAfterImage-1.20/libAfterImage.a(asimage.o):asimage.c:(.text+0x2143): more undefined references to `safemalloc' follow
function `forget_asimage_name':
asimage.c:(.text+0xe22): undefined reference to `remove_hash_item'
/home/gtheler/libs/libAfterImage-1.20/libAfterImage.a(ascmap.o): In
function `color_hash2colormap':
ascmap.c:(.text+0x564): undefined reference to `safemalloc'
function `colormap_asimage':
ascmap.c:(.text+0x858): undefined reference to `safemalloc'
ascmap.c:(.text+0x88b): undefined reference to `safecalloc'
ascmap.c:(.text+0x89f): undefined reference to `safecalloc'
/home/gtheler/libs/libAfterImage-1.20/libAfterImage.a(asstorage.o): In
function `store_data_in_block':
asstorage.c:(.text+0x530f): undefined reference to `show_error'
asstorage.c:(.text+0x532d): undefined reference to `show_error'
asstorage.c:(.text+0x5359): undefined reference to `show_error'
asstorage.c:(.text+0x5380): undefined reference to `show_error'
asstorage.c:(.text+0x53a9): undefined reference to `show_error'
/home/gtheler/libs/libAfterImage-1.20/libAfterImage.a(asstorage.o):asstorage.c:(.text+0x57cd): more undefined references to `show_error' follow
asstorage.c:(.text+0x5afd): undefined reference to `show_warning'
function `store_compressed_data':
asstorage.c:(.text+0x5dcf): undefined reference to `show_error'
function `query_storage_slot':
asstorage.c:(.text+0x8172): undefined reference to `show_error'
function `print_storage_slot':
asstorage.c:(.text+0x82f4): undefined reference to `show_error'
function `forget_data':
asstorage.c:(.text+0x8642): undefined reference to `show_error'
function `dup_data':
asstorage.c:(.text+0x87cc): undefined reference to `show_error'
/home/gtheler/libs/libAfterImage-1.20/libAfterImage.a(asstorage.o):asstorage.c:(.text+0x89f5): more undefined references to `show_error' follow
asstorage.c:(.text+0x8b4c): undefined reference to `show_warning'
/home/gtheler/libs/libAfterImage-1.20/libAfterImage.a(asvisual.o): In
function `ximage2scanline_pseudo12bpp':
asvisual.c:(.text+0x2305): undefined reference to `get_hash_item'
asvisual.c:(.text+0x2402): undefined reference to `get_hash_item'
function `query_screen_visual_id':
asvisual.c:(.text+0x26f3): undefined reference to `get_output_threshold'
asvisual.c:(.text+0x27ca): undefined reference to `show_error'
function `destroy_asvisual':
asvisual.c:(.text+0x28a8): undefined reference to `destroy_ashash'
function `visual2visual_prop':
asvisual.c:(.text+0x293b): undefined reference to `safemalloc'
function `visual_prop2visual':
asvisual.c:(.text+0x2be5): undefined reference to `safemalloc'
function `make_reverse_colormap':
asvisual.c:(.text+0x2fc6): undefined reference to `safecalloc'
function `make_reverse_colorhash':
asvisual.c:(.text+0x3062): undefined reference to `create_ashash'
asvisual.c:(.text+0x30c7): undefined reference to `add_hash_item'
function `setup_as_colormap':
asvisual.c:(.text+0x338e): undefined reference to `safemalloc'
asvisual.c:(.text+0x34ca): undefined reference to `safemalloc'
asvisual.c:(.text+0x3642): undefined reference to `safemalloc'
asvisual.c:(.text+0x37ef): undefined reference to `safemalloc'
function `create_asvisual_for_id':
asvisual.c:(.text+0x3e81): undefined reference to `safecalloc'
asvisual.c:(.text+0x3f0c): undefined reference to `safecalloc'
function `create_visual_window':
asvisual.c:(.text+0x4118): undefined reference to `show_warning'
function `create_visual_ximage':
asvisual.c:(.text+0x4654): undefined reference to `safemalloc'
/home/gtheler/libs/libAfterImage-1.20/libAfterImage.a(blender.o): In
function `blend_scanlines_name2func':
blender.c:(.text+0x1821): undefined reference to `mystrncasecmp'
/home/gtheler/libs/libAfterImage-1.20/libAfterImage.a(imencdec.o): In
function `create_image_xim':
imencdec.c:(.text+0xe71): undefined reference to `show_error'
function `create_image_argb32':
imencdec.c:(.text+0x1e20): undefined reference to `safemalloc'
function `start_image_decoding':
imencdec.c:(.text+0x9218): undefined reference to `safecalloc'
imencdec.c:(.text+0x9529): undefined reference to `safecalloc'
function `start_image_output':
imencdec.c:(.text+0x97e2): undefined reference to `safecalloc'
/home/gtheler/libs/libAfterImage-1.20/libAfterImage.a(scanline.o): In
function `prepare_scanline':
scanline.c:(.text+0x179): undefined reference to `safecalloc'
scanline.c:(.text+0x25b): undefined reference to `safecalloc'
/home/gtheler/libs/libAfterImage-1.20/libAfterImage.a(scanline.o):scanline.c:(.text+0x3a8): more undefined references to `safecalloc' follow
function `calculate_green_diff':
scanline.c:(.text+0x16b1): undefined reference to `safemalloc'
function `interpolate_green_diff':
scanline.c:(.text+0x19a3): undefined reference to `safemalloc'
collect2: error: ld returned 1 exit status
              Popping language C
 Imprima este mensaje sólo si es absolutamente necesario.
Para imprimir, en lo posible utilice el papel de ambos lados.
El Grupo Sancor Seguros se compromete con el cuidado del medioambiente.
************AVISO DE CONFIDENCIALIDAD************
El Grupo Sancor Seguros comunica que:
Este mensaje y todos los archivos adjuntos a el son para uso exclusivo del destinatario y pueden contener información confidencial o propietaria, cuya divulgación es sancionada por ley. Si usted recibió este mensaje erróneamente, por favor notifíquenos respondiendo al remitente, borre el mensaje original y destruya las copias (impresas o grabadas en cualquier medio magnético) que pueda haber realizado del mismo. Todas las opiniones contenidas en este mail son propias del autor del mensaje. La publicación, uso, copia o impresión total o parcial de este mensaje o documentos adjuntos queda prohibida.
Disposición DNDP 10-2008. El titular de los datos personales tiene la facultad de ejercer el derecho de acceso a los mismos en forma gratuita a intervalos no inferiores a seis meses, salvo que acredite un interés legítimo al efecto conforme lo establecido en el artículo 14, inciso 3 de la Ley 25.326. La DIRECCIÓN NACIONAL DE PROTECCIÓN DE DATOS PERSONALES, Organo de Control de la Ley 25.326, tiene la atribución de atender las denuncias y reclamos que se interpongan con relación al incumplimiento de las normas sobre la protección de datos personales.
