[petsc-users] [Fwd: Re:  saving views as images]
    Theler German Guillermo
    gtheler at cites-gss.com
    Tue Mar 10 12:14:08 CDT 2015
On Tue, 2015-03-10 at 11:35 -0500, Barry Smith wrote:
>    You must call
>   call(PetscDrawSetSave(draw, "matrix", PETSC_FALSE));
>   call(PetscDrawSetSaveFinalImage(draw, "matrix2"));
> BEFORE you view the image.  PetscDrawSetSave() sets the flag to save future images; generally you could this immediately after you've done the PetscViewerDrawOpen
Got it Barry, so now I have:
  call(PetscViewerBinaryOpen(PETSC_COMM_WORLD,file,FILE_MODE_READ,&fd));
  call(MatCreate(PETSC_COMM_WORLD,&A));
  call(MatSetFromOptions(A));
  call(MatLoad(A,fd));
  call(PetscViewerDrawOpen(PETSC_COMM_WORLD, PETSC_NULL, file, 100, 100,
size, size, &viewer));
  call(PetscViewerDrawGetDraw(viewer, 0, &draw));
  call(PetscDrawSetFromOptions(draw));
  call(MatView(A, viewer));
  call(PetscDrawDestroy(&draw));
  call(PetscViewerDestroy(&fd));
  call(MatDestroy(&A));
  call(PetscFinalize());
But now I get this dissapointing message from libafterimage:
gtheler at blinky:~/codigos/mat2img$ ./mat2img -info
[0] PetscInitialize(): PETSc successfully started: number of processors
= 1
[0] PetscGetHostName(): Rejecting domainname, likely is NIS
blinky.(none)
[0] PetscInitialize(): Running on machine: blinky
[0] PetscCommDuplicate(): Duplicating a communicator 1140850688
-2080374784 max tags = 536870911
[0] PetscGetFileStat(): System call stat() succeeded on file matrix.bin
[0] PetscTestOwnership(): System call access() succeeded on file
matrix.bin
[0] PetscFileRetrieve(): Found file matrix.bin
[0] PetscGetFileStat(): System call stat() failed on file
matrix.bin.info
[0] PetscFileRetrieve(): Did not find file matrix.bin.info
[0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
-2080374784
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 20 X 20; storage space: 0
unneeded,58 used
[0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is
0
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 3
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows
0)/(num_localrows 20) < 0.6. Do not use CompressedRow routines.
[0] Mat_CheckInode(): Found 20 nodes out of 20 rows. Not using Inode
routines
-2080374784
[0] PetscDrawSetUpColormap_Shared(): Successfully allocated colors
blinky.(none)
[0] PetscPOpen(): Running command :rm -fr matrix matrix.m4v
blinky.(none)
[0] PetscPOpen(): Running command :mkdir matrix
blinky.(none)
[0] PetscPOpen(): Running command :rm -fr matrix2 matrix2.m4v
blinky.(none)
[0] PetscPOpen(): Running command :mkdir matrix2
unknown ERROR: unable to write file "matrix2/matrix2_0.Gif" - GIF image
format is not supported.
[0] PetscFinalize(): PetscFinalize() called
 Imprima este mensaje sólo si es absolutamente necesario.
Para imprimir, en lo posible utilice el papel de ambos lados.
El Grupo Sancor Seguros se compromete con el cuidado del medioambiente.
************AVISO DE CONFIDENCIALIDAD************
El Grupo Sancor Seguros comunica que:
Este mensaje y todos los archivos adjuntos a el son para uso exclusivo del destinatario y pueden contener información confidencial o propietaria, cuya divulgación es sancionada por ley. Si usted recibió este mensaje erróneamente, por favor notifíquenos respondiendo al remitente, borre el mensaje original y destruya las copias (impresas o grabadas en cualquier medio magnético) que pueda haber realizado del mismo. Todas las opiniones contenidas en este mail son propias del autor del mensaje. La publicación, uso, copia o impresión total o parcial de este mensaje o documentos adjuntos queda prohibida.
Disposición DNDP 10-2008. El titular de los datos personales tiene la facultad de ejercer el derecho de acceso a los mismos en forma gratuita a intervalos no inferiores a seis meses, salvo que acredite un interés legítimo al efecto conforme lo establecido en el artículo 14, inciso 3 de la Ley 25.326. La DIRECCIÓN NACIONAL DE PROTECCIÓN DE DATOS PERSONALES, Organo de Control de la Ley 25.326, tiene la atribución de atender las denuncias y reclamos que se interpongan con relación al incumplimiento de las normas sobre la protección de datos personales.
