[petsc-users] Multigrid preconditioning of entire linear systems for discretized coupled multiphysics problems
Jed Brown
jed at jedbrown.org
Thu Mar 5 16:33:34 CST 2015
Fabian Gabel <gabel.fabian at gmail.com> writes:
> AMG has apparently been used (successfully?) for fully-coupled
> finite-volume discretizations of Navier-Stokes:
> http://dx.doi.org/10.1080/10407790.2014.894448
> http://dx.doi.org/10.1016/j.jcp.2008.08.027
These papers effectively bring a pressure projection or SIMPLE-type
algorithm into a coupled system. It's not a saddle-point formulation
and is not uniformly valid across parameters (I think; methods of this
sort normally aren't, but I haven't analyzed it). The multigrid
algorithm is not described and might not be purely algebraic.
Note that the 2014 paper copies liberally from the 2009 paper.
You can try formulating Navier-Stokes this way and test existing solvers
if you like, but I predict it doesn't come without tradeoffs.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150305/c3d56f37/attachment.pgp>
