[petsc-users] Multigrid preconditioning of entire linear systems for discretized coupled multiphysics problems
Barry Smith
bsmith at mcs.anl.gov
Thu Mar 5 15:26:34 CST 2015
From the abstract: "by using an algebraic multigrid solver." That's like saying "by using an iterative solver"; there are infinite possibilities of algebraic solvers.
You should try using hypre's BoomerAMG algebraic solver ./configure PETSc with --download-hypre and run with -pc_type hypre to list the various boomeramg options run with -help and grep for boomeramg.
Barry
> On Mar 5, 2015, at 3:12 PM, Fabian Gabel <gabel.fabian at gmail.com> wrote:
> On Di, 2015-03-03 at 13:02 -0600, Barry Smith wrote:
>>> On Mar 2, 2015, at 9:19 PM, Fabian Gabel <gabel.fabian at gmail.com> wrote:
>>> On Mo, 2015-03-02 at 19:43 -0600, Barry Smith wrote:
>>>> Do you really want tolerances: relative=1e-90, absolute=1.10423, divergence=10000? That is an absolute tolerance of 1.1? Normally that would be huge.
>>> I started using atol as convergence criterion with -ksp_norm_type
>>> unpreconditioned. The value of atol gets updated every outer iteration.
>> What is the "outer iteration" and why does it exist?
> I used the term "outer iteration" as in Ferziger/Peric "Computational
> Methods for Fluid Dynamics":
> "... there are two levels of iterations: inner iterations, within which
> the linear equations are solved, and outer iterations, that deal with
> the non-linearity and coupling of the equations."
> I chose the Picard-Iteration approach to linearize the non-linear terms
> of the Navier-Stokes equations. The solution process is as follows:
> 1) Update matrix coefficients for the linear system for (u,v,w,p)
> 2) Calculate the norm of the initial residual r^(n):=||b - Ax^(n) ||_2
> 3) if (r^(n)/r(0) <= 1-e8) GOTO 7)
> 4) Calculate atol = 0.1 * r^(n)
> 5) Call KSPSetTolerances with rtol=1e-90 and atol as above and solve the
> coupled linear system for (u,v,w,p)
> 6) GOTO 1)
> 7) END
> With an absolute tolerance for the norm of the unpreconditioned residual
> I feel like I have control over the convergence of the picard iteration.
> Using rtol for the norm of the preconditioned residual did not always
> achieve convergence.
>>>> You can provide your matrix with a block size that GAMG will use with MatSetBlockSize().
>>> I think something went wrong. Setting the block size to 4 and solving
>>> for (u,v,w,p) the convergence degraded significantly. I attached the
>>> results for a smaller test case that shows the increase of the number of
>>> needed inner iterations when setting the block size via
>>> MatSetBlockSize().
>> This is possible.
> Ok, so this concludes the experiments with out-of-the-box GAMG for the
> fully coupled Navier-Stokes System? Why would the GAMG not perform well
> on the linear system resulting from my discretization? What is the
> difference between the algebraic multigrid implemented in PETSc and the
> method used in the paper [1] I mentioned?
> I am still looking for a scalable solver configuration. So far ILU with
> various levels of fill has the best single process performance, but
> scalability could be better. I have been experimenting with different
> PCFIELDSPLIT configurations but the best configuration so far does not
> outperform ILU preconditioning.
> Fabian
> [1] http://dx.doi.org/10.1016/j.jcp.2008.08.027
>> Barry
>>>> I would use coupledsolve_mg_coarse_sub_pc_type lu it is weird that it is using SOR for 27 points.
>>>> So you must have provided a null space since it printed "has attached null space"
>>> The system has indeed a one dimensional null space (from the pressure
>>> equation with Neumann boundary conditions). But now that you mentioned
>>> it: It seems that the outer GMRES doesn't notice that the matrix has an
>>> attached nullspace. Replacing
>>> CALL MatSetNullSpace(CMAT,NULLSP,IERR)
>>> with
>>> CALL KSPSetNullSpace(KRYLOV,NULLSP,IERR)
>>> solves this. What is wrong with using MatSetNullSpace?
>>> Fabian
>>>> Barry
>>>>> On Mar 2, 2015, at 6:39 PM, Fabian Gabel <gabel.fabian at gmail.com> wrote:
>>>>> On Mo, 2015-03-02 at 16:29 -0700, Jed Brown wrote:
>>>>>> Fabian Gabel <gabel.fabian at gmail.com> writes:
>>>>>>> Dear PETSc Team,
>>>>>>> I came across the following paragraph in your publication "Composable
>>>>>>> Linear Solvers for Multiphysics" (2012):
>>>>>>> "Rather than splitting the matrix into large blocks and
>>>>>>> forming a preconditioner from solvers (for example, multi-
>>>>>>> grid) on each block, one can perform multigrid on the entire
>>>>>>> system, basing the smoother on solves coming from the tiny
>>>>>>> blocks coupling the degrees of freedom at a single point (or
>>>>>>> small number of points). This approach is also handled in
>>>>>>> PETSc, but we will not elaborate on it here."
>>>>>>> How would I use a multigrid preconditioner (GAMG)
>>>>>> The heuristics in GAMG are not appropriate for indefinite/saddle-point
>>>>>> systems such as arise from Navier-Stokes. You can use geometric
>>>>>> multigrid and use the fieldsplit techniques described in the paper as a
>>>>>> smoother, for example.
>>>>> I sadly don't have a solid background on multigrid methods, but as
>>>>> mentioned in a previous thread
>>>>> http://lists.mcs.anl.gov/pipermail/petsc-users/2015-February/024219.html
>>>>> AMG has apparently been used (successfully?) for fully-coupled
>>>>> finite-volume discretizations of Navier-Stokes:
>>>>> http://dx.doi.org/10.1080/10407790.2014.894448
>>>>> I was hoping to achieve something similar with the right configuration
>>>>> of the PETSc preconditioners. So far I have only been using GAMG in a
>>>>> straightforward manner, without providing any details on the structure
>>>>> of the linear system. I attached the output of a test run with GAMG.
>>>>>>> from PETSc on linear systems of the form (after reordering the
>>>>>>> variables):
>>>>>>> [A_uu 0 0 A_up A_uT]
>>>>>>> [0 A_vv 0 A_vp A_vT]
>>>>>>> [0 0 A_ww A_up A_wT]
>>>>>>> [A_pu A_pv A_pw A_pp 0 ]
>>>>>>> [A_Tu A_Tv A_Tw A_Tp A_TT]
>>>>>>> where each of the block matrices A_ij, with i,j in {u,v,w,p,T}, results
>>>>>>> directly from a FVM discretization of the incompressible Navier-Stokes
>>>>>>> equations and the temperature equation. The fifth row and column are
>>>>>>> optional, depending on the method I choose to couple the temperature.
>>>>>>> The Matrix is stored as one AIJ Matrix.
>>>>>>> Regards,
>>>>>>> Fabian Gabel
>>>>> <cpld_0128.out.578677>
>>> <log.blocksize4><log.txt>
