[petsc-users] how to switch ILU to its block version?
Fande Kong
fd.kong at siat.ac.cn
Sun Mar 1 17:03:18 CST 2015
Thanks, Matt.
Could bs be different from rows. I am solving a fluid-structure problem,
which has different bs in fluid and solid parts.
Fande,
On Sun, Mar 1, 2015 at 3:57 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Mar 1, 2015 at 4:55 PM, Fande Kong <fd.kong at siat.ac.cn> wrote:
>> Thanks, Barry.
>> More questions. Is bs usually the number of unknowns associated with a
>> grid point. Do I need to change MatSetValues if use a MATSEQBAIJ matrix?
> No, but it does enable you to use MatSetValuesBlock() if you want.
> Matt
>> Fande,
>> On Sun, Mar 1, 2015 at 2:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> Fande,
>>> The MATSEQBAIJ matrix automatically uses a point block ILU; with the
>>> block size of the matrix. So if your matrix naturally has a block size bs
>>> if you use the MATSEQBAIJ matrix type it will be point block ILU of block
>>> size bs.
>>> We don't have a variable point block ILU in PETSc for SeqAIJ. It is
>>> possible to write but would be rather involved.
>>> Barry
>>> > On Mar 1, 2015, at 1:47 PM, Fande Kong <fd.kong at siat.ac.cn> wrote:
>>> > Hi all,
>>> > I have a code with ILU as subdomain solver, and it works well. Now I
>>> want to try a block version of ILU, there are some easy ways to implement
>>> this?
>>> > Fande,
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150301/41a8180c/attachment.html>
