[petsc-users] how to switch ILU to its block version?
Sun Mar 1 16:57:02 CST 2015
On Sun, Mar 1, 2015 at 4:55 PM, Fande Kong <fd.kong at siat.ac.cn> wrote:
> Thanks, Barry.
> More questions. Is bs usually the number of unknowns associated with a
> grid point. Do I need to change MatSetValues if use a MATSEQBAIJ matrix?
No, but it does enable you to use MatSetValuesBlock() if you want.
   Matt
> Fande,
> On Sun, Mar 1, 2015 at 2:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   Fande,
>>     The MATSEQBAIJ matrix automatically uses a point block ILU; with the
>> block size of the matrix. So if your matrix naturally has a block size bs
>> if you use the MATSEQBAIJ matrix type it will be point block ILU of block
>> size bs.
>>     We don't have a variable point block ILU in PETSc for SeqAIJ. It is
>> possible to write but would be rather involved.
>>    Barry
>> > On Mar 1, 2015, at 1:47 PM, Fande Kong <fd.kong at siat.ac.cn> wrote:
>> > Hi all,
>> > I have a code with ILU as subdomain solver, and it works well. Now I
>> want to try a block version of ILU, there are some easy ways to implement
>> this?
>> > Fande,
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150301/7a9a9aac/attachment.html>
