[petsc-users] how to switch ILU to its block version?
Sun Mar 1 17:43:54 CST 2015
On Sun, Mar 1, 2015 at 5:03 PM, Fande Kong <fd.kong at siat.ac.cn> wrote:
> Thanks, Matt.
> Could bs be different from rows. I am solving a fluid-structure problem,
> which has different bs in fluid and solid parts.
I think you are asking about variable block size in the matrix. We do not
support that.
     Matt
> Fande,
> On Sun, Mar 1, 2015 at 3:57 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, Mar 1, 2015 at 4:55 PM, Fande Kong <fd.kong at siat.ac.cn> wrote:
>>> Thanks, Barry.
>>> More questions. Is bs usually the number of unknowns associated with a
>>> grid point. Do I need to change MatSetValues if use a MATSEQBAIJ matrix?
>> No, but it does enable you to use MatSetValuesBlock() if you want.
>>    Matt
>>> Fande,
>>> On Sun, Mar 1, 2015 at 2:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>   Fande,
>>>>     The MATSEQBAIJ matrix automatically uses a point block ILU; with
>>>> the block size of the matrix. So if your matrix naturally has a block size
>>>> bs if you use the MATSEQBAIJ matrix type it will be point block ILU of
>>>> block size bs.
>>>>     We don't have a variable point block ILU in PETSc for SeqAIJ. It is
>>>> possible to write but would be rather involved.
>>>>    Barry
>>>> > On Mar 1, 2015, at 1:47 PM, Fande Kong <fd.kong at siat.ac.cn> wrote:
>>>> > Hi all,
>>>> > I have a code with ILU as subdomain solver, and it works well. Now I
>>>> want to try a block version of ILU, there are some easy ways to implement
>>>> this?
>>>> > Fande,
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150301/c1966df2/attachment.html>
