[petsc-users] how to switch ILU to its block version?
Fande Kong fd.kong at siat.ac.cn
Sun Mar 1 16:55:58 CST 2015
Thanks, Barry.
More questions. Is bs usually the number of unknowns associated with a grid
point. Do I need to change MatSetValues if use a MATSEQBAIJ matrix?
Fande,
On Sun, Mar 1, 2015 at 2:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Fande,
>     The MATSEQBAIJ matrix automatically uses a point block ILU; with the
> block size of the matrix. So if your matrix naturally has a block size bs
> if you use the MATSEQBAIJ matrix type it will be point block ILU of block
> size bs.
>     We don't have a variable point block ILU in PETSc for SeqAIJ. It is
> possible to write but would be rather involved.
>    Barry
> > On Mar 1, 2015, at 1:47 PM, Fande Kong <fd.kong at siat.ac.cn> wrote:
> > Hi all,
> > I have a code with ILU as subdomain solver, and it works well. Now I
> want to try a block version of ILU, there are some easy ways to implement
> this?
> > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150301/3d1026da/attachment-0001.html>
