[petsc-users] Order of PetscRandom and SVD
    Jose E. Roman
    jroman at dsic.upv.es
    Tue Jun 30 16:43:20 CDT 2015
SLEPc solvers use a PetscRandom object internally, and may generate a different sequence of random values in each process.
Jose
> El 30/6/2015, a las 23:05, Torquil Macdonald Sørensen <torquil at gmail.com> escribió:
> Hi!
> I'm experiencing some problems using PetscRandom and SVD from SLEPc. For
> some reason, the order of two seemingly unrelated  parts of the program
> below affects the random values in a vector. The test program below, run
> with "mpiexec -n 2", will print a vector with two identical component
> values. If I move the four lines of SVD code up above "PetscRandom r",
> the two vector component are different, as expected. Why does this
> matter, when the SVD code is unrelated to the PetscRandom r and Vec u?
> #include "petscdmda.h"
> #include "slepcsvd.h"
> int main(int argc, char **argv)
>    PetscErrorCode ierr = SlepcInitialize(&argc, &argv, 0, 0);
> CHKERRQ(ierr);
>    DM da;
>    ierr = DMDACreate1d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE, 2, 1, 1, 0,
> &da); CHKERRQ(ierr);
>    ierr = DMSetFromOptions(da); CHKERRQ(ierr);
>    Vec u;
>    ierr = DMCreateGlobalVector(da, &u); CHKERRQ(ierr);
>    PetscRandom r;
>    ierr = PetscRandomCreate(PETSC_COMM_WORLD, &r); CHKERRQ(ierr);
>    ierr = PetscRandomSetFromOptions(r);
>    SVD svd;
>    ierr = SVDCreate(PETSC_COMM_WORLD, &svd); CHKERRQ(ierr);
>    ierr = SVDSetFromOptions(svd); CHKERRQ(ierr);
>    ierr = SVDDestroy(&svd); CHKERRQ(ierr);
>    ierr = VecSetRandom(u, r); CHKERRQ(ierr);
>    ierr = VecView(u, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
>    ierr = PetscRandomDestroy(&r); CHKERRQ(ierr);
>    ierr = VecDestroy(&u); CHKERRQ(ierr);
>    ierr = DMDestroy(&da); CHKERRQ(ierr);
>    ierr = SlepcFinalize(); CHKERRQ(ierr);
>    return 0;
> Output of the program as written above:
> Vec Object: 2 MPI processes
>  type: mpi
> Vec Object:Vec_0xd00a30_0 2 MPI processes
>  type: mpi
> Process [0]
> 0.720032 + 0.061794 i
> Process [1]
> Output of the program with the four lines of SVD code moved above the
> line "PetscRandom r":
>  type: mpi
> Vec Object:Vec_0x117aa30_0 2 MPI processes
>  type: mpi
> Process [0]
> Process [1]
> 0.541144 + 0.529699 i
> Other information:
> $ gcc --version
> gcc (Debian 5.1.1-12) 5.1.1 20150622
> The PETSc version was obtained with the command:
> git checkout 75ae60a9cdad23ddd49e9e39341b43db353bd940
> because the newest GIT version wouldn't compile. SLEPc is the newest
> from the master branch. The -log_summary output of the program is:
> ---------------------------------------------- PETSc Performance
> Summary: ----------------------------------------------
> ./randtest.exe on a arch-linux2-c-debug named lenovo with 2 processors,
> by tmac Tue Jun 30 22:42:49 2015
> Using Petsc Development GIT revision: v3.6-89-g75ae60a  GIT Date:
> 2015-06-29 18:37:23 -0500
>                         Max       Max/Min        Avg      Total
> Time (sec):           1.274e-02      1.00000   1.274e-02
> Objects:              3.900e+01      1.00000   3.900e+01
> Flops:                0.000e+00      0.00000   0.000e+00  0.000e+00
> Flops/sec:            0.000e+00      0.00000   0.000e+00  0.000e+00
> Memory:               1.273e+05      1.00000              2.546e+05
> MPI Messages:         6.500e+00      1.00000   6.500e+00  1.300e+01
> MPI Message Lengths:  3.600e+01      1.00000   5.538e+00  7.200e+01
> MPI Reductions:       9.000e+01      1.00000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
>                            e.g., VecAXPY() for real vectors of length N
> --> 2N flops
>                            and VecAXPY() for complex vectors of length
> N --> 8N flops
> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
> ---  -- Message Lengths --  -- Reductions --
>                        Avg     %Total     Avg     %Total   counts
> %Total     Avg         %Total   counts   %Total
> 0:      Main Stage: 1.2723e-02  99.9%  0.0000e+00   0.0%  1.300e+01
> 100.0%  5.538e+00      100.0%  8.900e+01  98.9%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
>   Count: number of times phase was executed
>   Time and Flops: Max - maximum over all processors
>                   Ratio - ratio of maximum to minimum over all processors
>   Mess: number of messages sent
>   Avg. len: average message length (bytes)
>   Reduct: number of global reductions
>   Global: entire computation
>   Stage: stages of a computation. Set stages with PetscLogStagePush()
> and PetscLogStagePop().
>      %T - percent time in this phase         %F - percent flops in this
> phase
>      %M - percent messages in this phase     %L - percent message
> lengths in this phase
>      %R - percent reductions in this phase
>   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
>      #                          WARNING!!!                    #
>      #   This code was compiled with a debugging option,      #
>      #   To get timing results run ./configure                #
>      #   using --with-debugging=no, the performance will      #
>      #   be generally two or three times faster.              #
>      #                          WARNING!!!                    #
>      #   The code for various complex numbers numerical       #
>      #   kernels uses C++, which generally is not well        #
>      #   optimized.  For performance that is about 4-5 times  #
>      #   faster, specify --with-fortran-kernels=1             #
>      #   when running ./configure.py.                         #
> Event                Count      Time (sec)
> Flops                             --- Global ---  --- Stage ---   Total
>                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> VecView                1 1.0 1.0881e-03 1.2 0.00e+00 0.0 5.0e+00 8.0e+00
> 1.5e+01  8  0 38 56 17   8  0 38 56 17     0
> VecSet                 1 1.0 1.5020e-05 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecScatterBegin        1 1.0 2.1935e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecScatterEnd          1 1.0 7.1526e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecSetRandom           1 1.0 1.6928e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyBegin       1 1.0 8.4877e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+00  1  0  0  0  2   1  0  0  0  2     0
> MatAssemblyEnd         1 1.0 6.7306e-04 1.0 0.00e+00 0.0 4.0e+00 4.0e+00
> 1.4e+01  5  0 31 22 16   5  0 31 22 16     0
> Memory usage is given in bytes:
> Object Type          Creations   Destructions     Memory  Descendants' Mem.
> Reports information only for process 0.
>              Vector     7              7        11064     0
>      Vector Scatter     3              3         3280     0
>              Matrix     3              3         8064     0
>    Distributed Mesh     1              1         4972     0
> Star Forest Bipartite Graph     2              2         1712     0
>     Discrete System     1              1          848     0
>           Index Set     6              6         4660     0
>   IS L to G Mapping     1              1          632     0
>         PetscRandom     3              3         1920     0
>          SVD Solver     1              1          984     0
>          EPS Solver     1              1         1272     0
>  Spectral Transform     1              1          784     0
>       Krylov Solver     1              1         1304     0
>      Preconditioner     1              1          848     0
>       Basis Vectors     3              3         3024     0
>       Direct Solver     2              2         2640     0
>              Region     1              1          648     0
>              Viewer     1              0            0     0
> Average time to get PetscTime(): 9.53674e-08
> Average time for MPI_Barrier(): 1.43051e-06
> Average time for zero size MPI_Send(): 4.52995e-06
> #PETSc Option Table entries:
> -ksp_converged_reason
> -log_summary
> -objects_dump 0
> -options_table
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 16 sizeof(PetscInt) 4
> Configure options: --prefix=/home/tmac/usr/stow/petsc
> --with-scalar-type=complex --with-shared-libraries=yes
> --with-debugging=yes --download-superlu=yes --download-ptscotch=yes
> --with-sowing=no --download-sowing=no
> Libraries compiled on Tue Jun 30 20:18:19 2015 on lenovo
> Machine characteristics: Linux-4.0.0-2-amd64-x86_64-with-debian-stretch-sid
> Using PETSc directory: /home/tmac/tmp/src/petsc
> Using PETSc arch: arch-linux2-c-debug
> Using C compiler: mpicc  -fPIC -Wall -Wwrite-strings
> -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  ${COPTFLAGS} ${CFLAGS}
> Using Fortran compiler: mpif90  -fPIC -Wall -Wno-unused-variable
> -ffree-line-length-0 -g -O0   ${FOPTFLAGS} ${FFLAGS}
> Using include paths:
> -I/home/tmac/tmp/src/petsc/arch-linux2-c-debug/include
> -I/home/tmac/tmp/src/petsc/include -I/home/tmac/tmp/src/petsc/include
> -I/home/tmac/usr/stow/petsc/include -I/usr/lib/openmpi/include
> -I/usr/lib/openmpi/include/openmpi
> Using C linker: mpicc
> Using Fortran linker: mpif90
> Using libraries:
> -Wl,-rpath,/home/tmac/tmp/src/petsc/arch-linux2-c-debug/lib
> -L/home/tmac/tmp/src/petsc/arch-linux2-c-debug/lib -lpetsc
> -Wl,-rpath,/home/tmac/usr/stow/petsc/lib -L/home/tmac/usr/stow/petsc/lib
> -lsuperlu_4.3 -llapack -lblas -lptesmumps -lptscotch -lptscotcherr
> -lscotch -lscotcherr -lX11 -lssl -lcrypto -lm
> -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5
> -L/usr/lib/gcc/x86_64-linux-gnu/5 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
> -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
> -L/lib/x86_64-linux-gnu -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran
> -lm -lquadmath -lm -lmpi_cxx -lstdc++ -lrt -lm -lz
> -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu
> -L/usr/lib/x86_64-linux-gnu -ldl -lmpi -lhwloc -lgcc_s -lpthread -ldl
> Best regards
> Torquil Sørensen
