[petsc-users] Order of PetscRandom and SVD
Torquil Macdonald Sørensen
torquil at gmail.com
Tue Jun 30 17:42:12 CDT 2015
Thanks. So what can I do to create a PetscRandom object that is not
affected by the SLEPc-functions that I'm calling?
Best regards,
Torquil Sørensen
On 30/06/15 23:43, Jose E. Roman wrote:
> SLEPc solvers use a PetscRandom object internally, and may generate a different sequence of random values in each process.
> Jose
>> El 30/6/2015, a las 23:05, Torquil Macdonald Sørensen <torquil at gmail.com> escribió:
>> Hi!
>> I'm experiencing some problems using PetscRandom and SVD from SLEPc. For
>> some reason, the order of two seemingly unrelated parts of the program
>> below affects the random values in a vector. The test program below, run
>> with "mpiexec -n 2", will print a vector with two identical component
>> values. If I move the four lines of SVD code up above "PetscRandom r",
>> the two vector component are different, as expected. Why does this
>> matter, when the SVD code is unrelated to the PetscRandom r and Vec u?
>> #include "petscdmda.h"
>> #include "slepcsvd.h"
>> int main(int argc, char **argv)
>> PetscErrorCode ierr = SlepcInitialize(&argc, &argv, 0, 0);
>> CHKERRQ(ierr);
>> DM da;
>> ierr = DMDACreate1d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE, 2, 1, 1, 0,
>> &da); CHKERRQ(ierr);
>> ierr = DMSetFromOptions(da); CHKERRQ(ierr);
>> Vec u;
>> ierr = DMCreateGlobalVector(da, &u); CHKERRQ(ierr);
>> PetscRandom r;
>> ierr = PetscRandomCreate(PETSC_COMM_WORLD, &r); CHKERRQ(ierr);
>> ierr = PetscRandomSetFromOptions(r);
>> SVD svd;
>> ierr = SVDCreate(PETSC_COMM_WORLD, &svd); CHKERRQ(ierr);
>> ierr = SVDSetFromOptions(svd); CHKERRQ(ierr);
>> ierr = SVDDestroy(&svd); CHKERRQ(ierr);
>> ierr = VecSetRandom(u, r); CHKERRQ(ierr);
>> ierr = VecView(u, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
>> ierr = PetscRandomDestroy(&r); CHKERRQ(ierr);
>> ierr = VecDestroy(&u); CHKERRQ(ierr);
>> ierr = DMDestroy(&da); CHKERRQ(ierr);
>> ierr = SlepcFinalize(); CHKERRQ(ierr);
>> return 0;
>> Output of the program as written above:
>> Vec Object: 2 MPI processes
>> type: mpi
>> Vec Object:Vec_0xd00a30_0 2 MPI processes
>> type: mpi
>> Process [0]
>> 0.720032 + 0.061794 i
>> Process [1]
>> Output of the program with the four lines of SVD code moved above the
>> line "PetscRandom r":
>> type: mpi
>> Vec Object:Vec_0x117aa30_0 2 MPI processes
>> type: mpi
>> Process [0]
>> Process [1]
>> 0.541144 + 0.529699 i
>> Other information:
>> $ gcc --version
>> gcc (Debian 5.1.1-12) 5.1.1 20150622
>> The PETSc version was obtained with the command:
>> git checkout 75ae60a9cdad23ddd49e9e39341b43db353bd940
>> because the newest GIT version wouldn't compile. SLEPc is the newest
>> from the master branch. The -log_summary output of the program is:
>> ---------------------------------------------- PETSc Performance
>> Summary: ----------------------------------------------
>> ./randtest.exe on a arch-linux2-c-debug named lenovo with 2 processors,
>> by tmac Tue Jun 30 22:42:49 2015
>> Using Petsc Development GIT revision: v3.6-89-g75ae60a GIT Date:
>> 2015-06-29 18:37:23 -0500
>> Max Max/Min Avg Total
>> Time (sec): 1.274e-02 1.00000 1.274e-02
>> Objects: 3.900e+01 1.00000 3.900e+01
>> Flops: 0.000e+00 0.00000 0.000e+00 0.000e+00
>> Flops/sec: 0.000e+00 0.00000 0.000e+00 0.000e+00
>> Memory: 1.273e+05 1.00000 2.546e+05
>> MPI Messages: 6.500e+00 1.00000 6.500e+00 1.300e+01
>> MPI Message Lengths: 3.600e+01 1.00000 5.538e+00 7.200e+01
>> MPI Reductions: 9.000e+01 1.00000
>> Flop counting convention: 1 flop = 1 real number operation of type
>> (multiply/divide/add/subtract)
>> e.g., VecAXPY() for real vectors of length N
>> --> 2N flops
>> and VecAXPY() for complex vectors of length
>> N --> 8N flops
>> Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages
>> --- -- Message Lengths -- -- Reductions --
>> Avg %Total Avg %Total counts
>> %Total Avg %Total counts %Total
>> 0: Main Stage: 1.2723e-02 99.9% 0.0000e+00 0.0% 1.300e+01
>> 100.0% 5.538e+00 100.0% 8.900e+01 98.9%
>> See the 'Profiling' chapter of the users' manual for details on
>> interpreting output.
>> Phase summary info:
>> Count: number of times phase was executed
>> Time and Flops: Max - maximum over all processors
>> Ratio - ratio of maximum to minimum over all processors
>> Mess: number of messages sent
>> Avg. len: average message length (bytes)
>> Reduct: number of global reductions
>> Global: entire computation
>> Stage: stages of a computation. Set stages with PetscLogStagePush()
>> and PetscLogStagePop().
>> %T - percent time in this phase %F - percent flops in this
>> phase
>> %M - percent messages in this phase %L - percent message
>> lengths in this phase
>> %R - percent reductions in this phase
>> Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
>> # WARNING!!! #
>> # This code was compiled with a debugging option, #
>> # To get timing results run ./configure #
>> # using --with-debugging=no, the performance will #
>> # be generally two or three times faster. #
>> # WARNING!!! #
>> # The code for various complex numbers numerical #
>> # kernels uses C++, which generally is not well #
>> # optimized. For performance that is about 4-5 times #
>> # faster, specify --with-fortran-kernels=1 #
>> # when running ./configure.py. #
>> Event Count Time (sec)
>> Flops --- Global --- --- Stage --- Total
>> Max Ratio Max Ratio Max Ratio Mess Avg len
>> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
>> --- Event Stage 0: Main Stage
>> VecView 1 1.0 1.0881e-03 1.2 0.00e+00 0.0 5.0e+00 8.0e+00
>> 1.5e+01 8 0 38 56 17 8 0 38 56 17 0
>> VecSet 1 1.0 1.5020e-05 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecScatterBegin 1 1.0 2.1935e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecScatterEnd 1 1.0 7.1526e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecSetRandom 1 1.0 1.6928e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatAssemblyBegin 1 1.0 8.4877e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
>> 2.0e+00 1 0 0 0 2 1 0 0 0 2 0
>> MatAssemblyEnd 1 1.0 6.7306e-04 1.0 0.00e+00 0.0 4.0e+00 4.0e+00
>> 1.4e+01 5 0 31 22 16 5 0 31 22 16 0
>> Memory usage is given in bytes:
>> Object Type Creations Destructions Memory Descendants' Mem.
>> Reports information only for process 0.
>> Vector 7 7 11064 0
>> Vector Scatter 3 3 3280 0
>> Matrix 3 3 8064 0
>> Distributed Mesh 1 1 4972 0
>> Star Forest Bipartite Graph 2 2 1712 0
>> Discrete System 1 1 848 0
>> Index Set 6 6 4660 0
>> IS L to G Mapping 1 1 632 0
>> PetscRandom 3 3 1920 0
>> SVD Solver 1 1 984 0
>> EPS Solver 1 1 1272 0
>> Spectral Transform 1 1 784 0
>> Krylov Solver 1 1 1304 0
>> Preconditioner 1 1 848 0
>> Basis Vectors 3 3 3024 0
>> Direct Solver 2 2 2640 0
>> Region 1 1 648 0
>> Viewer 1 0 0 0
>> Average time to get PetscTime(): 9.53674e-08
>> Average time for MPI_Barrier(): 1.43051e-06
>> Average time for zero size MPI_Send(): 4.52995e-06
>> #PETSc Option Table entries:
>> -ksp_converged_reason
>> -log_summary
>> -objects_dump 0
>> -options_table
>> #End of PETSc Option Table entries
>> Compiled without FORTRAN kernels
>> Compiled with full precision matrices (default)
>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>> sizeof(PetscScalar) 16 sizeof(PetscInt) 4
>> Configure options: --prefix=/home/tmac/usr/stow/petsc
>> --with-scalar-type=complex --with-shared-libraries=yes
>> --with-debugging=yes --download-superlu=yes --download-ptscotch=yes
>> --with-sowing=no --download-sowing=no
>> Libraries compiled on Tue Jun 30 20:18:19 2015 on lenovo
>> Machine characteristics: Linux-4.0.0-2-amd64-x86_64-with-debian-stretch-sid
>> Using PETSc directory: /home/tmac/tmp/src/petsc
>> Using PETSc arch: arch-linux2-c-debug
>> Using C compiler: mpicc -fPIC -Wall -Wwrite-strings
>> -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 ${COPTFLAGS} ${CFLAGS}
>> Using Fortran compiler: mpif90 -fPIC -Wall -Wno-unused-variable
>> -ffree-line-length-0 -g -O0 ${FOPTFLAGS} ${FFLAGS}
>> Using include paths:
>> -I/home/tmac/tmp/src/petsc/arch-linux2-c-debug/include
>> -I/home/tmac/tmp/src/petsc/include -I/home/tmac/tmp/src/petsc/include
>> -I/home/tmac/usr/stow/petsc/include -I/usr/lib/openmpi/include
>> -I/usr/lib/openmpi/include/openmpi
>> Using C linker: mpicc
>> Using Fortran linker: mpif90
>> Using libraries:
>> -Wl,-rpath,/home/tmac/tmp/src/petsc/arch-linux2-c-debug/lib
>> -L/home/tmac/tmp/src/petsc/arch-linux2-c-debug/lib -lpetsc
>> -Wl,-rpath,/home/tmac/usr/stow/petsc/lib -L/home/tmac/usr/stow/petsc/lib
>> -lsuperlu_4.3 -llapack -lblas -lptesmumps -lptscotch -lptscotcherr
>> -lscotch -lscotcherr -lX11 -lssl -lcrypto -lm
>> -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
>> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5
>> -L/usr/lib/gcc/x86_64-linux-gnu/5 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
>> -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
>> -L/lib/x86_64-linux-gnu -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran
>> -lm -lquadmath -lm -lmpi_cxx -lstdc++ -lrt -lm -lz
>> -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu
>> -L/usr/lib/x86_64-linux-gnu -ldl -lmpi -lhwloc -lgcc_s -lpthread -ldl
>> Best regards
>> Torquil Sørensen
