[petsc-users] Order of PetscRandom and SVD
Torquil Macdonald Sørensen
torquil at gmail.com
Tue Jun 30 16:05:17 CDT 2015
Hi!
I'm experiencing some problems using PetscRandom and SVD from SLEPc. For
some reason, the order of two seemingly unrelated parts of the program
below affects the random values in a vector. The test program below, run
with "mpiexec -n 2", will print a vector with two identical component
values. If I move the four lines of SVD code up above "PetscRandom r",
the two vector component are different, as expected. Why does this
matter, when the SVD code is unrelated to the PetscRandom r and Vec u?
#include "petscdmda.h"
#include "slepcsvd.h"
int main(int argc, char **argv)
PetscErrorCode ierr = SlepcInitialize(&argc, &argv, 0, 0);
CHKERRQ(ierr);
DM da;
ierr = DMDACreate1d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE, 2, 1, 1, 0,
&da); CHKERRQ(ierr);
ierr = DMSetFromOptions(da); CHKERRQ(ierr);
Vec u;
ierr = DMCreateGlobalVector(da, &u); CHKERRQ(ierr);
PetscRandom r;
ierr = PetscRandomCreate(PETSC_COMM_WORLD, &r); CHKERRQ(ierr);
ierr = PetscRandomSetFromOptions(r);
SVD svd;
ierr = SVDCreate(PETSC_COMM_WORLD, &svd); CHKERRQ(ierr);
ierr = SVDSetFromOptions(svd); CHKERRQ(ierr);
ierr = SVDDestroy(&svd); CHKERRQ(ierr);
ierr = VecSetRandom(u, r); CHKERRQ(ierr);
ierr = VecView(u, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
ierr = PetscRandomDestroy(&r); CHKERRQ(ierr);
ierr = VecDestroy(&u); CHKERRQ(ierr);
ierr = DMDestroy(&da); CHKERRQ(ierr);
ierr = SlepcFinalize(); CHKERRQ(ierr);
return 0;
Output of the program as written above:
Vec Object: 2 MPI processes
type: mpi
Vec Object:Vec_0xd00a30_0 2 MPI processes
type: mpi
Process [0]
0.720032 + 0.061794 i
Process [1]
Output of the program with the four lines of SVD code moved above the
line "PetscRandom r":
type: mpi
Vec Object:Vec_0x117aa30_0 2 MPI processes
type: mpi
Process [0]
Process [1]
0.541144 + 0.529699 i
Other information:
$ gcc --version
gcc (Debian 5.1.1-12) 5.1.1 20150622
The PETSc version was obtained with the command:
git checkout 75ae60a9cdad23ddd49e9e39341b43db353bd940
because the newest GIT version wouldn't compile. SLEPc is the newest
from the master branch. The -log_summary output of the program is:
---------------------------------------------- PETSc Performance
Summary: ----------------------------------------------
./randtest.exe on a arch-linux2-c-debug named lenovo with 2 processors,
by tmac Tue Jun 30 22:42:49 2015
Using Petsc Development GIT revision: v3.6-89-g75ae60a GIT Date:
2015-06-29 18:37:23 -0500
Max Max/Min Avg Total
Time (sec): 1.274e-02 1.00000 1.274e-02
Objects: 3.900e+01 1.00000 3.900e+01
Flops: 0.000e+00 0.00000 0.000e+00 0.000e+00
Flops/sec: 0.000e+00 0.00000 0.000e+00 0.000e+00
Memory: 1.273e+05 1.00000 2.546e+05
MPI Messages: 6.500e+00 1.00000 6.500e+00 1.300e+01
MPI Message Lengths: 3.600e+01 1.00000 5.538e+00 7.200e+01
MPI Reductions: 9.000e+01 1.00000
Flop counting convention: 1 flop = 1 real number operation of type
(multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N
--> 2N flops
and VecAXPY() for complex vectors of length
N --> 8N flops
Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages
--- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts
%Total Avg %Total counts %Total
0: Main Stage: 1.2723e-02 99.9% 0.0000e+00 0.0% 1.300e+01
100.0% 5.538e+00 100.0% 8.900e+01 98.9%
See the 'Profiling' chapter of the users' manual for details on
interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flops: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length (bytes)
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush()
and PetscLogStagePop().
%T - percent time in this phase %F - percent flops in this
phase
%M - percent messages in this phase %L - percent message
lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
# WARNING!!! #
# This code was compiled with a debugging option, #
# To get timing results run ./configure #
# using --with-debugging=no, the performance will #
# be generally two or three times faster. #
# WARNING!!! #
# The code for various complex numbers numerical #
# kernels uses C++, which generally is not well #
# optimized. For performance that is about 4-5 times #
# faster, specify --with-fortran-kernels=1 #
# when running ./configure.py. #
Event Count Time (sec)
Flops --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len
Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecView 1 1.0 1.0881e-03 1.2 0.00e+00 0.0 5.0e+00 8.0e+00
1.5e+01 8 0 38 56 17 8 0 38 56 17 0
VecSet 1 1.0 1.5020e-05 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 1 1.0 2.1935e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecScatterEnd 1 1.0 7.1526e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecSetRandom 1 1.0 1.6928e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatAssemblyBegin 1 1.0 8.4877e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
2.0e+00 1 0 0 0 2 1 0 0 0 2 0
MatAssemblyEnd 1 1.0 6.7306e-04 1.0 0.00e+00 0.0 4.0e+00 4.0e+00
1.4e+01 5 0 31 22 16 5 0 31 22 16 0
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Vector 7 7 11064 0
Vector Scatter 3 3 3280 0
Matrix 3 3 8064 0
Distributed Mesh 1 1 4972 0
Star Forest Bipartite Graph 2 2 1712 0
Discrete System 1 1 848 0
Index Set 6 6 4660 0
IS L to G Mapping 1 1 632 0
PetscRandom 3 3 1920 0
SVD Solver 1 1 984 0
EPS Solver 1 1 1272 0
Spectral Transform 1 1 784 0
Krylov Solver 1 1 1304 0
Preconditioner 1 1 848 0
Basis Vectors 3 3 3024 0
Direct Solver 2 2 2640 0
Region 1 1 648 0
Viewer 1 0 0 0
Average time to get PetscTime(): 9.53674e-08
Average time for MPI_Barrier(): 1.43051e-06
Average time for zero size MPI_Send(): 4.52995e-06
#PETSc Option Table entries:
-ksp_converged_reason
-log_summary
-objects_dump 0
-options_table
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 16 sizeof(PetscInt) 4
Configure options: --prefix=/home/tmac/usr/stow/petsc
--with-scalar-type=complex --with-shared-libraries=yes
--with-debugging=yes --download-superlu=yes --download-ptscotch=yes
--with-sowing=no --download-sowing=no
Libraries compiled on Tue Jun 30 20:18:19 2015 on lenovo
Machine characteristics: Linux-4.0.0-2-amd64-x86_64-with-debian-stretch-sid
Using PETSc directory: /home/tmac/tmp/src/petsc
Using PETSc arch: arch-linux2-c-debug
Using C compiler: mpicc -fPIC -Wall -Wwrite-strings
-Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90 -fPIC -Wall -Wno-unused-variable
-ffree-line-length-0 -g -O0 ${FOPTFLAGS} ${FFLAGS}
Using include paths:
-I/home/tmac/tmp/src/petsc/arch-linux2-c-debug/include
-I/home/tmac/tmp/src/petsc/include -I/home/tmac/tmp/src/petsc/include
-I/home/tmac/usr/stow/petsc/include -I/usr/lib/openmpi/include
-I/usr/lib/openmpi/include/openmpi
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries:
-Wl,-rpath,/home/tmac/tmp/src/petsc/arch-linux2-c-debug/lib
-L/home/tmac/tmp/src/petsc/arch-linux2-c-debug/lib -lpetsc
-Wl,-rpath,/home/tmac/usr/stow/petsc/lib -L/home/tmac/usr/stow/petsc/lib
-lsuperlu_4.3 -llapack -lblas -lptesmumps -lptscotch -lptscotcherr
-lscotch -lscotcherr -lX11 -lssl -lcrypto -lm
-Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5
-L/usr/lib/gcc/x86_64-linux-gnu/5 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
-L/lib/x86_64-linux-gnu -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran
-lm -lquadmath -lm -lmpi_cxx -lstdc++ -lrt -lm -lz
-L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -ldl -lmpi -lhwloc -lgcc_s -lpthread -ldl
Best regards
Torquil Sørensen
