[petsc-users] petsc4py Build Problem
    Satish Balay
    balay at mcs.anl.gov
    Wed Jun 24 21:14:46 CDT 2015
Perhaps the issue is petsc-3.5. We tried this petsc-3.6 - and that
worked fine..
Satish
On Wed, 24 Jun 2015, Mikhail Khodak wrote:
> Yes, the variables are defined. Using setup.py gives the same error.
> As a note, I am using a download of the master branch.
> Mikhail Khodak
> On Wed, Jun 24, 2015 at 7:15 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> > On 23 June 2015 at 12:15, Mikhail Khodak <mkhodak at princeton.edu> wrote:
> > > Thank you for reviewing this. The errors for the command 'pip2 install .'
> > > inside the petsc4py directory are attached, along with the configure/make
> > > logs for the PETSc build.
> > > Best,
> > > Mikhail Khodak
> > Not sure what's going on.
> > Do you have PETSC_DIR and PETSC_ARCH in your environment?
> > Does it work if you just do "python setup.py build" ?
> > Lisandro Dalcin
> > Research Scientist
> > Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> > Numerical Porous Media Center (NumPor)
> > King Abdullah University of Science and Technology (KAUST)
> > http://numpor.kaust.edu.sa/
> > 4700 King Abdullah University of Science and Technology
> > al-Khawarizmi Bldg (Bldg 1), Office # 4332
> > Thuwal 23955-6900, Kingdom of Saudi Arabia
> > http://www.kaust.edu.sa
> > Office Phone: +966 12 808-0459
