[petsc-users] petsc4py Build Problem
    Mikhail Khodak
    mkhodak at princeton.edu
    Wed Jun 24 21:47:47 CDT 2015
That was it. Installed with 3.6.0 and all tests passed.
Thank you both for the help.
Mikhail Khodak
On Wed, Jun 24, 2015 at 7:14 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Perhaps the issue is petsc-3.5. We tried this petsc-3.6 - and that
> worked fine..
> Satish
> On Wed, 24 Jun 2015, Mikhail Khodak wrote:
> > Yes, the variables are defined. Using setup.py gives the same error.
> > As a note, I am using a download of the master branch.
> > Mikhail Khodak
> > On Wed, Jun 24, 2015 at 7:15 AM, Lisandro Dalcin <dalcinl at gmail.com>
> wrote:
> > > On 23 June 2015 at 12:15, Mikhail Khodak <mkhodak at princeton.edu>
> wrote:
> > > > Thank you for reviewing this. The errors for the command 'pip2
> install .'
> > > > inside the petsc4py directory are attached, along with the
> configure/make
> > > > logs for the PETSc build.
> > > > Best,
> > > > Mikhail Khodak
> > > Not sure what's going on.
> > > Do you have PETSC_DIR and PETSC_ARCH in your environment?
> > > Does it work if you just do "python setup.py build" ?
> > > Lisandro Dalcin
> > > Research Scientist
> > > Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> > > Numerical Porous Media Center (NumPor)
> > > King Abdullah University of Science and Technology (KAUST)
> > > http://numpor.kaust.edu.sa/
> > > 4700 King Abdullah University of Science and Technology
> > > al-Khawarizmi Bldg (Bldg 1), Office # 4332
> > > Thuwal 23955-6900, Kingdom of Saudi Arabia
> > > http://www.kaust.edu.sa
> > > Office Phone: +966 12 808-0459
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150624/e3807f37/attachment.html>
