[petsc-users] petsc4py Build Problem
    Mikhail Khodak
    mkhodak at princeton.edu
    Wed Jun 24 21:12:37 CDT 2015
Yes, the variables are defined. Using setup.py gives the same error.
As a note, I am using a download of the master branch.
Mikhail Khodak
On Wed, Jun 24, 2015 at 7:15 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 23 June 2015 at 12:15, Mikhail Khodak <mkhodak at princeton.edu> wrote:
> > Thank you for reviewing this. The errors for the command 'pip2 install .'
> > inside the petsc4py directory are attached, along with the configure/make
> > logs for the PETSc build.
> > Best,
> > Mikhail Khodak
> Not sure what's going on.
> Do you have PETSC_DIR and PETSC_ARCH in your environment?
> Does it work if you just do "python setup.py build" ?
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Numerical Porous Media Center (NumPor)
> King Abdullah University of Science and Technology (KAUST)
> http://numpor.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 4332
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150624/c6afb4c0/attachment.html>
