[petsc-users] Reg : PETSC Installation
    Satish Balay
    balay at mcs.anl.gov
    Wed Jun 17 08:47:41 CDT 2015
On Wed, 17 Jun 2015, Manish Kumar K wrote:
> Dear PETSc Team,
>          I am configuring and trying to install PETSc on Cygwin shell. While invoking following commands in shell
> Step 1:
> ./configure -with-cc=gcc -with-cxx=g++ --with-fc=gfortran --with-mpi=0
> --download-fblaslapack=/cygdrive/yourselectedloaction/fblaslapack-3.4.2.tar.gz -with-batch
You should not need -with-batch option. Also you can install lapack from cygwin - and use that.
> Step 2:
> ./conftest-arch-mswin-c-debug
> Step 3:
> ./reconfigure-arch-mswin-c-debug.py
> Step 4:
> make test all
> When i do the above steps I get libpetsc.a file generated in lib folder of PETSc "petsc-3.5.3\arch-mswin-c-debug\lib" .
> I need an libpetsc.lib file with .lib extension , can you please help me how to generate libpetsc.lib file
Presumably you need petsc.lib to use with MS compilers? If so - you should install PETSc with
MS compilers - and not cgywin/gnu compilers.
Please check instructions at:
http://www.mcs.anl.gov/petsc/documentation/installation.html#windows
Satish
> Let me know if you needed anything else
> Regards
> Manish K
> [https://relayq.larsentoubro.com/DigitalSignature2015.jpg]
> L&T Technology Services Ltd
> www.LntTechservices.com<http://www.lnttechservices.com/>
> This Email may contain confidential or privileged information for the intended recipient (s). If you are not the intended recipient, please do not use or disseminate the information, notify the sender and delete it from your system.
