[petsc-users] Reg : Building project using makefile in cygwin using	petsc
    Manish Kumar K
    Manishkumar.K at LntTechservices.com
    Wed Jun 17 08:43:14 CDT 2015
Dear PETSc Team,
         I am trying to build couple  .c files
eg : solidification.c , solidification_solver.c , solidification_find_ijk.c and so on with one header global_header.c
 using makefile in Cygwin,
For that I'm invoking following command
make PETSC_DIR=/cygdrive/c/Scratch/petsc PETSC_ARCH=arch-mswin-c-opt cdat
and I have placed my c files in petsc location " =/cygdrive/c/Scratch/petsc/arch-mswin-c-opt/cdat"
I get following error
$ make PETSC_DIR=/cygdrive/c/Scratch/petsc PETSC_ARCH=arch-mswin-c-opt cdat
make: *** No rule to make target 'cdat'.  Stop.
I want and .exe file to be generated for this project of mine  eg : example.exe as my end result.
I have attached makefile with this mail ,kindly help on this would be appreciated.
Please help me in this .
Regards
Manish K
[https://relayq.larsentoubro.com/DigitalSignature2015.jpg]
L&T Technology Services Ltd
www.LntTechservices.com<http://www.lnttechservices.com/>
This Email may contain confidential or privileged information for the intended recipient (s). If you are not the intended recipient, please do not use or disseminate the information, notify the sender and delete it from your system.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150617/765746c4/attachment.html>
Type: application/x-zip-compressed
Desc: makefile.zip
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150617/765746c4/attachment.bin>
