[petsc-users] Reg : Building project using makefile in cygwin using petsc
Wed Jun 17 08:59:03 CDT 2015
On Wed, 17 Jun 2015, Manish Kumar K wrote:
> Dear PETSc Team,
>          I am trying to build couple  .c files
> eg : solidification.c , solidification_solver.c , solidification_find_ijk.c and so on with one header global_header.c
Normal notation for a header file is to use a '.h' notation - i.e global_header.h
>  using makefile in Cygwin,
> For that I'm invoking following command
> make PETSC_DIR=/cygdrive/c/Scratch/petsc PETSC_ARCH=arch-mswin-c-opt cdat
> and I have placed my c files in petsc location " =/cygdrive/c/Scratch/petsc/arch-mswin-c-opt/cdat"
You can have your applications files in any location [don't need to add them to PETSc source or install dir]
> I get following error
> $ make PETSC_DIR=/cygdrive/c/Scratch/petsc PETSC_ARCH=arch-mswin-c-opt cdat
> make: *** No rule to make target 'cdat'.  Stop.
Are you sure you have the makefile in the same location as the sources?
include C:/Scratch/petsc/conf/variables
include C:/Scratch/petsc/conf/rules
This is not really cygwin make format.
Also you appear to link with /cygdrive/c/Scratch/petsc/arch-mswin-c-opt/lib/SDPFlex.lib
You would have to rebuild this with cygwin gcc/g++/gfortran compilers - for this to work.
If you are able to do that - the attached modified makefile is likely to work..
Satish
> I want and .exe file to be generated for this project of mine  eg : example.exe as my end result.
> I have attached makefile with this mail ,kindly help on this would be appreciated.
> Please help me in this .
> Regards
> Manish K
> [https://relayq.larsentoubro.com/DigitalSignature2015.jpg]
> L&T Technology Services Ltd
> www.LntTechservices.com<http://www.lnttechservices.com/>
> This Email may contain confidential or privileged information for the intended recipient (s). If you are not the intended recipient, please do not use or disseminate the information, notify the sender and delete it from your system.
SPDFLEX_LIB = -lSDPFlex
CFLAGS	         =
FFLAGS	         =
CPPFLAGS         =
FPPFLAGS         =
EXAMPLESC        = solidification_read_mesh_CaPS.c \
				solidification_read_mat_property.c \
				solidification_find_ijk.c \
				solidification_find_node_number.c \
				solidification_solver_tmatrixb.c \
				solidification_solver_tgradient.c \
				solidification_solver.c \
				solidification_print_results_first.c \
				solidification.c \
				solidification_find_hotspot.c \
				solidification_read_input_data.c \
				solidification_solver_calc_property.c \
				solidification_solver_calc_htc.c \
				solidification_read_htc_data.c \
				solidification_vdg.c
CLEANFILES       = cdat
include ${PETSC_DIR}/conf/variables
include ${PETSC_DIR}/conf/rules
cdat: chkopts ${OBJSC}
	-${CLINKER} -o cdat-petsc-lic ${OBJSC} ${PETSC_LIB} ${SPDFLEX_LIB}
	${RM} ${OBJSC}
