[petsc-users] Modified Taylor-Hood elements with piece-wise constant pressure for Stokes equation
Justin Chang
jychang48 at gmail.com
Tue Jun 2 17:12:05 CDT 2015
Actually, something is wrong. The velocity solutions are correct, but the
pressure solution has gone awry (see attached, left uses MTH whereas right
is TH). Don't know why I didn't catch this earlier, I may need to consult
to the FEniCS guys for this
On Tue, Jun 2, 2015 at 4:45 PM, Jed Brown <jed at jedbrown.org> wrote:
> Justin Chang <jychang48 at gmail.com> writes:
> > Last one with the svd did not work with the way the AMG PC was hard-coded
> > into FEniCS. Here's the list of preconditioners my installation of FEniCS
> > supports:
> > Preconditioner | Description
> > default | default preconditioner
> > ilu | Incomplete LU factorization
> > icc | Incomplete Cholesky factorization
> > sor | Successive over-relaxation
> > petsc_amg | PETSc algebraic multigrid
> > jacobi | Jacobi iteration
> > bjacobi | Block Jacobi iteration
> > additive_schwarz | Additive Schwarz
> > amg | Algebraic multigrid
> > hypre_amg | Hypre algebraic multigrid (BoomerAMG)
> > hypre_euclid | Hypre parallel incomplete LU factorization
> > hypre_parasails | Hypre parallel sparse approximate inverse
> > none | No preconditioner
> Wrapping an extensible dynamic system with a static maintenance burden
> is pretty much the canonical example of bad design.
> I used to keep a patched version of Dolfin so I could bypass this stupid
> table. The table can and should be constructed dynamically using
> const char **pcs;
> int npcs;
> PetscFunctionListGet(PCList,&pcs,&npcs);
> Anyway, are you sure this wasn't fixed so that you can pass PETSc
> options directly?
> If you can get commands to PETSc, but just can't change the
> preconditioner, then try
> -ksp_view_mat binary
> (for the tiny problem) and open the resulting matrix "binaryoutput" in
> octave/matlab/scipy.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150602/b175bae0/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150602/b175bae0/attachment-0001.png>
