[petsc-users] Modified Taylor-Hood elements with piece-wise	constant pressure for Stokes equation
    Jed Brown
    jed at jedbrown.org
    Tue Jun  2 16:45:54 CDT 2015
Justin Chang <jychang48 at gmail.com> writes:
> Last one with the svd did not work with the way the AMG PC was hard-coded
> into FEniCS. Here's the list of preconditioners my installation of FEniCS
> supports:
> Preconditioner    |  Description
> default           |  default preconditioner
> ilu               |  Incomplete LU factorization
> icc               |  Incomplete Cholesky factorization
> sor               |  Successive over-relaxation
> petsc_amg         |  PETSc algebraic multigrid
> jacobi            |  Jacobi iteration
> bjacobi           |  Block Jacobi iteration
> additive_schwarz  |  Additive Schwarz
> amg               |  Algebraic multigrid
> hypre_amg         |  Hypre algebraic multigrid (BoomerAMG)
> hypre_euclid      |  Hypre parallel incomplete LU factorization
> hypre_parasails   |  Hypre parallel sparse approximate inverse
> none              |  No preconditioner
Wrapping an extensible dynamic system with a static maintenance burden
is pretty much the canonical example of bad design.
I used to keep a patched version of Dolfin so I could bypass this stupid
table.  The table can and should be constructed dynamically using
  const char **pcs;
  int npcs;
  PetscFunctionListGet(PCList,&pcs,&npcs);
Anyway, are you sure this wasn't fixed so that you can pass PETSc
options directly?
If you can get commands to PETSc, but just can't change the
preconditioner, then try
  -ksp_view_mat binary
(for the tiny problem) and open the resulting matrix "binaryoutput" in
octave/matlab/scipy.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150602/6630aa04/attachment.pgp>
