[petsc-users] Modified Taylor-Hood elements with piece-wise constant pressure for Stokes equation
Matthew Knepley
knepley at gmail.com
Tue Jun 2 07:08:16 CDT 2015
On Mon, Jun 1, 2015 at 9:51 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Jed,
> I am not quite sure what you're asking for. Are you asking for how people
> actually implement this augmented TH? In other words, how the shape/basis
> functions for this mixed function space would look? I have only seen in
> some key note lectures and presentations at conferences briefly mentioning
> this P2/(P1+P0) element, as if it's the de facto discretization for Stokes
> flows. That said, even I am not too sure how this would look.
> Matt,
> In the 'quad_q2p1_full' example you pointed me to, is that P2/P1_disc or
> P2/(P1+P0)? I imagine those are two very different discretizations, so when
> you have the command line option "-pres_petscdualspace_lagrange_continuity
> 0" it looks to me you're doing the former?
Its Q2-P1_disc. That is stable and captures the pressure jumps well. This
is the standard variable-viscosity Stokes element in
my experience.
Matt
> Thanks,
> Justin
> On Mon, Jun 1, 2015 at 10:02 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Jun 1, 2015 at 9:38 AM, Jed Brown <jed at jedbrown.org> wrote:
>>> Justin Chang <jychang48 at gmail.com> writes:
>>> > There are a few papers that discuss this modified/augmented Taylor-Hood
>>> > elements for Stokes equations in detail (e.g.,
>>> > http://link.springer.com/article/10.1007%2Fs10915-011-9549-4).
>>> This analysis does not state a finite element.
>> They certaiinly state the approximation space up front. Then later in the
>> paper
>> they say that they independently test with P1 and P0, and that this has a
>> 1D
>> null space, and then in the solution section they have some way of
>> handling that
>> which I ignored because its easy to handle.
>> Matt
>>> > From what I have seem, it seems people primarily use this to ensure
>>> > local mass conservation while attaining the desirable qualities of the
>>> > TH element. Lately I have seen this element used in many FEniCS and
>>> > Deal.II applications (and it's also very easy to implement, just a few
>>> > additional lines of code),
>>> Could you point to a specific example? How are they handling
>>> linear dependence of the "basis"?
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150602/65834745/attachment.html>
