[petsc-users] Modified Taylor-Hood elements with piece-wise constant pressure for Stokes equation
Matthew Knepley
knepley at gmail.com
Tue Jun 2 16:12:05 CDT 2015
On Tue, Jun 2, 2015 at 4:00 PM, Justin Chang <jychang48 at gmail.com> wrote:
> MTH did not converge with the default -ksp_rtol 1e-6 so I had to raise the
> tolerance to 1e-5 in order to get a solution. Attached are the outputs for
> TH and MTH
This really looks like it was never solving this system.
Matt
> Last one with the svd did not work with the way the AMG PC was hard-coded
> into FEniCS. Here's the list of preconditioners my installation of FEniCS
> supports:
> Preconditioner | Description
> default | default preconditioner
> ilu | Incomplete LU factorization
> icc | Incomplete Cholesky factorization
> sor | Successive over-relaxation
> petsc_amg | PETSc algebraic multigrid
> jacobi | Jacobi iteration
> bjacobi | Block Jacobi iteration
> additive_schwarz | Additive Schwarz
> amg | Algebraic multigrid
> hypre_amg | Hypre algebraic multigrid (BoomerAMG)
> hypre_euclid | Hypre parallel incomplete LU factorization
> hypre_parasails | Hypre parallel sparse approximate inverse
> none | No preconditioner
> I would need to change a few things here and there if we really insisted
> on seeing if svd works.
> On Tue, Jun 2, 2015 at 3:00 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Justin Chang <jychang48 at gmail.com> writes:
>> > I originally solve that example problem using LU.
>> I'd like to learn why LU didn't notice that the system is singular.
>> (The checks are not reliable, but this case should be pretty obviously
>> bad.)
>> > But when I solve this one:
>> http://fenicsproject.org/documentation/dolfin/1.5.0/python/demo/documented/stokes-iterative/python/documentation.html
>> > By simply running their code as is for TH and adding the one like I
>> > mentioned for MTH, I get the following outputs when I pass in
>> -ksp_monitor
>> > -ksp_view and -log_summary
>> Thanks, Justin. Could you please run with
>> -ksp_type gmres -ksp_gmres_restart 1000 -ksp_monitor_true_residual
>> -ksp_monitor_singular_value
>> Also, can you run a tiny problem size (like less than 1000 dofs) with
>> -pc_type svd -pc_svd_monitor
>> Thanks.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150602/ef60c631/attachment.html>
